Jeep in Norway 2th buildt Overland upgrade - Page 16 - JeepForum.com
 10Likes
post #226 of 806 Old 02-10-2014, 07:44 PM
JeepNowski
Thomahawk....Would you mind (because I am too lazy to go back through 15 pages of this post) and tell me the current set up you are running as far as lift, tire size, wheel size? PLEASE??
Thank you in advance. Also, I love what you are doing with your new WJ. Yes they are expensive to get where you want, but I appreciate what you are able to do with yours.
Mine is an '04 Limited with the regular 4.7 and is all stock. Just got a set of A/T tires for it 245/65/r17 Cooper Discoverer ATPs. Not the greatest tire in the world but I've used this brand since I started driving 20+ years ago and haven't ever had a bad set of coopers except for the cooper mudders I had on my work truck a few years ago.
Anyway, I'm just now finally starting to get my WJ to where I want it like you are but I suspect my desires are less than yours. I don't need/want the HO bulbs and projectors and non-stock wheels....But I would like my WJ to look something like what yours looks like. You've got a good looking truck there.
JeepNowski is offline
post #227 of 806 Old 02-11-2014, 01:36 AM Thread Starter
Thomahawk
I wouldnt mind, when you compliment my Jeep the Way you do, here is my setup for ya.
2"BDS coils,
New Coil isolators,
Bilstein 5100 shocks,
Addco front swaybar W/JKS QD endlinks,
Addco rear swaybar W/IRO ext endlinks,
IRO rear sway bar spacers,
JKS trackbar, KOR TB bushings,
Moog super trial boss SS.
Procomp 17X9" 4.75"bs
GGAT2 255/70/17 31's
My motivation for doing this again is to Get the new one in the same state of condition and moded like the still highly missed green one.
I know they Are common over there, but over here GC's Are rare, and usually bone stock.
Which goes without saying, my Jeep is 1 of around here.
Also you guys here at JF, helps me out a lot, keeps me motivated, and help me figure out solutions to problems. I really couldnt do it without your help and support.
The Jeep addiction is a great thing,
sure i got hit hard by That bug, but i love it
As for funds, the green Jeep still pays for the new one, no more funds added into the new project than the old one got me back.
And as you all know, i just empty every pocket on the first one, thats how we roll.
Thx again and stay tuned, more parts'n upgrades will come soon.
Buildthread
Thomahawk is offline
post #228 of 806 Old 02-13-2014, 10:35 AM Thread Starter
Thomahawk
More parts orderd the last days,
Moog coil isolators, to see if i Get back some lift height, suspect the crowns to be compressed already, or its the BDS coil itself. And i might end up with 3" springs to make the 31's useble.
And mid-case blend assembly, and the recirc blend assembly, to Fix my AZC codes 51, 54, 55 later down the road, when i Get more important things of my list.
Buildthread
post #229 of 806 Old 02-13-2014, 06:37 PM
JeepNowski
You must be independently wealthy LOL because I couldn't come close to spending the $$$ you do on my WJ.....Of course, I don't have the bug as bad as you appear to and I've got quite a few children and a wife I have to consider before purchasing all my stuff LOL
post #230 of 806 Old 02-14-2014, 01:51 AM Thread Starter
Thomahawk
Nah, it might seems That Way, but its just our crazy economy that didnt Get hit in 08.
I have about 5-6k USD left from the green Jeep payout and parting out, still after all mods, repairs and upgrades done to the new one.
Parting out the old green one and an old ZJ, made this money, also selling factory wheels and other stuff i dont need any more, brings in some more funds too.
What the Jeep takes, the Jeep have to pay back.
You are righ, i got no wife or kids to support,
but i got many addictions,,,, ZJ 5.2 project, a 08 Buell, and a 73 ironhorse sportster project to, so my parts acount Are bleeding for sure, lol
The WJ Are my no 1 priority anyway
Stay tuned, more $ to spend (shhh) more upgrades to come!!!
Changed my signature to reflect my current situation.
Buildthread
post #231 of 806 Old 02-15-2014, 07:57 AM Thread Starter
Thomahawk
Replaced driver side lifters today.
Small write up on request:
-Submerge new lifters in engine oil overnight.
-Disconect negative battery terminal.
-Position gear in Neutral.
-Remove air intake to Throttle body.
-Unplug wireing harness from coils, injectors, and the 3 other ones going to alternator area, and 3 from TB,
-Pull harness away from valve cover to make axcess.
-Remove valve cover, make notice off where the studs Are located.
-Only rockers with cam lobe pointing away from rocker is removeble, pull the ones thats in the correct cam position and replace lifter.
-Rocker arm going out toward its narrow end, Push rocker arm back into place again, after inspected both contact end for wear and roller for damage.
-Turn crank, repeat until all 8 Are done.
-Make sure all rocker arms and lifters (if reused) come back to each own same spot. DO NOT MIX UP!
-Reassemblie in reverse order.
All Went well back together and lifters was replaced sucsesfully,
Still didnt cure my tick
More to come about that,,,,
Buildthread
post #232 of 806 Old 02-15-2014, 08:29 AM Thread Starter
Thomahawk
Ok guys, help needed!!!???
When i pulled the rocker arms i noticed some play between the camlobe itself and the cam???
This was worst at either cylinder 3 or 5, see drawing,
on the ones i marked 1, which was the first one i pulled.
Then i found very very small play on the 5/7 cylinder, rockers marked 2.
And then nothing, no play in cam/camlobe, in none of the remaing cylinders, valve sets.
BIG QUESTION??
Can my tick be related to play in camlobe for each revolution it goes around, loosing and building up tensionen when lobe turns valves, its not like one solid piece, the lobes Are pressed on the cam shaft or something.
Anyone???
Buildthread
post #233 of 806 Old 02-15-2014, 11:04 AM Thread Starter
Thomahawk
Came across this "The 4.7 motor in case you did know, has a hollow camshaft. Thats means the cam lobe can rotate and cause a misfire"
Here>>>http://m.dodgeforum.com/forum/showth...ge=3&styleid=5
Interesting and freightning,,,
Buildthread
post #234 of 806 Old 02-15-2014, 11:10 AM
Irishgrimm
Thomahawk, love the WJ and thread so far! I also appreciate the details as I am doing a build of my own. It's a WJ SRT8 clone so quite a bit different than yours but none the less we share some quirks, mainly the blend door codes 54,56. I got a blend door kit from Amazon for $60 and did the repair without tearing the dash apart so if you need and tips let me know, it only took about 1.5 hours. I also just repaired the driver's side exhaust manifold as it seems a common issue for the bolts to break. That's where my engine tick came from especially on cold starts and acceleration. Not sure if you mentioned that you ruled that out for your tick problem yet? I was lucky and the manifold itself wasn't warped so it was just bolts and gasket + labor $150 total. Well keep up the good work and check mine out if you get a chance... you might recognize the color!
http://www.jeepforum.com/forum/f22/2...build-2108553/
2000 WJ Limited, Shale Green Metallic - Current SRT8 Clone project
2001 WJ Anniversary Edition, Silver Metallic - Traded in for wife's new Honda...
1996 XJ Country, Dark Green Pearl, 4'' Rancho, 33'' Cepeks - Sold
1991 YJ Sport, Black, 4'' Skyjacker, 33'' Cepeks - Blown Engine and Parted out
Irishgrimm is offline
post #235 of 806 Old 02-15-2014, 11:43 AM Thread Starter
Thomahawk
^^^Awsome, Nice buildt you got going there, That will be one H of a WJ!!!
Like what i see so far, my last WJ started at 20's still like That look for a street Jeep, also those SRT8 rims Are sure Nice.
Pretty sure it aint the famous exhaust tick,
deff more of a cam lifter related sound, i guess, we will see.
Ordered the Mopar mid case and recirc blend door kit, but will be awhile before i will Get to do that one.
Buildthread
post #236 of 806 Old 02-15-2014, 05:14 PM Thread Starter
Thomahawk
Gonna try this two,
http://www.wynnoil.co.uk/products-wy...lve-lifter.htm
Goes into oil and stays until next oil change,,, And this, http://www.wynnoil.co.uk/products-wy...em-cleaner.htm
Oil flush do use before engine oil change.
Buildthread
post #237 of 806 Old 02-15-2014, 05:38 PM
JeepNowski
Posted in another thread, but have you ever given your WJ a Seafoam treatment? I've heard a lot here on this forum and personally from mechanic friends who love this stuff and say it really does do what it says it does.
1/3 of a can into the gas tank, 1/3 of a can into the engine oil, and 1/3 of a can to suck up through a vac hose from the brake booster. If you haven't done this yet, google a video of WJ seafoam treatment. Also it makes LOTS of smoke when you suck it up through the vac hose LOL
post #238 of 806 Old 02-15-2014, 05:52 PM Thread Starter
Thomahawk
Yeah i know about seafoam, isnt availeble over here, but might order some of That shhh to, couldnt hurt, and gets great reviews though.
Buildthread
post #239 of 806 Old 02-15-2014, 07:52 PM
JeepNowski
I figured you had but I wasn't 100% sure.....and I didn't know about it's availability over there.
Well at any rate, good luck on figuring out the exact cause of, and subsequent fixing of the tick. I'm rooting for ya.
post #240 of 806 Old 02-16-2014, 09:43 AM Thread Starter
Thomahawk
Got front diff fluid and BTF cover done today,
Pulled old cover and drained fluid, looked ok, not to bad
Cleaned out gears and diff housing with brake cleaner, inspected magnet, no excessive metal going on, and gears looked ok, no visible wear or tear.
Used a lubelocker for the first time, really great product
Got BTF cover mounted,
And refilled with Redline 75W-140, no Mopar FM needed
Buildthread
