Jeep in Norway 2th buildt Overland upgrade - Page 11 - JeepForum.com
 10Likes
post #151 of 801 Old 01-11-2014, 05:59 AM
Pierre_r
1989 XJ Cherokee
About the tick noise.
Have you checked the bolts to the flexplate?
On my XJ they came loose once and made almost the exact same sound.
Pierre_r is offline
post #152 of 801 Old 01-11-2014, 07:50 AM Thread Starter
Thomahawk
Originally Posted by Pierre_r
About the tick noise. Have you checked the bolts to the flexplate? On my XJ they came loose once and made almost the exact same sound.
Havent checked That no, but Should the tick Go with the rpm of the engine, if its the flexplate?
Buildthread
Thomahawk is offline
post #153 of 801 Old 01-11-2014, 08:12 AM Thread Starter
Thomahawk
Got first snow today
Buildthread
post #154 of 801 Old 01-11-2014, 08:18 AM Thread Starter
Thomahawk
Washed the salt off, Jeep sure did come a long Way in those 7 weeks since i bought it. Name:  image-2527151485.jpg
Size:  378.9 KB Name:  image-1502530543.jpg
Size:  374.8 KB Name:  image-403151933.jpg
Size:  367.5 KB Name:  image-1124048982.jpg
Size:  358.5 KB Name:  image-3792251349.jpg
Size:  376.3 KB Name:  image-408298389.jpg
Size:  350.5 KB Name:  image-823501815.jpg
Size:  285.6 KB Name:  image-4200500710.jpg
Getting there step by step
And i have shop floor time to pull valve cover and inspect rocker arms and lifters tomorow.
Buildthread
post #155 of 801 Old 01-11-2014, 09:05 AM
Hytek
Looks good man nice job!
98 5.9 Limited - IRO 3.5", IRO short arms track bars Bilsteins, Addco, JK wheels, 255-75/17 BFG, Magnaflow, Flowmaster
04 Limited 4.7H.O QD, UC+BB, Bilsteins, 245/75-16 Duratracs Addco sway bar
Hytek is offline
post #156 of 801 Old 01-11-2014, 01:20 PM
JeepNowski
That makes it very tempting for me to go with the blacked out look. I've still got a long way to go with mine, in fact...ALL the way. I just haven't had the money to spend on improvements since I bought it.
JeepNowski is offline
post #157 of 801 Old 01-11-2014, 01:58 PM Thread Starter
Thomahawk
Thx man, its getting there
Blacked out is the Way to Go, Black wheels to come, glad i had all those parts in my garage, or it would get expensive, again, lol
Do it slowly mod by mod
Buildthread
post #158 of 801 Old 01-12-2014, 08:26 AM Thread Starter
Thomahawk
Update,
Pulled valve cover today, heads do look very clean and not gunked up atleast
Cam lobes looks normal,
Timing chain looked good,
Pulled one rocker arm and a lash adjuster/lifter to check/inspect wear and function,
Rocker arm look ok, but roller wheel have side ways play, idk if That is normal?
Lifter Are seized up, cant Get it moving, guess they all the same, so i will replace them all rather than cleaning/fixing all 16 of them.
Everything back together again, now to order parts.
Buildthread
post #159 of 801 Old 01-12-2014, 03:25 PM
rdkendrick
2003 WJ
If the lifter is seized, wouldn't you be getting a miss?
Sent from my iPad using my fingers
rdkendrick is offline
post #160 of 801 Old 01-12-2014, 03:48 PM Thread Starter
Thomahawk
Idk by now,,,
One mechanic, and one other very Mechanical skilled friend, the stetoscop guys, says top end right side lifter/cam noise like sound.
Rockers and cam lobes look fine, no abnormal wear, so that leaves me to lifters, engine also looks very clean, deff not gunked up, and problebly maintained ok.
Since lots of others 4.7 owners had problems with lifters and throwing rockers i will try this, if not rebuildt top end, front end, bottom end, engine swap most likely, whatever,,, flyes thrue my mind, very very expensive routes,
It could be conecting rod, slipping piston at top end in head, but id think/hope so.
So i guess i will give this it a try, or any got some other very Good suggestions?
Buildthread
post #161 of 801 Old 01-12-2014, 03:56 PM
rdkendrick
2003 WJ
Originally Posted by Thomahawk View Post
Idk by now,,, One mechanic, and one other very Mechanical skilled friend, the stetoscop guys, says top end right side lifter/cam noise like sound. Rockers and cam lobes look fine, no abnormal wear, so that leaves me to lifters, engine also looks very clean, deff not gunked up, and problebly maintained ok. Since lots of others 4.7 owners had problems with lifters and throwing rockers i will try this, if not rebuildt top end, front end, bottom end, engine swap most likely, whatever,,, flyes thrue my mind, very very expensive routes, It could be conecting rod, slipping piston at top end in head, but id think/hope so. So i guess i will give this it a try, or any got some other very Good suggestions?
What if you don't do anything? Is it a noise you can live with? I know mine ticks just a little. I figure it's just the wear from having 178k on the odo.
post #162 of 801 Old 01-12-2014, 04:42 PM Thread Starter
Thomahawk
Originally Posted by rdkendrick
What if you don't do anything? Is it a noise you can live with? I know mine ticks just a little. I figure it's just the wear from having 178k on the odo. Sent from my iPad using my fingers
Have you heard the tick on my video?
My tick is not just a little one,
No i cant live with metal pieces slapping into each other inside my engine, its heartbreaking and at the end somewhere down the road, eventualy something major will blow, driving around waiting for that is like sitting on a ticking bomb, not very confortble.
Buildthread
post #163 of 801 Old 01-12-2014, 06:35 PM
rdkendrick
2003 WJ
Have you heard the tick on my video? My tick is not just a little one, No i cant live with metal pieces slapping into each other inside my engine, its heartbreaking and at the end somewhere down the road, eventualy something major will blow, driving around waiting for that is like sitting on a ticking bomb, not very confortble.
I watched the DYI YouTube video on your other thread and I take it back. Now I am hoping I don't have any seized lifters. I don't have any loud ticks. I watched your video and it DOES sound like the rear driver's side. I hope new lifters solves your problem. it doesn't look very hard to do.
post #164 of 801 Old 01-13-2014, 03:14 AM Thread Starter
Thomahawk
I watched the DYI YouTube video on your other thread and I take it back. Now I am hoping I don't have any seized lifters. I don't have any loud ticks. I watched your video and it DOES sound like the rear driver's side. I hope new lifters solves your problem. it doesn't look very hard to do. Sent from my iPad using my fingers
Thx man, new lifters on order, now waiting, hopefully this will Fix it, its as much as i want to digg into the engine myself, any further, i might Get someone to do the Job for me, i really need my engine running right, irritates and worries the Hell out of me.
Edit: got some delieveries today,
12qts Mopar ATF+4 Transmission honey,
3qts Redline 75W-140 diff fluid,
Oil pressure sensor,
Right side power and FOLD IN mirror,
BIG THANKS TO michiganmaweric who fixed this Export part out from US stealership.
Buildthread
post #165 of 801 Old 01-16-2014, 07:40 AM Thread Starter
Thomahawk
Recieved more parts today,
Quadratec Window wipe seals
Will save them up for the spring, as the ones i have now aint That bad.
And 4300k headlight bulbs, they first sent me wrong ones, so i now have both 5000k and 4300k to test what color fits the CCFL best.
And, last LED interior light bulbs needed for a complete upgrade.
Buildthread
