Linus '04 WJ build - Page 2 - JeepForum.com
post #16 of 35 Old 10-13-2012, 04:36 PM
Thomahawk
Originally Posted by Linus
Got a good deal from Discount Tire Direct on some General Grabber 255/70R17 tires, 31". Got them mounted on some JK moabs I bought earlier this summer.
Looking bad @$$, just ordered same size wheels, excact same tires, same height lift, yours look perfect, i am really stoked now. Thumbsup!
How do they sit in/out, do you have a picture along the side from front or rear, do they sit flush with upper outer fender Edge, or does it stick out???
Buildthread
Thomahawk is offline
post #17 of 35 Old 10-14-2012, 12:45 PM Thread Starter
Linus
Thanks! I like the set up pretty good so far. It is a firm ride though, so be warned. The Moabs are .5" wider then the stock Silverblades and the Grabbers are another .5" wider then my old tires so I am about 2" wider per axle. I like the stance better now, not recessed like the stock set up.
04 WJ - 4.0L and Selec-Trac
BDS 2", 3/4" spacers, Bilstein 5100, and 31" General Grabber AT2's
Linus is offline
post #18 of 35 Old 10-14-2012, 12:51 PM
Thomahawk
THANKS, Looks good!
Buildthread
post #19 of 35 Old 11-13-2012, 12:35 PM
WarEagle91
Jeep looks good I am actually doing the same lift next Monday when I have a break from school and I saw that AU decal on your jeep so.....WAR DAMN EAGLE!
WarEagle91 is offline
post #20 of 35 Old 11-13-2012, 04:49 PM
TwilightAuto
wow nice work man! looking good!
http://www.TwilightAuto.com
TwilightAuto is offline
post #21 of 35 Old 11-14-2012, 03:47 PM Thread Starter
Linus
Thanks man, yeah it's a good lift and was easy to put on considering I don't have a lot of experience working on cars...and War Eagle!!
Thanks, got a few more plans for it
Linus is offline
post #22 of 35 Old 11-19-2012, 01:05 PM Thread Starter
Linus
Did this over the weekend, trying to make it to 200k
Linus is offline
post #23 of 35 Old 11-25-2012, 12:15 PM Thread Starter
Linus
Since the 2" lift I have noticed a little more body roll and squeaking from the stressed rear sway bar links. I thought I would save some money and fab up some bracket spacers to return them to the stock lengths.
I picked up a 2" receiver from harbor freight for $20. I measured the bracket and made 2 cuts with a reciprocating saw.
I used the bracket as a template and drilled 4 holes to mount it to the body and to mount the bracket to the underside. For hardware I used 1" long 3/8" bolts, washers, and nuts.
Here is the rear sway bar and link before bracket spacers.
And here they are after I installed the spacer and lowered them back closer to a stock level.
I am not a great mechanic or am I a machinist. My personal advice is to just buy the 2" extended sway bar links from IRO or Zone. Or at the least use an easier to cut material. While it is convenient the receiver hitch is 2" x 2", it is strong steel and ate through a saw blade and drill bit. So if you have a band saw and drill press I saw go for it, if not, easier just to pick up the longer links.
Linus is offline
post #24 of 35 Old 11-26-2012, 06:56 AM
RedlegWJ
Saving the reciever for a bumper build?...
For future referance, if you use cutting oil with your sawzall, it'll save your blades and surprise on how ell it will do, although slow. At least until you get a better saw. Same for the drill bits. Slow down and use oil.
Gray 99 Laredo with '04 driveline wap. Tons of fun coming soon. Steel bumpers. 5 1/2" IRO coils, IRO adj. track bar. Rancho RS9000 Addco rear sway. 2"x.250" DOM long arms with johny joints. Custom A-arm with ball joint delete (J-joint). JK Moab wheels/ 33x 12.5 x 17 Cooper SST. Bushwacker Flares.
RedlegWJ is offline
post #25 of 35 Old 11-26-2012, 02:26 PM Thread Starter
Linus
Yeah I thought about oil but I got lazy and just carried on. Just glad they are done and on!
Linus is offline
post #26 of 35 Old 12-08-2012, 03:47 PM Thread Starter
Linus
The cushion had split and the frame was poking through and was pretty uncomfortable on my ribs. So I took the drivers side seat out, took the back off and pealed back the upholstery to see what was wrong.
I pulled the cushion back over the frame bar and sprayed some 3M adhesive spray into the crack. I let it set up for a minute then I held the cushion back together for it dry. I then used some scrap denim I had, sprayed more adhesive on it, and put it over the crack like a patch. Hopefully it will help hold the crack together.
I also wrapped the frame bar with some scrap felt in case it pokes back through the cushion, at least I'll have more then just the thin upholstery to cushion it. Put the seat back and sat in it for a minute. And it feels much better. Much more padded on that side now, just hope it holds up another 124k miles
Linus is offline
post #27 of 35 Old 12-30-2012, 03:51 PM Thread Starter
Linus
Got 2 Hella 6" driving lights for Christmas and mounted them up yesterday. Decided to put them on the bumper. Put a big fender washer on the underside and everything feels pretty sturdy. But a heads up if you mount lights here, I got as close to the grill as I could but the bolt going through the bumper hits the unibody when you put the bumper cover back on. So the middle of the bumper sticks out an inch or so more then before. I could only get the far left and right 2 plastic rivets to engage. And I had to trim the middle tab on the bumper cover to get the grill to clip back on.
Linus is offline
post #28 of 35 Old 01-01-2013, 11:41 AM Thread Starter
Linus
Got all my Christmas presents on over the last week.
Dynomax Super Turbo muffler, part# 17743. Sounds pretty good, I'll try and get a video of it later
Also mounted up my Rola roof rack and Hella lights
Linus is offline
post #29 of 35 Old 01-17-2013, 07:28 AM
dcorn
Jeep looks great, lift and tires appear perfect for a DD. So is that with 2" springs and a 3/4" spacer in the front to even it out? I'm considering selling my WRX and picking up a WJ to save some dough.
2014 Jeep Grand Cherokee Summit
dcorn is offline
post #30 of 35 Old 01-19-2013, 04:14 PM Thread Starter
Linus
Thanks man, and yes there is a 1" rake from the factory so the 3/4" spacer up front helps level it out. I like my WJ but man I'd have a tough time giving up a WRX!
Linus is offline
Bumper Build Project For my 95 ZJ: Build Time- 1 Month TMNT2210 ZJ Grand Cherokee Forum 43 09-10-2015 12:57 PM
Yellow jp79's Garage Build......so I can do my Jeep Build!!!!!! yellowjp79 Wrangler General Discussion 152 11-07-2013 06:31 AM
My "not-quite-a-build" ZJ build thread.. Kur ZJ Grand Cherokee Forum 57 01-12-2013 09:41 AM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 12:45 PM
Fbi (offroad build inspeter) build 93zjFBI ZJ Grand Cherokee Forum 8 12-18-2010 11:43 PM
