Jeep In Norway - Page 78 - JeepForum.com
post #1156 of 1373 Old 05-29-2013, 03:39 PM
snobrdrkid07
snobrdrkid07's Avatar
Did *all* those cracks appear when you started hitting on it? Or did they get worse?
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600s | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100s | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #1157 of 1373 Old 05-29-2013, 03:49 PM Thread Starter
Thomahawk
I am really not 100% sure, might have been there from before, but never noticed any leak around there, and the cracks and leak Are on the one side That i hammered the messel.
So i am to afraid to keep on getting it out, if it cracks totaly i am without my dd.
Buildthread
Thomahawk is offline
post #1158 of 1373 Old 05-29-2013, 05:31 PM
PowderHound
2003 WJ
Try to cut a flat in the drain plug and get it out with a big screwdriver and a channel lock. Then JB weld the cracks until you can get a new housing. It might work...
2003 WJ♦Inferno Red Limited(4.7 H.O., Vari-Lok axles)♦OME HD/BILLY 5100S♦IRO t-case skid, adj. tb, sway links♦Moog SS♦Factory tow package w/harness & tow hooks♦ Amp/12 sub box♦new bad b**ch passenger♦1993 XJ country♦lift/muds/winchbumper-sold♦build thread instead of long A$$ sig soon...
PowderHound is offline
post #1159 of 1373 Old 05-29-2013, 09:44 PM
snobrdrkid07
If it got to that point, I would stop and assess what needs to be done. If you think the back half of the case is done for... might need to take it to a shop for a second opinion. You could replace the back half with the rest of the case still inside the Jeep.
-Michael-
post #1160 of 1373 Old 05-30-2013, 02:43 AM Thread Starter
Thomahawk
Yeah, thats excactly what i am doing right now, rear housing Are discontinuied.
We will see what i end up doing about it.
Buildthread
post #1161 of 1373 Old 05-30-2013, 09:51 AM Thread Starter
Thomahawk
Transmission service today,
Drained and cleaned out of pan and magnet.
WIX filter kit with both filters and gasket + 7qts Mopar ATF+4 Went back in.
This i managed to pull off
Buildthread
post #1162 of 1373 Old 05-30-2013, 10:39 AM
PowderHound
2003 WJ
If the T.C. is toast you might consider the 242 swap...
post #1163 of 1373 Old 06-05-2013, 03:44 AM Thread Starter
Thomahawk
BIG package arrieved today, wow That was BIG, no Wonder why shipping cost an arm and a leg, atleast it made it in one piece, unlike last time.
Thanks Kolak, you saved me huge on this one to
Buildthread
post #1164 of 1373 Old 06-05-2013, 08:58 AM
snobrdrkid07
Ahh I need one of those too!
-Michael-
post #1165 of 1373 Old 06-05-2013, 06:14 PM Thread Starter
Thomahawk
Yeah, the flickering and to low aimed headlights been pissing me off, That aftermarket shhh i bought 2 years ago seemd to SNAP at ALL attachment points, plastic deff was very crispy, the Mopar one has more flex to it or what to say, seems more robust.
Cant wait to Get it replaced and my headlight aimed and sitting correct again.
Deff Will trim front bumper durring the same operation, tires rubs bumper at full lock in reverse how it sits now.
Buildthread
post #1166 of 1373 Old 06-05-2013, 07:58 PM
snobrdrkid07
Mine had been broken for about 7 years now after a slight mishap... snapped a bracket and it was glued back but that isn't working anymore haha. Too lazy to fix and too cheap spend the money. Even though its only like $50 haha
-Michael-
post #1167 of 1373 Old 06-12-2013, 09:37 AM Thread Starter
Thomahawk
Ok, today i finally got to do some Work on my Jeep, cause my summertoy/beater (Buell) broke down and i am waiting for parts.
Replaced the broken brake wire from consol to under rear seats, had to pull AMP's, rear seats, passenger front Seat, and center consol, to Get carpet up and away enough, to unbolt the wire clamp.
Pretty easy, about 2 hours from start to finish with all interior back in and audio hooked up again.
Next up is the headlight support, as soon as my bumper clips arrieves.
Got a letter from goverment, cause i forgot about the every second year EU control, i now have until 31th of July to Get it approved.
Those headlights will need to be aimed correctly to pass That inspection.
I also rerouted the remote and signal Cables from consol to rear seats so now its all gone under carpet
Buildthread
post #1168 of 1373 Old 06-13-2013, 06:10 AM
madslynge87
Hey champ hope everything is good with the Jeep just got my Kolak exhaust and i'm super stoked ! have a question, do u know how long the converter pipe from 2 1/2" to 3" was ?
madslynge87 is offline
post #1169 of 1373 Old 06-13-2013, 12:16 PM Thread Starter
Thomahawk
Awsome, thats Good news, you will deff enjoy it,
i am not really sure but if i remember correct, its about 4-5" long.
Jeep is doing great, try to keep the list of things need to be done, as short as possible, lol
I am not using it to much These days, riding my Buell XB12S is my summer addiction.
Buildthread
post #1170 of 1373 Old 06-14-2013, 01:29 PM Thread Starter
Thomahawk
Pulled front end today, bumper, grill headlights,,,,
To replace the broken headlight support, everything Went back together again and my headlights now sits more perfect and Edge towards fender Lines up better.
Tried to trim my bumper a bit but not enough, still rubs at full lock, will need to trim more,
Also made a new attachment clip for the wheel well plastic to compensate for the ones missing by trimming away the bumper Edge.
image-669379282.jpg   image-269936214.jpg   image-3982774312.jpg   image-928312615.jpg   image-3091196948.jpg
Buildthread
