Making my ZJ Tow Worthy? - JeepForum.com
post #1 of 5 Old 06-08-2010, 05:08 PM Thread Starter
dm0326
Hello All,
First post here! I have a 1998 Grand Cherokee with an I6. I do not have the tow package, and from what I understand from reading, I can only tow 2000lbs max if I don't make modifications. I have just recently purchased a 3300 lb trailer and I would like to be able to tow it with the ZJ. What can I do to my ZJ to make it tow worthy? I have heard rear air bags, tranny cooler, P/S pump replacement, new axle ration. Do you agree with these suggestions? I am not sure what I need to do. Thanks in advance!!!
dm0326 is offline
post #2 of 5 Old 06-08-2010, 06:12 PM
JFox21
I think you have a XJ Cherokee, not a ZJ Grand Cherokee, or maybe the other way around. Either way, you have an Inline 6, not a V6.
Welcome to JF!
Jamie
Sophomore at Santa Clara University
JFox21 is offline
post #3 of 5 Old 06-08-2010, 08:42 PM Thread Starter
dm0326
I have a ZJ Grand Cherokee, sorry for the confusion. New to these jeep terms.
dm0326 is offline
post #4 of 5 Old 06-08-2010, 09:18 PM
jamnjeep
All you really need to do is install the correct Class 3 hitch and wiring harness. You could get a tranny cooler to be on the safe side and thats about it. I know plenty of people that have added a hitch and pull 4k ib trailers.
Changing the gear ratio would help a little but not really needed.
The biggest problem is braking but you get the same brakes from the factory regardless if you have the factory tow package.
1994 YJ under construction....
jamnjeep is offline
post #5 of 5 Old 06-09-2010, 05:37 AM
comptiger5000
Once you add the hitch, add a big cooler for the tranny, and maybe a small one for the power steering. Other than that, you should be OK. Regearing the axles is optional, and for 3300 lbs, probably not needed.
Of course, being that ZJ brakes kinda suck, I wouldn't tow anything that heavy without trailer brakes, which, if electric, will require a brake controller.
comptiger5000 is offline
Jeep Worthy Music RiponredTJ Wrangler General Discussion 78 05-24-2010 09:15 AM
2006 Grand Cherokee is it off road worthy ModernJ WK Grand Cherokee & XK Commander Forum 6 07-29-2009 11:02 AM
Wave worthy? jeepwrangler97 Wrangler General Discussion 139 04-17-2009 09:58 PM
Just a few questions not worthy of a new thread MoonyJohn ZJ Grand Cherokee Forum 43 03-28-2009 07:43 PM
A sticky worthy link ?? rxl ZJ Grand Cherokee Forum 6 08-28-2007 07:34 AM
