Justin's Bumper Build Thread - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Justin's Bumper Build Thread
FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitFS: Wranger BRIGHT License Plate LED! Just $3! Great valueToxic Brakes - 3000 PSI Braided Stainless Steel Brake Line
Unread 06-14-2012, 12:57 PM   #16
Justin_WJ
Originally Posted by narnwv
but will be for mine right.
Honestly if I had the time Aaron, I might build a couple and sell them, but the time isn't there, I have resources, but no time it's probably gonna take me three weeks to build this one....
2000 WJ Limited, 4inch RC X, 242 T-case swap, 33x12.50 STT's, 15x8 D window wheels with 3.75 BS, JKS ADJ. Tracbar, T-case armor, Custom front winch bumper, Smittybilt XRC 8, 4.56's Extended Rola Rack w/Harbor Freight 6" lights, and always muddy :)
Justin_WJ is offline   Reply With Quote Quick reply to this message
Unread 06-14-2012, 01:39 PM   #17
Timbo24
Originally Posted by Justin_WJ
Got the grill cut away from the bumper as well.
What are your specs? That looks tall.
Timbo24 is offline   Reply With Quote Quick reply to this message
Unread 06-14-2012, 01:54 PM   #18
narnwv
narnwv's Avatar
his signature says RC-X 4", 33s
~Aaron
narnwv is offline   Reply With Quote Quick reply to this message
Unread 06-14-2012, 01:57 PM   #19
Justin_WJ
Haha. Guy I know at work owns this.
Unread 06-14-2012, 03:19 PM   #20
PhantomWJ
2003 WJ
What is the square tubing for...i dont get it..
PhantomWJ is offline   Reply With Quote Quick reply to this message
Unread 06-14-2012, 03:44 PM   #21
Justin_WJ
Reinforcement for the winch to bolt to..
Unread 06-14-2012, 04:09 PM   #22
PhantomWJ
2003 WJ
Oh
Unread 06-14-2012, 04:44 PM   #23
Justin_WJ
And 2x4 because my t-case chain is stretched....Lmfao.
Unread 06-20-2012, 08:01 AM   #24
Justin_WJ
Thoughts?
And yes, I will come up with some sort of airflow holes,
Unread 06-20-2012, 09:30 AM   #25
narnwv
narnwv's Avatar
~Aaron
Unread 06-20-2012, 12:11 PM   #26
Justin_WJ
told ya it was going to take a while...haha, i think im going to buy a winch before i continue. just to insure its going to fit that way i dont have to hack the bumper apart if it doesnt. Im going to make the radiator skid tonight at work. ill give dimensions once its made. im going to make it removable so if it ever gets bent i cant just make another...It will bolt to the existing lower radiator support and also bolt to the bottom of the 2x2 tubing.
Unread 06-21-2012, 01:10 AM   #27
Justin_WJ
Well no progress tonight, to much to do at work. Oh well. Maybe tomorrow
Unread 06-23-2012, 10:41 AM   #28
Justin_WJ
Well finally got a little progress, work has been crazy, punched this out on a Amada CNC turret punch, then bent it at 135 degrees on one side so it would line up when I bolted it to the tubing. In the bottom I used 3/8 ferrels in the existing lower radiator support.
I played around with the Amada the same night and programmed the fair lead plate with a OlllllO design in it. IT'S GONNA LOOK SWEET!!!!
Unread 06-23-2012, 10:43 AM   #29
narnwv
narnwv's Avatar
looking good man!
~Aaron
Unread 06-23-2012, 10:52 AM   #30
Justin_WJ
Thanks Aaron, I've come up with a lot of custom parts to put on it.
You're gonna be so jealous
