Iron Rock Offroad long arms, bad brake steer. is it common? - JeepForum.com
post #1 of 6 Old 04-24-2013, 05:56 PM Thread Starter
GODMODEX
I have really bad brake steer after installing my 6.5 IRO critical path LA lift on my WJ I have been told by a couple people that this is the nature of their wristed radius arm design. I wanna know if anyone else has this problem with their long arms, if you fixed it and how etc, or if I should be chasing something else as the source of my brake steer... thanks all!
01 TJ, 32RH, 4.0, 8.8, hpd30, 35's, metalcloaks
07 CBR600RR, full Akra exhaust, PC V, etc.
GODMODEX is offline
post #2 of 6 Old 04-25-2013, 02:52 AM
framanda
I had terrible brake steer after I finish my three link. Custom not a iron rock offroad setup but still a 3 link. Turned out to be a bad caliper replaced it and now it's been great for over a year. I believe that the stock 4 link was hiding the issue and the the three link bought the issue to the surface.
framanda is offline
post #3 of 6 Old 04-25-2013, 12:20 PM Thread Starter
GODMODEX
I believe it is a caliper after cleaning and greasing the slide pins it decreased
GODMODEX is offline
post #4 of 6 Old 04-26-2013, 12:28 AM
framanda
Mine problem was the ceramic piston was seized in the caliper effectively makeing the brakes on that side inoperable.
framanda is offline
post #5 of 6 Old 04-27-2013, 05:48 PM
clgielin
2003 WJ
Mine brakes straight, no brake steer. Is your front axle centered, aligned after the lift?
Chris
2003 WJ 4.7L
Build Thread Here:
Michigan Tech Jeepers #4
Utah JeepCrew #16
clgielin is offline
post #6 of 6 Old 04-28-2013, 12:58 AM Thread Starter
GODMODEX
yeah it is, thinking brakes still but it's hard to tell
GODMODEX is offline
