Jeep in Norway 2th buildt Overland upgrade - Page 33 - JeepForum.com
 10Likes
post #481 of 799 Old 07-13-2014, 01:19 PM Thread Starter
Thomahawk
Rain stopped, sneaked out again and did a rear wiper delete, its useless anyway, and looks better without IMO.
Buildthread
Thomahawk is offline
post #482 of 799 Old 07-14-2014, 05:01 AM Thread Starter
Thomahawk
Auch still have a water leak, carpet is soaked again on driver side foot well, after heavy rain tonight, leaving me with sunroof, or windshield as possible causes.
Did some duct tape on windshield trim, then if it still leak, it must be sunroof, if not, windshield,,,,
Buildthread
post #483 of 799 Old 07-14-2014, 02:15 PM
rdkendrick
2003 WJ
Originally Posted by Thomahawk View Post
Auch still have a water leak, carpet is soaked again on driver side foot well, after heavy rain tonight, leaving me with sunroof, or windshield as possible causes. Did some duct tape on windshield trim, then if it still leak, it must be sunroof, if not, windshield,,,,
Then it could be driver's side door. Is your weatherstripping sticking out far enough? What I mean, is it crushed, or not.
I had a leak, during the winter, water came in the upper front corner of driver's side door. The problem was a piece of ice had gotten caught when I closed the door, and melted, but before it melted, it let water in.
I only found it, because more water had frozen where it was coming in. Once I cleared it, no more leak.
Sent from my iPad using Electrons
rdkendrick is offline
post #484 of 799 Old 07-14-2014, 04:46 PM Thread Starter
Thomahawk
Started recirc and mid case blend doors repair today, everything went ok, just time consuming, hardest part was to figure out that the main harness was screwed against the back of the main structure duct thingy, i might used a couple xtra hours to understand it.
Once away, i replaced the recirc with a new Mopar piece,
Then i started cutting to replace mid doors,
Got old ones out,
Replaced old foam on center, mid vent housing,
Then it started raining again, will continue reassembly tomorow.
Today i am up to 7-8 hours, knew it would be a BIG operation, but didnt knew it was going to take this much time, anyways, now i am halfways or even more.
Buildthread
post #485 of 799 Old 07-14-2014, 05:35 PM
rdkendrick
2003 WJ
This picture, right here, is a good example of the problem, where people complain they have weak air flow.
It is going out between the foam and unsealed duct.
post #486 of 799 Old 07-14-2014, 06:02 PM Thread Starter
Thomahawk
Originally Posted by rdkendrick
Then it could be driver's side door. Is your weatherstripping sticking out far enough? What I mean, is it crushed, or not. I had a leak, during the winter, water came in the upper front corner of driver's side door. The problem was a piece of ice had gotten caught when I closed the door, and melted, but before it melted, it let water in. I only found it, because more water had frozen where it was coming in. Once I cleared it, no more leak. Sent from my iPad using Electrons
Idk, i am leaning more against windshield or sunroof drain, today i noticed some water on the passanger side to
Will keep looking into it,,,
This picture, right here, is a good example of the problem, where people complain they have weak air flow. It is going out between the foam and unsealed duct. Sent from my iPad using Electrons
Nice i had some speaker foam laying around, hopefully the AC codes, 51 54 55 will be gone soon, and temp stay steady.
Buildthread
post #487 of 799 Old 07-15-2014, 06:00 AM Thread Starter
Thomahawk
Continued the blend door project today,
Got cut edge cleaned up, everything vacumed out real good, installed inner and outer door,
Conected ACZ unit, did reset and calibration procedure, recheck for codes,
No shows 0
Did some extra patching to cover the axcess hole,,,
Now everything just need to come back together again.
Buildthread
post #488 of 799 Old 07-15-2014, 09:13 AM
rdkendrick
2003 WJ
I hope that duct tape holds. Did you put the piece that you cut out, back in? I would have used the silver HVAC tape. It comes with the Blendor kit. If you still have it open, you might consider it.
According to the instructions in my Blendor kit, you make the cut, remove the screw on the bottom, and remove the cut piece.
(See attached picture)
It fits back on the bottom, on a groove, and the screw holds the bottom piece pretty firmly. Then, you tape the rest with the silver HVAC tape, that came with the Blendor kit.
post #489 of 799 Old 07-15-2014, 11:28 AM Thread Starter
Thomahawk
Nah, i used the patch stickers that came with the Mopar kit first, then Xtra patched it with duct tape, will hold up, no stress.
And stil no longer open, dash assembly finished, phu
Buildthread
post #490 of 799 Old 07-15-2014, 02:03 PM Thread Starter
Thomahawk
Small break due to heavy rain, sneaked out again, then i vacumed everything real good,
Threw out the factory AMP to make room for more AMP.
Found a suspecious water drop inside door trim here, might be my leak, here>>>
Also lots of sh and debrise inside the door trim gap here>>>
Cleaned out all for doors inside the door trim gap,
Cleaned out my sunroof rails, rubber edge, and lubed it all up again with Graphite grease,,,
Thats all for today folks
Buildthread
post #491 of 799 Old 07-16-2014, 05:30 PM Thread Starter
Thomahawk
Just a small amount of work done today,
Got RCA's, ground, remote power, and USB cables routed from HU, threw center consol, under carpet, to under backseat.
USB in center consol,
Also prepared under backseat for new bigger AMP's by cutting away factory bolts.
Stay tuned, more to come soon
Buildthread
post #492 of 799 Old 07-17-2014, 04:01 PM Thread Starter
Thomahawk
Another small amount of pre audio work today,
Sanded down,
and made a good ground terminal for the AMP under rear seat,
Drilled holes thrue the under seat metal panel, for aux/RCA etc, extra patched the cables with duct tape, where it goes thrue the metal sheet.
Got all wires needed now, everything lines up nice, soon to hook things up, and start enjoy the work
Buildthread
post #493 of 799 Old 07-18-2014, 11:25 AM Thread Starter
Thomahawk
Another WJ Followed me and my Buddy Leif back to our personal junkyard,,,
Its a 2001 limited 4.7 Quadradrive, blown engine
It was a steal of a deal, plan is to take engine from our low milage parts Jeep, and Get it back on the roads again, off course its going for sale.
First parts Jeep is very soon ready to go to the metal crusher, ha ha, didnt save much, lol
Buildthread
post #494 of 799 Old 07-31-2014, 03:56 PM Thread Starter
Thomahawk
Did some Work with my Jeep Buddy Leffy today,
Engine/trans is now ready to be pulled out of the green parts Jeep,
And start its new life in the golden one,
Which wee also started disassembly front end today,
Good progress, only thing that dont match up is that they got different fan setup, but i think it will be ok to just pull the viscous fan off the 00 engine, and use the 01 fan set up, right?
Boneyard
Buildthread
post #495 of 799 Old 08-04-2014, 05:53 PM Thread Starter
Thomahawk
Hmmmm, ha ha ha
Buildthread
