Jeep in Norway 2th buildt Overland upgrade - Page 7 - JeepForum.com
 11Likes
post #91 of 823 Old 12-17-2013, 02:18 PM
snobrdrkid07
snobrdrkid07's Avatar
Plugs looked pretty good actually. You've been going through that WJ from top to bottom! Good to start fresh on all the fluids, etc for peace of mind!
Nice engine!
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #92 of 823 Old 12-17-2013, 02:26 PM Thread Starter
Thomahawk
2006 XK Commander
^^^Thx man, only couple of things needed done now, Fuel filter, PCV and crank case vent hoses, Transmission fluid and filters, diff fluid, then i know they Are all Good.
Got parts from Kolak today, 8 days from AZ USA > Norway, pretty damn impressive to me, guess paying That USPS EMS shipping was worth every penny.
Parts arrieved,
Rear bilstein shocks (for my lift)
WIX Transmission filter
WIX fuel filter
Crank case vent tubing
Airfilter
PCV's
So now i have Even more to do, soon everything on my list off maintainance will be checked out,,,
Then its time for some more SERIOUS mods and upgrades, stay tuned
Buildthread
Thomahawk is offline
post #93 of 823 Old 12-18-2013, 09:34 AM Thread Starter
Thomahawk
2006 XK Commander
More maintainance off my list today, replaced Crank case > intake tubing
+ Fuel filter
easy 30 min Fix, but its all about the small things.
Buildthread
post #94 of 823 Old 12-19-2013, 12:21 PM Thread Starter
Thomahawk
2006 XK Commander
Update on fuel consumption.
Calculated by EVIC:
As it was when i bought it Roadtrip 550km back home from PO, 1.8l/km~12.4mpg
Around town driving and sitting in rush hour trafic, 2.5l/km~9.4mpg!!!!
This is hilarious with gas prices at 16.5NOK pr/liter~10.22USD pr/gallon!!!! No wonder why PO claimed it was toooooo thirsty, i totally agree, lol
AFTER vacum/idle leak fix, Tune up/service, engine oil'n filter, PCV, TB/IAC/Airfilter/intake clean, sparkplugs, fuel filter
Around town driving and sitting in rush hour trafic, 1.85l/km~12.7mpg
Roadtrip to Sweden 250km today doing 75mph+ in heavy rain, 1.18l/km~19.93mpg!!!
EDIT: CALCULATED BY HAND:
Last 1 full tank 50/50 Mixed around town and highway, 1.59l/km ~ 14.79mpg.
Not bad to be a V8, guess fuel consumption worries now Are off my list, engine pulls strong, no lack off power, many many smiles pr miles
Buildthread
post #95 of 823 Old 12-19-2013, 12:29 PM
jeepwrangler97
I'm Norwegian...ish (mostly) & think it'd be awesome to move there...but $10.22/gallon.
I also don't speak Norwegian or know how I'd get my jeep there....but still think it'd be cool
Sent by a messenger bird
jeepwrangler97 is offline
post #96 of 823 Old 12-19-2013, 01:17 PM Thread Starter
Thomahawk
2006 XK Commander
^^^Cool, lots of Norwegian settled over in Amerika wish i had your gas prices
Got check gauge light,
P0523 Oil Pressure Sensor
High Oil pressure sensor input above acceptable voltage.
What to do? New oil pressure sensor?
Buildthread
post #97 of 823 Old 12-19-2013, 02:45 PM
ZB_WJ
I've been MIA, didn't know you had a new Jeep! Last I was on here you had just wrecked the last one. Time to catchup opcorn:
I think we all just need a beer. :cheers2: (courtesy of ChrisHager)
This forum is a double edge blade, it's saved me thousands in repairs and cost me thousands in mods
ZB_WJ is offline
post #98 of 823 Old 12-19-2013, 03:20 PM Thread Starter
Thomahawk
2006 XK Commander
Yeah, i am back on track and busy getting the new one into the same flawless condition like the last one, phu, there Are some parts and labour needed.
I just saw your rearend damage, its a shame, hopefully it is repairable, Good luck with The adjuster,,,
Buildthread
post #99 of 823 Old 12-20-2013, 06:22 AM Thread Starter
Thomahawk
2006 XK Commander
Originally Posted by Thomahawk
Got check gauge light, P0523 Oil Pressure Sensor High Oil pressure sensor input above acceptable voltage. What to do? New oil pressure sensor?
Odd thing, checked oil level today cause gauge shows 0 pressure, was alittle above add, clearly it have used some, toped it off and check gauge Went away, and gauge back to normal,,,
Still will replace oil pressure sender, but whats going on, should i be worried?
Anyone?
Buildthread
post #100 of 823 Old 12-20-2013, 08:45 PM
rdkendrick
2003 WJ
Gotta be a bad sensor that doesn't work below a certain pressure. My 4.7HO uses a little oil between changes. 177400 miles.
Sent from my iPad using my fingers
rdkendrick is offline
post #101 of 823 Old 12-21-2013, 12:27 PM
KayCeeJeep
Sending units can be all over the map when they go out, they don't always just quit. I'm betting a new sender and no more issues.
KayCeeJeep is offline
post #102 of 823 Old 12-21-2013, 08:50 PM
Galaxie500LTD
x3, mine came with bad sensor that would suddenly drop to zero + CEL, then be fine, then screw up again. Replaced with a Mopar, one month later it died too. But this time it showed high oil pressure all the time and never fluctuated (which 2001's should do), even with the motor not running it would show pressure. It gave me the same code you had. When I cleared the code by disconnecting the battery, it didn't return, even though the sensor still wasn't working right and still showed high pressure. Luckily my parts guy at the dealership exchanged it for another new one. That one works just fine.
-Nice new Jeep BTW, looking forward to the LIFT
2001 WJ V8 QuadraDrive Stock
1966 Ford Galaxie 500 LTD, 390 CI (6.4L) V8 4V, two door hard top, black on black
Galaxie500LTD is offline
post #103 of 823 Old 12-22-2013, 05:32 AM Thread Starter
Thomahawk
2006 XK Commander
^^^New oil pressure sensor on order, will replace it asap when it arrieves, i really dont like the idea of the dummy gauge, it st up id.
Will do an engine flush and put some Omega 10W-30 in it, it might cure on my tick.
I got everything for the lift now, rear billy's also,
But my mechanic is on holyday until january, so i will wait until then cause of aligment needed, and its so much easier for him with a lift and everything, and for me to Get it back up snd running the same day.
Also waiting for a 40" led light bar,
Exhaust and tuner,
And still lots of parts in my Garage That need mounted, front shackles, diff covers, Stillen brakes,,,,
More to come soooon,,,,,
Buildthread
post #104 of 823 Old 12-24-2013, 12:40 AM
snobrdrkid07
From 99-01 the WJ's used an actual oil pressure sender unit. In the 02-04's the used a "dummy gauge" and if the oil pressure is in a certain range it sits exactly where the last picture shows. I have always wondered if you could swap a real gauge into a newer WJ.
-Michael-
post #105 of 823 Old 12-24-2013, 12:58 PM
KayCeeJeep
I wondered about that too but from what I've been able to find out it won't work. The dummy gauge has two wires from the sending unit and the real one three, so theres a PCM issue from what I understand.
