-   Grand Cherokee General Discussion (http://www.jeepforum.com/forum/f197/)
-   -   ISUzj Build Thread (http://www.jeepforum.com/forum/f197/isuzj-build-thread-751883/)
ISUzj 04-12-2009 05:55 PM
ISUzj Build Thread
Well, I think that I have done enough to create a build thread so I can show off what I have put into my ZJ. Dang proud of how far it has come in the last years. I have had it for 4 years now, but the majority of the changes have come since stumbling upon JF and realizing the infinite possibilities of these Grand Cherokees.
Bone stock 4 years ago I was a Sr. in H.S., 107400 miles, 5.2L V8, 249 T-case, Mopar stock spare tire carrier, and Mopar running boards. Radiant Fire KRC red. Stock rims, Bald liberator tires.
http://lh6.ggpht.com/_gM4XB39aOP8/SP...0/107_0755.JPG
I then decided on my own I needed a roof rack and a grill guard/brush guard. So I went to work building them out of what I could find in the shop. The gaurd is made from DOM steel tube that was from my uncle who owns a farm equipment repair shop, the center parts of it are actually the blade from a road maintainer. This is a heavy grille guard but it is held on by two posts welded to the uni body and held by grade 3 bolts so they have some give in case of a collision. It weighs oh about 60 lbs I have bounced off a couple of things and suffered no damage and it has been useful for pushing ppl int he Iowa winters, I have a strip of rubber on each of the vertical plates. http://lh5.ggpht.com/_gM4XB39aOP8/Se...0/100_1595.JPG
http://lh3.ggpht.com/_gM4XB39aOP8/Se...0/100_1596.JPG
As for my roof rack, that is made from a combination of cattle fencing and a ton of steel tubing that comes from the top of overhead doors(my dad installs them for a living) and it is 1" tubing and can be bent with a conduit bender. Use what you got I guess. It hold a ton of stuff, and my 5 dollar a piece tractor lights do pretty good. It secures to the rack by a couple of 5/16 bolts through the crossmembers on the roof.
http://lh5.ggpht.com/_gM4XB39aOP8/Se...0/100_1594.JPG
This is what it roughly was then for about a year and a half. I had to update my tires because my other ones were shot. Good tires, just a little too small :teehee: really dare I say, Kinda Fugly looking.... :brickwall:
http://lh6.ggpht.com/_gM4XB39aOP8/Se...0/100_0828.JPG
After I discovered JF, I got the bug to lift it, but since the place I was living didn't allow me to really work on it in the parking lot I tired to do the o'l 249~242 swap...but it was an udder failure. We had PARTS all over, I had gotten a 242 from a 02' liberty, which was way wrong for my 94:rtft:. But we tried and to no avail, 12 hours later we realized it wasn't going to work. I thought I had pics. but why post failure pics. A new 242 from a 94 is on its way and will be in shortly. I did get a cold air intake on the 5.2, help it breathe a little better, 70 bucks on eBay.
So once I got situated into a place where i was able to wrench on it (house with a garage) I decided it was time for a 2.25 BB after lots of research and some :newbie: questions. sorry, Kinda crappy picture. Thanks to all who put up with a dumb question from time to time from me.
http://lh6.ggpht.com/_gM4XB39aOP8/SM...0/100_1138.JPG
I got the shocks with it (Skyjacker hydro 7000) the bushings fell apart in my hand, I ended up going to advanced and cutting down some of the standard ones they had on the shelves. The ride wasn't all that smooth either, I am hopping to find some better replacements in the future. But they were better than my old stock ones.
http://lh6.ggpht.com/_gM4XB39aOP8/SM...0/100_1139.JPG
Ended up going ahead and selling my old tires and getting different rims (American Racing Baja)painting them black, and getting a hold of some 31-10.50-15 Treadwrights: BF Goodrich AllTerrain T/A I am very pleased with them, they have been great. I even got another one because I found a crack I was not 100% sure about. they have great customer service.
http://lh5.ggpht.com/_gM4XB39aOP8/Se...0/100_1175.JPG
After getting that, decided I needed a different bumper, only because I went playing on some rock piles once I got my new tires to test them out. Apparently I am as not as nimble with my jeep as I thought I was and tore my old bumper off, why not? that's a good enough reason to get a new bumper. So I started and designed one on Solidworks and built it in my garage.
Here is the thread for the bumper:
http://www.jeepforum.com/forum/f37/rear-bumper-zj-627663/
It was this:
http://lh3.ggpht.com/_gM4XB39aOP8/SX...0/100_1291.JPG
I ran into weight issues on the bumper and tire carrier, I am in the middle of a redesign. The tire carrier was causing a twist in the bumper, I need to find a better way to get it attached to the "frame" of the jeep to get a little more support. I just re coated it this weekend with an additional 2 layers of Hurculier So here is it in its current state: I sprayed it with Krylon after it dried to see if that works as a UV protector...if not, I'll buy the protector
http://lh3.ggpht.com/_gM4XB39aOP8/Se...0/100_1591.JPG
ISUzj 04-12-2009 05:56 PM
Snow wheeling (that is about it for central Iowa....):p
http://lh3.ggpht.com/_gM4XB39aOP8/Se...0/100_1348.JPG
So after some time, at Christmas, I gathered enough Christmas money to be able to go just a touch higher. Thanks to suggestions from MoonyJohn, i went and got some 3" coils from Rusty's. But then I had to gather all the other necessities (adj trackbar, swaybar extensions, and such). And I was waiting on a friend to get his strut compressor for his bro to use for the springs. But we had to wait a long time. but in the meantime(3 months) I managed to decide it was worth it to paint m cladding and all of the plastic on my jeep. I took my cladding off and discovered rust, so i repaired that and repainted that. I painted anything black on my jeep black again with either KrylonFusion, or Rustoleum.
http://lh5.ggpht.com/_gM4XB39aOP8/Sd...0/100_1514.JPG
http://lh6.ggpht.com/_gM4XB39aOP8/Sd...0/100_1515.JPG
You can see my complete pic later: Then finally this week everything was ready, I did my HW and we lifted it:cheers:. and actually, since my old springs were sagging so it was more like a 4" lift. so it was a ton higher, me and a buddy started at 4 and were done at 11:00 with the lift.
My old fronts and new ones 4.25" difference
http://lh4.ggpht.com/_gM4XB39aOP8/Sd...2/100_1549.JPG
Once again like everything else, I am cheap/poor, made my own swaybar extensions:
rear:
http://lh3.ggpht.com/_gM4XB39aOP8/Sd...0/100_1552.JPG
Front quick discos:
http://lh4.ggpht.com/_gM4XB39aOP8/Se...2/100_1551.JPG
and the lift: Also painted cladding/mirrors/rails/doorhandles:thumbsup:
http://lh5.ggpht.com/_gM4XB39aOP8/Sd...0/100_1554.JPG
I was feeling ambitious this week wanted to get a lot done, Had leftover hurculiner from my buddy's YJ tub, so i decided that I would go ahead and do my fenders if you look in the pics, they are chipped badly and dented. So I taped it off and began to sand down the paint, hitting out dents as I went.
http://lh6.ggpht.com/_gM4XB39aOP8/Sd...0/100_1556.JPG
Then lined all of the fenders: As well as redid the back bumper because it was in need of an additional layer:
http://lh4.ggpht.com/_gM4XB39aOP8/Sd...0/100_1559.JPG
Extra on the back end:
http://lh3.ggpht.com/_gM4XB39aOP8/Se...0/100_1563.JPG
ISUzj 04-12-2009 05:57 PM
Today, 1:00
http://lh4.ggpht.com/_gM4XB39aOP8/Se...0/100_1590.JPG
So a summary:
3" Rusty's springs, Rough Country Adjustable Front Track Bar, IRO rear trackbar bracket, Homemade Rack, and Brushguard, Quick-discos and swaybar extensions, Treadwright 31-10.50-15's, Baja Rims, rear-bumper w/ recovery points F & R. and a lot of Krylon Fusion. 170k on the clock
I hope to get down to the river in a couple of days for some actual shots that are not in my driveway, I never take my camera when I go and play....
I have replaced,
front CV joint, Pinion bearing, Axel bearing, entire rear axle, and that's about it.
Future plans,
Rock sliders and skid-plates 242 swap; that's it. maybe front bumper with the right design
Black95ZJ 04-12-2009 07:04 PM
That's a very nice ZJ, my friend. Good job, and it's an inspiration to me at least....what you can do with little money and a lot of ingenuity. I'm liking the **** out of the roof rack and rear bumper.
Just for curiosity's sake, how much does that bumper weigh??
ISUzj 04-12-2009 07:20 PM
according to the Solidworks...roughly 78 lbs, it really is not bad, balanced and easy to mount, 4 bolts and the shackles hold it on. I pulled a 3/4 ton dodge with that bumper from the ditch. I am going to try and get a new pic with the Roof rack, I lost the bolts that hold it on.
micifus 04-12-2009 07:50 PM
That rear bumper came out really nice. A lot of people on here try and make there own and honestly they come out looking like ****. By far the best one I have seen. You maybe want to consider a UV protectice clear coat alot of that stuff starts to degrade qucik
runnerboy2010 04-12-2009 10:42 PM
Nice work ISU, it looks great. Glad to see someone else from Iowa on here too, and that grill guard makes me extremely jealous. I have been looking for one forever but never found one i like more than that. Also i think it looks alot better with the herculined fenders. Great work so far.Go Clones!
coupleofjeeps 04-12-2009 11:55 PM
hey that does look very good... good for you for doing stuff on the cheap and doing it yourself.
ISUzj 04-13-2009 10:27 AM
Thanks, yeah did a ton of research first and design on Solidworks. I put the Krylon fusion on it once it dried going to see how much of a UV protection that works out to be.
MoonyJohn 04-13-2009 08:38 PM
1 Attachment(s)
I like the hurculiner on the fenders, turned out clean. Also, did you just use krylon fusion on the handles and mirrors? I might need to take that up pretty soon during spring/summer.
Our jeeps are almost the same. :thumbsup:
WhiteOut 04-13-2009 08:47 PM
Very nice Jeep. Nothing wrong with doing it on a budget and fabbing your own stuff, makes you appreciate it more. I was gonna point you in the direction of my thread but it looks like RnEmOver took care of ya. :thumbsup:
ISUzj 04-13-2009 09:11 PM
Well I can say that your jeep was the true inspiration to me to lift it, but ya for the fenders I was super worried how it would look but once I hit that fender with the grinder...well then it was forward or nothing.
Kryloning the handles...a lot of work, but worth it I think. makes it look so much cleaner..I am not sure how it will hold up with me hitting my hands on it all the time, I feel like it may eventually wear off, but nothing more krylon can't fix :cheers:
ISUzj 07-29-2009 10:38 PM
Just posting up an updated pic of the jeep all clean..... Will get a rock pic up soon
http://lh3.ggpht.com/_gM4XB39aOP8/Sm...0/102_0130.JPG
SnowLeopard 07-29-2009 11:07 PM
Awesome work. I wish I had the fabbing skill to do stuff like that. Your Jeep looks great. I can't wait to see some trail pics.
ISUzj 10-06-2009 06:01 PM
I Thought I would add some of what I have done since the last pic in this thread. I have been doing more Minor stuff, but I got started on my OBA. The reason that I am after OBA is because I really don't think that I will have a big o'l shop compressor in the future but wanted one that could be used on some small air tools and for tires. So I got me a Tank w/o compressor with other fixins for 30 bucks Thanks Craigslist:
http://lh6.ggpht.com/_gM4XB39aOP8/Ss...0/100_1628.JPG
Then I built a nice surround for it, and got some vinyl at a fabric store(never like going in those covered in grease) and I covered it.
http://lh6.ggpht.com/_gM4XB39aOP8/Ss...0/100_1630.JPG
http://lh5.ggpht.com/_gM4XB39aOP8/Ss...0/100_1631.JPG
Added some Other things to it :use the space. Got the Air coupler and a mounted pressure gauge so I know what my pressure is. All of the in lines are in the front and close to the floor. Once I get to the York, and figure how to mounted it, I can run the lines right up and in. Right now though it still holds 220 lbs of air that I can put in through a simple coupling. I did a test, I can air up one tire from flat to bout 25-28 lbs. which I think is pretty good just for the tank.
http://lh3.ggpht.com/_gM4XB39aOP8/Ss...0/102_0207.JPG
Here it sits now...Also Got my Axe mounted(really been handy with camping a couple times this summer) Flashlight easy access is really nice too.
http://lh6.ggpht.com/_gM4XB39aOP8/Ss...0/102_0205.JPG
and added 10hp
http://lh4.ggpht.com/_gM4XB39aOP8/Ss...0/102_0208.JPG
The time now is 08:24 PM.
