McCloud's Niner Build/Rebuild Thread - Page 16 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > McCloud's Niner Build/Rebuild Thread
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineThe Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!
Unread 02-12-2013, 12:11 PM   #226
GCjunkie93
Originally Posted by McCloudsZJ
Dropped everything. No court fees, no DIP, no points off my license.
The judge was going to suspend my license for six months on reckless driving. The cop that pulled me over and chimed in. He said that it was in no way my fault; he barely made it to me and he had snow chains on his 4WD SUV.
That's awesome! It's nice to actually have some honest cops. No one around here would step up and admit that
1993 ZJ 5.2 V8-Some Stuff/Beater
1984 CJ7 258/Auto/Dana 300/Daily Driver
GCjunkie93 is offline   Reply With Quote Quick reply to this message
Unread 02-13-2013, 09:13 AM   #227
McCloudsZJ
Because RaceJeep
McCloudsZJ's Avatar
Enough chit chat. Back to a Jeep build. Got this from Kolak. It's pure beef. Can't wait to get it painted and installed. Thanks Kolak!
In the garage: M1 4bbl
McCloudsZJ is offline   Reply With Quote Quick reply to this message
Unread 02-15-2013, 03:53 PM   #228
McCloudsZJ
Because RaceJeep
McCloudsZJ's Avatar
Power steering pulley is off kilter or something. The pump is mounted properly, but the pulley wobbles now. Causes a squeak every time it goes around and rubs the edge of the belt. This is bad news because it's ****ing with my serp belt and I'm working 75+ hours this week and next. Not to mention, it's putting all sorts of off-axis stress on that pulley. Have you seen a PS pulley explode? Because I have. God $%#@ mother #$%^ing piece of @$#@ sucking @($# eating $#@&!!!!!!
In other news, the Jeep fund was temporarily diverted into the diamond fund. I made the last payment on an engagement ring last week and proposed last night.
Unread 02-15-2013, 03:58 PM   #229
bananaslug
Based on you ball and chain we'll take it that she said yes haha. Congrats
bananaslug is offline   Reply With Quote Quick reply to this message
Unread 02-15-2013, 04:16 PM   #230
kg6mov
kg6mov's Avatar
Jeeps spitting out power steering pulleys is no fun. You can run without it if you have to, but it's not recommended.
1996 ZJ Green Laredo V8, 2.5" OME and Bilsteins, 33's, Holes drilled in the roof.
kg6mov is offline   Reply With Quote Quick reply to this message
Unread 02-15-2013, 05:36 PM   #231
Scopez
1994 ZJ
Any chance the mounting bracket is cracked? That could cause it.
94 ZJ Laredo. 5.2 Crate engine. 6in JKS SA Lift. 33in Destination MTs. ARB Front Bumper.
Scopez is offline   Reply With Quote Quick reply to this message
Unread 02-22-2013, 07:36 PM   #232
McCloudsZJ
Because RaceJeep
McCloudsZJ's Avatar
**** this ****. I've worked 14 hour days for the last seven days. I miss playing with the Jeep. I now have...
ORDERED:
  • Power steering pump
  • Power steering pulley
  • Power steering bracket
  • Intake manifold/plenum gasket (decided against the permanent repair right now--I'm a baller on a budget)
  • Intake manifold bolts
SITTING IN THE **** CLOSET:
  • Steering linkage
  • Isolators
  • Spring compressors
  • Couple cans of red paint (for the springs and linkage)
  • The whole interior--I did finish wrapping the door trim in brushed aluminum, though
  • My head unit
  • The rest if the new carpet
  • 75 ft^2 of sound insulation (for the doors, rear hatch, and roof)
10 days until I get a day off!!!
Unread 02-22-2013, 07:58 PM   #233
davidtownsend
2006 WK
Your still using the perl and seal?
1994 Jeep Grand Cherokee 5.2L Limited
2006 Jeep Grand Cherokee Overland 5.7L Hemi
davidtownsend is offline   Reply With Quote Quick reply to this message
Unread 02-25-2013, 09:12 AM   #234
McCloudsZJ
Because RaceJeep
McCloudsZJ's Avatar
: After pulling every single fuse under the hood and in the passenger side and every one under the hood and all the relays, one by one, I though I'd isolated my parasitic drain to the alternator. Replaced that, drove it for two weeks, everything was golden. That was when I drove it every day, several times a day. I let it sit for the weekend and drove the work truck. Went to start it this morning at 5:30. Nothing. Not even interior lights when I unlocked it (manually). One more week until I get a day off. Until then, I'll just be undoing the battery every time I park it. :
Unread 02-26-2013, 09:08 AM   #235
McCloudsZJ
Because RaceJeep
McCloudsZJ's Avatar
I "fixed" the squeaky pulley. I dripped a couple drops of Dawn dish detergent on the belt--it's silent now. My Mopar stickers had given up on life. They just couldn't handle the intense heat under the hood, even with the louvers to keep then chilled.
So, I had five minutes alone with a can of spray paint... I tend to get carried away when that happens.
It's worth mentioning that the louvers are Plastidipped under the spray paint. I can just peel off the red and go back to deep slate any time I fancy. This was mostly an experiment to see how far I can take the red and slate theme.
Unread 02-26-2013, 09:24 AM   #236
McCloudsZJ
Because RaceJeep
McCloudsZJ's Avatar
I guess I should have included a picture of the final product. What do you think? With the steering linkage, wheel lips, springs, and diff covers this color red, is it going to be too much?
Unread 02-26-2013, 09:33 AM   #237
Scopez
1994 ZJ
It'll look very sporty IMO. I'm liking it.
Unread 02-26-2013, 11:57 AM   #238
adavis39
[QUOTE=McCloudsZJ;15039231]I guess I should have included a picture of the final product. What do you think? With the steering linkage, wheel lips, springs, and diff covers this color red, is it going to be too much?[QUOTE]
im not a fan of it....BUT its hard to get a real sense of it because I cant see the entire JEEP in the pic, and your currently mis-matched bumper cover really clashes with the red and makes it look worse than it probably would with a matching cover
2002 WJ Limited [B]4.7[/B]: 6" Clayton REALLY long arms....yep, they are longer than yours [B]SOLD : ([/B]
1998 Platinum [B]5.9[/B] DD
2007 WK Overland [B]5.7[/B] wifes DD
TNJEEPS.COM
BUILD: [B][url]http://www.jeepforum.com/forum/f197/utwj-build-other-crap-1399123/[/url][/B]
[B]"In a world that he did not create, but he will go through it as if it is his own creation. Half man, half beast, whatever it is it is weird, it is ticked off and it calls itself Slash"[/B]
adavis39 is offline   Reply With Quote Quick reply to this message
Unread 02-26-2013, 12:05 PM   #239
McCloudsZJ
Because RaceJeep
McCloudsZJ's Avatar
I should have cropped that out. I know the purple looks ****ing stupid. I'm really hoping to tie it all together with a properly painted bumper and some red accents here and there. If it doesn't work, then I'll just peel the red off of the louvers. They're the only thing that I think could be "over the top."
Unread 02-27-2013, 10:16 AM   #240
McCloudsZJ
Because RaceJeep
McCloudsZJ's Avatar
The red is off the louvers. It looked like a lady bug or something. Black and red spots.
In other news, the rear wiper motor is shot. The solution? Delete the rear wiper! While I'm getting plugs, the radio antenna is coming out, too.
