JeepWJ's 03 WJ Ltd Build Thread - Project Golfball - Page 11 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > JeepWJ's 03 WJ Ltd Build Thread - Project Golfball
WIN a Rough Country Forged Track Bar - ExtremeTerrain!FREE, FREE, FREE EVENT!! Save big on Lockers now till ApriJKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6
Unread 09-22-2010, 09:26 PM   #151
myjeeplovesmud
i've been told by many that it works, but i've never done it myself.... so let me know how it goes
2004 WJ Limited 4.7 H.O
K&N FIPK - Magnaflow Exhaust
17" XD Series Spy Rims- Custom Painted
ZONE 4" Lift With 32" Duratracs
Hella Lighting - Rola Rack - KOR 3/4 Spacers
IRO Sliders - Rusty's Hooks - Cobra CB
MY BUILD THREAD
BAD TO THE BONE ZONE
November 2010 GCOTM
myjeeplovesmud is offline   Reply With Quote Quick reply to this message
Unread 10-03-2010, 06:20 PM   #152
JeepWJ
2003 WJ
I still have yet to try the dry ice, but the hail damage yielded a small money tree which is kinda nice Also:
That's a SS relocation (and doesn't that tie-rod look kinda shiny??) Stepping away a bit:
OTK!!!!!
2003 WJ Ltd, 3" IRO w/ OTK + JKS discos, 245/70R17 BFG KM2s, JCR sliders, ProtoFab rear bumper, lots of electrical mods.
my build thread; my Jeep, my Twitter, my blog.
JeepWJ is offline   Reply With Quote Quick reply to this message
Unread 10-03-2010, 08:11 PM   #153
myjeeplovesmud
i think i saw you driving on 151 towards fitchburg thurday around 9am? maybe not?
MY BUILD THREAD
November 2010 GCOTM
Unread 10-03-2010, 08:59 PM   #154
MoonyJohn
Mallcrawler
MoonyJohn's Avatar
That SS "relocation kit" looks like garbage, it hangs down more than a stock one does and the bolts are freakishly long. Also, did you just flip the tie rod? I know you have to do some TRE work and sway bar end link work to make it "work" (said the w word too many times).
MoonyJohn is online now   Reply With Quote Quick reply to this message
Unread 10-03-2010, 09:12 PM   #155
patrick983
dont the relocation kits usually place the SS between the trackbar and draglink? ive got one laying around somewhere i never installed from IRO i guess i could look and see
2000 White V8 WJ LSR-6in-35's-LA's-242HD-Warn [B]SOLD and missed very badly[/B]
06 GTO - BC Coilovers, JBA Catless mids, Svede Intake
patrick983 is offline   Reply With Quote Quick reply to this message
Unread 10-03-2010, 09:21 PM   #156
Bama_WJ
That bracket to relocate the SS goes on the track bar mount on the "frame" side. Well, that's where I had mine for like 1.5 years. Now I have it mounted to the sway bar endlink mount on the axle and the other side of the SS is attached to the drag link.
Daniel
1 Ton WJ Build In Progress
The Daily: 2011 Chevy Cruze Eco - Trifecta tuned and 37+ MPG
Wife's Jeep: 2006 WK Overland - OME HD Lift, 265/70/17 BFG AT's, 1.25" SpiderTrax wheel spacers, 3" Gibson Cat-Back
North Alabama Jeep
42RE Vent Mod - Seal your transmission!
YouTube. - My Video Channel
Facebook - Wheeling Pictures/Videos
The Jeep Wave. Bringing it back.
Bama_WJ is offline   Reply With Quote Quick reply to this message
Unread 10-03-2010, 09:42 PM   #157
myjeeplovesmud
the more i look at that, i agree, you have that installed wrong
MY BUILD THREAD
November 2010 GCOTM
Unread 10-03-2010, 09:46 PM   #158
JeepWJ
2003 WJ
I think probably not - Thu 9a, I was headed up to Poynette, so I would have probably been on 12, P, 160, etc...
Hm...interesting. I found IRO's SS relocator instructions really confusing (actually, the OTK tie rod instructions weren't that great either, though the product itself is awesome). I may have put the SS in the wrong place, but the tie rod instructions said to put the SS hanger on the tie rod, and I seem to have NO DW, despite some pretty heavy-duty misalignment (which I'll take care of tomorrow)
@MoonyJohn, yeah, it looks like it hangs down pretty far, but you have to remember that the tie rod is at least 2" higher up than it was before, so I think it's still ok. I would also rather it were a little higher up, and I might try to move it 180 degrees, so it doesn't stick out as far, but a) it appears to work, and b) despite the looks, it is higher up than it was before.
I guess the real question is, is there any one RIGHT place to put an SS? I've seen 'em so many different places, I figured whether the SS is 'correctly' installed is mainly an issue of whether you get DW and/or binding with your configuration...at any rate, if someone has pics and/or known good configurations, I'm all ears!
Unread 10-03-2010, 10:37 PM   #159
Bama_WJ
There is no real wrong place to put it. Just make sure one end is attached to a solid non-steering component while the other end is obviously attached to either the tie rod or drag link.
Daniel
North Alabama Jeep
Unread 10-04-2010, 07:55 PM   #160
JeepWJ
2003 WJ
You know you drive a built WJ when.........you take it to the shop, and they can't figure out how to do a front end alignment, even after you told them how.
Theducksguts dropped by and we finally got 'er aligned. I played around a little with where to put the SS. It will NOT fit on the drag link; with it there, I can't turn my wheels to the left at all. So I'm thinking it'll have to go on the tie rod, hopefully in a little higher-clearance configuration. For tomorrow, though, I'll be driving without an SS. I just tested it out, and no DW (but a damp driver's seat nonetheless) at 45...fortunately, I won't need to get over 45 to get to work!
Unread 10-06-2010, 07:36 AM   #161
JeepWJ
2003 WJ
I still have to attach it (tonight), but I think I figured out where the SS can go. If I put the U-shaped bracket on the same bolt as the stud for my right disco, I should be able to attach the other end of the SS to the drag link. It'll be WAAAY high out of the way there!
Let's just hope it works. We'll find out tonight!
Unread 10-06-2010, 07:04 PM   #162
JeepWJ
2003 WJ
Finally got the SS tucked away safely. I REALLY like where it is. If you see any potential problems with it, please let me know, but I've had it out at 65 and it's rock solid. No bumpsteer whatever.
And from the other side:
Unread 10-07-2010, 08:05 PM   #163
JeepWJ
2003 WJ
So I had a little bit of stupid fun tonight.
That's $10 worth of Harbor Freight clearance lights! Like I said, stupid, but fun
They don't work yet. I just got them mounted. Running the wires will be a job for a different day.
I'm also working on a new project: a blog! It's here.
Unread 10-08-2010, 04:19 PM   #164
theducksguts
Glad you are staying busy. SS looks good. Much better than your first attempt. I'll say it again. The roof lights are an "interesting addition". Looks fine though.
00 XJ Sport 0331 Victim
99 XJ Sport
98 TJ
Check out my Classifieds
theducksguts is offline   Reply With Quote Quick reply to this message
Unread 10-08-2010, 04:48 PM   #165
JeepWJ
2003 WJ
Well, $10, for probably 3-4 hours' screwing around with the Jeep. I'd say that's a pretty good cost-to-install-time ratio!
I promise most of the rest of my mods will be more functional. I need some wheel spacers, and that steel bumper.
