Originally Posted by framanda
you have probably seen what i was reffering to, But heres a pic just in case. this is where I measured my castor from.
Originally Posted by 1skrewsloose
Great pics, thanks. But where do you measure to get reference for the angle? Mine has slight dw that is less noticeable when loaded heavy in the back. Basically the same thing is going on? New to jeeps. Also is alignment needed when changing caster?
See the pic Framanda uploaded, this is where I measured bottom of the C set mine to 4* with 4.5" springs, also you can only change castor if you have adjustable control arms.. also make sure you don't have worn out TRE's, Trackbar bushings and balljoints.
