It's name is 'Black Jeep' - Page 6 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > It's name is 'Black Jeep'
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 01-28-2011, 10:55 PM   #76
PeriwinkleZJ
That's my plan. D44a spartan locked, MCV truss. HP30 WJ knucks, lockright. I'm beginning to gather parts, and look for axles. Unfortunately I'm moving into a new house soon, so most of it will have to wait till I get a pay bump and tax return. D44a should be fine for 33's especially trussed, although many people overlook them because of common bearing failures which the truss should fix by preventing housing flex.
-1993 Grand Cherokee Laredo V8 5.2, Mopar CAI, Borla headers, Borla Y-pipe, Turn down exhaust, 4" RC SA, 33x12.50r15 BfGoodrich Km2, Crown extended brake lines, IRO Double Shear Track bar, IRO HD tie rod, Home made Quick discos, E-fan, Heavy duty harness/9007 bulb conversion, HP30 WJ knuckles lockrite solid cover.
BUILD THREAD:http://www.jeepforum.com/forum/f197/...-jeep-1133312/
PeriwinkleZJ is offline   Reply With Quote Quick reply to this message
Unread 01-28-2011, 10:58 PM   #77
MurdaJs
Originally Posted by SnowLeopard View Post
It sounds to me like you just need to find a 44a from a newer ZJ to swap in. For 33's that should work? Anyone else wanna chime in? My axle knowledge is pretty limited.
The general consensus is that 44a's can take 33s in stock form, trussing makes 35s doable.
A truss is a good idea for anyone who wheels remotely hard regardless on anything above 32s to keep the aluminum housing from flexing
EDIT: Periwinkle beat me
[QUOTE=Marauder_Pilot;33845457]I'd suck an acre of cocks for a nice expo-built Tacoma[/QUOTE]
MurdaJs is offline   Reply With Quote Quick reply to this message
Unread 01-28-2011, 11:03 PM   #78
PeriwinkleZJ
I'm thinking I can do HP30, and D44a locked for under $1000 without touching brakes, bearings, or gears. Ideally I'd like to rebuild them, but probably won't until I have to. Also I'd like to regear to 4.56, but mostly won't until I go to 33's.
Parts I have:
D30 lockright
It'll get bigger I promise.
Unread 01-28-2011, 11:04 PM   #79
SnowLeopard
At least you have the 5.2 With the 4.0 you'd want to regear to run 33's. Heck, I'd like to regear, and I've just got 30's.
Yes, it snows in Texas.
SnowLeopard is offline   Reply With Quote Quick reply to this message
Unread 01-28-2011, 11:10 PM   #80
PeriwinkleZJ
Yeah Periwinkle was a turtle. Black jeep is a damn hare. I found a 2.8 V6 5spd XJ at the junkyard with a vacuum disconnect d30 with 4.56 once. Kick myself for not snatching up those gears when I had the chance.
Unread 01-28-2011, 11:22 PM   #81
SnowLeopard
I know the feeling. I went to the local yard after work, knowing there were a couple things off a ZJ I wanted to snag last time I was there. It was all stripped. I should've known better. Jeep stuff just doesn't last in yards. Better luck next time, I suppose. If you need a gas tank skid though, they have one. Though you're in VA. Shipping is high considering the weight.
Unread 01-28-2011, 11:26 PM   #82
PeriwinkleZJ
I still have periwinkle lurking in my stepdads back yard. It still has the gas tank skid. I need a Tcase skid though next time I hit the local JY. I cracked my 242 last time I went wheeling, definetly don't want it to happen again. I'd rather get hung up.
Unread 01-28-2011, 11:33 PM   #83
SnowLeopard
They have the T-case skid there, but it's been abused. I ended up buying mine off someone on JF. The one on the ZJ at the yard is so beat up, it looks like someone rammed into a rock or something and just bent it back. The bolts that go into the cross-member are pulled diagnal and show, when they should be flush against it. So it's likely going to require cutting the bolts just to get off. I opted against it as the yard isn't a u-pull-it, and the guys that work there were too lazy to even try to get it off for me. I didn't want to pay for a beat up skid anyway.
Anything on your old Jeep I might want though? You should part the good stuff out and sell it in stock form. Of course, you probably just swapped most of it to the new Jeep.
Unread 01-30-2011, 12:11 AM   #84
PeriwinkleZJ
Yeah almost everything of any use is on my new jeep, otherwise it's a parts jeep for me, my brother, and my moms ZJs. We roll deep Oh yeah, my stepdad has a CJ with fiberglass tub, and D44s. Although, my dad drives a 350z, not sure where I got my jeep genes from haha.
Unread 01-31-2011, 11:06 PM   #85
PeriwinkleZJ
Got it inspected finally. The D35 is making a howl, I assume a bad bearing of some sort. After I get this house I'll be prowling the local JY for a D44a. The rebuild kit from AAP is only $75 without my discount, and commercial hook up so I may just go ahead and do it while it's out.
Unread 01-31-2011, 11:08 PM   #86
HaViiK
The junkyard here in Lynchburg has WJ 44a's for about 300! Want me too look at the pick n save and see what they got? I may be there saturday.
Check my build btw...I left a comment to you!
[SIZE="2"][COLOR="DarkRed"]Steven, New HaViiK[/COLOR][/SIZE]
[URL="http://www.jeepforum.com/forum/f197/haviiks-01-wj-slow-build-1067820/"][COLOR="DarkRed"]Black HaViiK:[/COLOR][/URL] [COLOR="DarkRed"]2001 WJ, 4.0, 42re (rebuilt at 100k), 30/35, Rough Country X-Series, JCR Stage 3 Sliders, Yakima Megawarrior & Big Powderhound, Grille Guard, KC Daylighter 130w, Custom Sub Box & 2 Kicker 12" CVR
[/COLOR]
[SIZE="2"][URL="http://www.jeepforum.com/forum/f13/zj-wj-faqs-read-first-contact-mod-changes-additions-591821/"][COLOR="DarkRed"]WJ/ZJ FAQ[/COLOR][/URL][/SIZE]
[SIZE="2"][URL="http://www.facebook.com/steven.T.wright"][COLOR="DarkRed"]Facebook. Wheeling stuff in there.[/COLOR][/URL][/SIZE]
[SIZE="2"][URL="http://www.youtube.com/user/Thunderheadrcx?feature=mhee"][COLOR="DarkRed"]Youtube Channel. GoPro/Wheeling stuff[/COLOR][/URL][/SIZE]
[QUOTE=rulppa(chat);10944366]whats with people (steve) with those monster sigs. reply is usually like ':E' then 2 pages of signature lol[/QUOTE]
[QUOTE=Sarahdactyl;11226293]THE WINNER IS REDHOTCHILIDOG!!!!111!!1!!!!(OBNXIOUS HUGE BEEFSTEW STYLE FONT) I will PM winner for details[/QUOTE]
HaViiK is offline   Reply With Quote Quick reply to this message
Unread 01-31-2011, 11:13 PM   #87
PeriwinkleZJ
I haven't gone to the JYs here in a while, but the PNS has had a steady flow of a dub or two. The other JY here has started to get them too. It's going to be a little bit since I'm shelling out like a grand to move into my new house. Tax returns for sure
Unread 01-31-2011, 11:24 PM   #88
HaViiK
Ballinn. The PNS here has one WJ and it caught fire. Nothing good at all.
[/COLOR]
Unread 02-01-2011, 12:01 AM   #89
PeriwinkleZJ
I hate that, when the one vehicle you need things off of is charred up, and useless. What a tease...
Unread 02-03-2011, 08:46 PM   #90
PeriwinkleZJ
I went to the local JY here and spent about 4 hours rumagiung around with my little brother Nathan (1stZJ), my friend patrick with a YJ on 35's, and my girlfriend. I didn't get anything for the ZJ. Everything I want (D44a, HP30,NP242) cost $100-$150 so since I plan on moving into my own house in a week or two it was out of the question :thumbsdown: Nathan pulled an old CJ mail truck grill and lights though so I plan on making it into mancave art by dremeling the back of the headlights out and replacing it with regular 110V lights for a badass hanging lamp thing.
