It's name is 'Black Jeep' - Page 11 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > It's name is 'Black Jeep'
WIN a Rough Country Forged Track Bar - ExtremeTerrain!FREE, FREE, FREE EVENT!! Save big on Lockers now till ApriJKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6
Unread 04-19-2011, 11:27 PM   #151
PeriwinkleZJ
Just bought a membership Thinking about changing my user name since periwinkle is gone, not sure what it would be so periwinkle stays for now.
-1993 Grand Cherokee Laredo V8 5.2, Mopar CAI, Borla headers, Borla Y-pipe, Turn down exhaust, 4" RC SA, 33x12.50r15 BfGoodrich Km2, Crown extended brake lines, IRO Double Shear Track bar, IRO HD tie rod, Home made Quick discos, E-fan, Heavy duty harness/9007 bulb conversion, HP30 WJ knuckles lockrite solid cover.
BUILD THREAD:http://www.jeepforum.com/forum/f197/...-jeep-1133312/
PeriwinkleZJ is offline   Reply With Quote Quick reply to this message
Unread 04-20-2011, 12:23 AM   #152
1stblack97ZJ
How about "the man formerly known as periwinkleZJ"
1997 ZJ Laredo
4" Lift
32s
Plenty of lights
1stblack97ZJ is offline   Reply With Quote Quick reply to this message
Unread 04-20-2011, 12:31 AM   #153
PeriwinkleZJ
I think we have a winner!! Not sure if I can hae that many characters though..damnit!!
Unread 04-20-2011, 01:40 AM   #154
PeriwinkleZJ
I can't sleep, and I've been pricing things for the HP30 so I'm going to keep track of websites, prices, and a grand total of what all I need to get to finish the swap.
-IRO internal Truss: http://www.ironrockoffroad.com/Merch...egory_Code=PFZ $150
-Goferit Flip inserts: http://www.goferitoffroad.com/products.htm $45
-Solid Differential Cover: http://www.polyperformance.com/shop/...gn=4X4products $65
-OTK track bar bracket: http://www.jcroffroad.com/Merchant2/...tegory_Code=S6 $50
-Hub spacers: http://www.jeeperz-creeperz.com/flan...er-p-4489.html $36
-Lower Control arm skids: http://rustysoffroad.com/mm5/merchan...gory_Code=ARMS $24
Plus rotors, pads, and balljoints which I'm confident I can get for less than $200
Grand Total: ~$600
This isn't including shipping, taxes, cost of welding spacers and brackets, fluids, or any odds and ends. I'm sure when it's all said and done it will be around $800+.
Unread 04-20-2011, 05:47 PM   #155
PeriwinkleZJ
Just paid for a hughes racing plenum repair kit for $90 from a member. Hopefully it will ship tomorrow. Also checking out an 8.8 3.73 LSD with discs for $125 locally friday.
Unread 04-22-2011, 08:05 PM   #156
PeriwinkleZJ
Picked up 2 stock t-case skids, one for me, and one for my brother. Anyone know how to mount these things up when they weren't on there to begin with?
Unread 04-23-2011, 05:27 PM   #157
Spike300
There might be nuts welded to the inside of the frame rail, not sure which holes but that how mine was mounted till the nuts broke off when i tried to take the bolts out to drop my tcase.
[url]http://www.jeepforum.com/forum/f197/camo-beast-975063/[/url]
5.2-242 tcase-44a-30x9.50x15 MT/R-American Racing Burst Rims -[COLOR="Red"]Optima[/COLOR] -E3 plugs-[COLOR="DarkGreen"]Cu[/COLOR]st[COLOR="DarkGreen"]om[/COLOR] Pa[COLOR="DarkGreen"]in[/COLOR]t-Amsoil-Addco Front and Rear-polyurethane bushings
[B]To be installed[/B]: RE gen2 discos, military battery terminals
[B]To be rebuilt:[/B] HP30
[B]To be received:[/B]
[B]To be paid for:[/B]
[B]Next on the list:[/B] complete redo of brakes and
lines
[B]Needed:[/B] fittings, coil of brake tubing, Russel speed bleeders
Zombie Outbreak Response Unit #75
Spike300 is offline   Reply With Quote Quick reply to this message
Unread 04-27-2011, 08:07 PM   #158
PeriwinkleZJ
There are no nuts welded to the frame. Stock there are these stupid nut things, but I wasn't going to pay a **** ton for 6 from the dealer. Just picked up 6 m10x1.5 with lock washers. Fished the nut and lock washer in to the frame with a magnet, and hand tightened it down till the lock washer caught then it snugged up just fine with the ratchet. Same thing on crossmember but we fished the nuts and lock washers in from the exposed sides of the corssmember, and held it steady after starting the threads with a finger through the top holes. Everything snugged up great on nates, we haven't done mine yet. I also got my hughes racing plenum kit today!
Unread 04-27-2011, 08:48 PM   #159
1stblack97ZJ
yeah thats basically how I did mine. It sucked.
1997 ZJ Laredo
4" Lift
32s
Plenty of lights
Unread 04-27-2011, 08:55 PM   #160
SnowLeopard
Magnets, I never thought of doing that. I managed to get a bolt into the frame and dropped it down so I could tighten up a nut to it, but at some point I couldn't keep it in place so I was just turning both the nut and bolt in the frame. By then it was fairly tight, and I was stuck. It's not loosened any since last summer when I did it, but if I ever need to get it out, I will be screwed. LOL I like the lock washer idea. I wish I'd thought of it. Where were you last year when I was asking for suggestions?
Yes, it snows in Texas.
SnowLeopard is offline   Reply With Quote Quick reply to this message
Unread 04-27-2011, 09:00 PM   #161
1stblack97ZJ
I stuck adjustable wrenches down the crossmember to keep the nuts in place.
for the frame, i cut a breaker bar and stuck it up the bigger hole about 5 inches down got it all positioned and tightened it up. I just left the breaker bar and socket up there.
1997 ZJ Laredo
4" Lift
32s
Plenty of lights
Unread 04-28-2011, 12:11 PM   #162
1stZJ
With the lock washers it to us like 15 min to do all three sides and mines up there good and tight
[url]http://www.jeepforum.com/forum/f197/1stzj-build-thread-986545/[/url]
[CENTER][B][SIZE="1"]I can't save burning babies in the surf, I has asthma :([/SIZE][/B][/CENTER]
1stZJ is offline   Reply With Quote Quick reply to this message
Unread 04-28-2011, 12:32 PM   #163
1stblack97ZJ
wish I woulda thought of using lock washers.
1997 ZJ Laredo
4" Lift
32s
Plenty of lights
Unread 05-07-2011, 10:32 PM   #164
PeriwinkleZJ
I can't get my frame side with my bulky magnet it keeps sticking to the sides. I need to use the one we used on Nates.
I can't believe the magnet thing, and lock washer thing worked. Nothing I do EVER works, but all we did was hold the nut with my finger till the lock washer caught then it tightened right up. For the frame the magnet held it enough to tighten down till the washer grabbed. It was to a miracle that it actually worked.
Unread 05-07-2011, 10:40 PM   #165
1stblack97ZJ
Those magnets are damn pesky.
1997 ZJ Laredo
4" Lift
32s
Plenty of lights
