Jopolly3's WJ Build Thread: Lauren - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Jopolly3's WJ Build Thread: Lauren
ORS4x4: New Product!Aluminum Quick Release Fire Extinguisher Mounts from ORS4xKinetic Recovery Rope from ORS4x4
Unread 03-09-2012, 11:22 PM   #16
jopolly3
The first thing I went to work on was the interior. By the time it had made it to my buddy's shop the floors in the passenger area had already been coated with bed-liner and I had installed my Corbeau Baja Ultras. First I completely removed the stock gas tank and spare tire tub and laid down a piece of plate over the hole...
I decided to go with 4-point harnesses so I had a roll cage installed...
Joe
2013 JKU Rubicon 6spd: ARB Dana 44 covers F&R, Expedition One front bumper & swaybar skid, Hella driving lamps, JKS adjustable track bars F&R, MBRP SS off-road exhaust, OME HD springs and shocks, OME relocated SS, Rock Hard 4x4 gas tank skid, Rock Hard 4x4 oil pan skid, Rock Hard 4x4 rock sliders, Rock Hard 4x4 transfer case skid, Spidertrax wheel spacers, Superwinch LP8500 Gen 1
2002 Subaru WRX: Cobb intake, Mishimoto aluminum radiator, Kartboy short throw shifter and bushings
1960 CJ-6: Never ending project rig
Build Threads:
JKUR - [url]http://www.jeepforum.com/forum/f96/jopolly3s-jkur-build-thread-1522982/[/url]
CJ6 - [url]http://www.jeepforum.com/forum/f8/jopolly3s-cj6-build-thread-1347975/[/url]
WJ - [url]http://www.jeepforum.com/forum/f197/jopolly3s-wj-build-thread-lauren-1033184/[/url]
"BFG makes some good rubbers, if they sold condoms I'd buy them" -Owen Horner
jopolly3 is offline   Reply With Quote Quick reply to this message
Unread 03-09-2012, 11:40 PM   #17
jopolly3
The next project was a front axle swap. Originally I wanted to put the WJ on 3/4 tons front and rear but having second thoughts about the associated cost I decided to go in a different direction. I figured with all the weight shed in the rear (lost the tank, skid, interior trim, back seat, etc.) the 44HD would be a sufficient axle. I looked for different front axles and eventually came up with a hair-brained scheme involving a Ram D44 w/ CAD (see if you can guess what it is)...
The axle is out of a 1998 Ram 1500 5.9L, fun how a rattle can makes anything look new...
Originally I was going to use 35's but funds were low so I decided to borrow the rims and tires from my YJ project. They are 37" military Goodyear MT's mounted on U.S. Wheel steelies...
Joe
Build Threads:
Unread 03-09-2012, 11:52 PM   #18
jopolly3
From here it was time to pull the D30 and mock up the D44.
This was the starting point...
This job is so much easier with a fork lift...
Not going to lie, I was very surprised how wide this things stance was (full width axle sitting on 9" wide wheels with very little backspacing I don't know why I would be). The roll cage is definitely a moot point...
Joe
Build Threads:
Unread 03-10-2012, 12:08 AM   #19
jopolly3
With the axle mocked up it was time to weld on some brackets and sit it down.
I put a set of Spidertrax adapters in the rear to match the Ram's 5x5.5 bolt pattern up front...
She can still flex like a champ (but it eats the %&#@ out of the front fenders)...
Final welding on the brackets...
Random picture of my truck and my buddy's 2011 Powerstroke. He may be able to reverse the earth's rotation with those 800lbs-ft but can't keep up with the Hemi haha...
Joe
Build Threads:
Unread 03-10-2012, 12:14 AM   #20
jopolly3
This is how it is currently sitting in my parking lot. I have really done a poor job keeping up with the build but I will go through the truck with my camera this week to show off all the details...
Joe
Build Threads:
Unread 03-10-2012, 10:04 AM   #21
GraKee99
Rapist Wit
GraKee99's Avatar
Nice work! I don't like the white wheels but I know they are temporary. How do you like the corbeau seats? That is something that is high on my modification list.
Brian
WJ, WK, CJ5
GraKee99 is offline   Reply With Quote Quick reply to this message
Unread 03-10-2012, 03:33 PM   #22
jopolly3
Haha Yeah, when I bolted them up and my friend said "If you don't paint those I will..." I painted the 2 up front graphite, I still need to paint the rears and spare. The Corbeaus are amazing, they keep you dead center even when the truck feels like its going over. The thing is they make the Ultra SS in two sizes, I don't think the larger one will fit in a WJ too well (I have the narrow model and the door panels push on them when closed). The narrow model holds me perfectly (I am 5'10" ~140lbs) but my friend thinks they are a little tight (he is 6'1" probably ~230lbs).
Joe
Build Threads:
Unread 05-29-2012, 05:34 AM   #23
GRAND_WJ
Any updates?
'01 WJ Limited, 4.7v8 QT2, VSI LPG, snorkle, 8" lift, HD tie rod, HD crossmember, tom woods custom double/double drive shafts, LA front/rear, bilsteins, 35 12.5 hankook muddies on 17x9 MT sidebiters, ARB frontbar, 12000 pound winch, full recovery bag, on board air, XXX 220 spot lights, rola roof rack and Notch custom flares (Iceland flares) ...
GRAND_WJ is offline   Reply With Quote Quick reply to this message
Unread 05-29-2012, 07:25 AM   #24
squashman702
1994 ZJ
Guessing this is going to be a trailer-only rig from this point on?
Think Twice Garage
"I guess I'd just run it?"
squashman702 is offline   Reply With Quote Quick reply to this message
Unread 05-29-2012, 08:38 AM   #25
jopolly3
Originally Posted by GRAND_WJ View Post
Any updates?
The CJ has been dominating my time recently but I am turning back to the WJ for a bit. Last night I ordered brackets to slip the Ford 9 under the rear. I currently have the parts to assemble the 3rd member laid out on the bench at home (this coming weekends project). I also ordered an extra tensioner pulley to make up a bypass for the missing AC compressor.
Yeah, this project is officially a trail rig haha
Joe
Build Threads:
Unread 05-29-2012, 09:55 AM   #26
AgitatedPancake
leave the AC compressor and use it as an air compressor on the trail, their output volume is far superior to 99% of the 12v compressors out there
To contact me, email Greg@Frobotfab.com
Frobot Fabrication Facebook
01 WJ 5 Speed Claytons LA's, 36" Iroks, 35 spline 9" rear, Custom Ruffstuff 60-9" front axle.
Build Thread: http://www.mallcrawlin.com/forum//showthread.php?t=7387
AgitatedPancake's Youtube Channel
AgitatedPancake is offline   Reply With Quote Quick reply to this message
Unread 05-29-2012, 01:32 PM   #27
squashman702
1994 ZJ
Going to say- it would be quite the project to sneak it by someone for a sticker in MA. You do all your work in Brighton? I am in Allston.
Think Twice Garage
Unread 05-29-2012, 09:30 PM   #28
jopolly3
Haha I wish, the city buses ripping by making working on the street a little distracting. It failed inspection the way it was so "go big or go home" became the game plan. My father lets me use his garage out in Natick. Allston is pretty dense, where do you work on yours?
Pancake: Is that something you have done? I have looked at your build but I must have missed that... (too focused on the 5-spd haha)
Joe
Build Threads:
Unread 05-30-2012, 08:11 AM   #29
squashman702
1994 ZJ
My buddy (CTeunuch) has a shop in Sudbury, no place to work on it where I live in Allston (right off of Harvard Street).
Think Twice Garage
Unread 07-07-2012, 12:23 AM   #30
mtnmarc
nice wj on 37s and 4 inches of lift. ive been debating putting my 37s on at 4 inches.
can i see some more pictures of the rear? my 35s rub wheeling now.
99 WJ hp44, 3 link, Eaton e locker, 14" foa coilovers in the front. 14 bolt, 4 link, grizzly locker, 12" foa coilovers in the rear. 5.38s and 37s
mtnmarc is offline   Reply With Quote Quick reply to this message
