Installing Budget Boost on WJ - JeepForum.com
post #1 of 20 Old 07-21-2010, 07:24 PM Thread Starter
GatorJeep15
I'm ordering the 2" Budget Boost w/ shocks for my WJ
I want to know if I should take it somewhere and have someone else install it or if this is doable. I have fair amount of experience when it comes to mechanical work, but little to none exprience in suspension for cars.
I would love to have someone here who has installed this lift on their jeep give me advice. Thanks.
GatorJeep15 is offline
post #2 of 20 Old 07-21-2010, 07:25 PM
patrick02wj
its the easiest thing ive done to my jeep other than pumping gas go for it
2002 WJ I6, IRon Rock Offroad 4", JKs adj. trackbaR, Doetsch Tech 8000 Prerunner Shocks, 275/70/17 BFG AT, Black Moabs, tinted tails, Hellas
Alpine IVA-W205 Double din, JL Audio 10w7, Fosgate POWER 600/2, Fosgate POWER 400/4, FOCAL 165V30
patrick02wj is offline
post #3 of 20 Old 07-21-2010, 07:27 PM Thread Starter
GatorJeep15
haha that's calming for me...
So switching the shocks won't be a big deal
post #4 of 20 Old 07-21-2010, 07:32 PM
patrick02wj
naah not too bad, what kind of shocks?
post #5 of 20 Old 07-21-2010, 07:34 PM Thread Starter
GatorJeep15
I'm not sure, rusty's doesn't show a picture of the spacers and shocks here is the link:
Rustys Offroad: WJ Grand Cherokee 2" Budget Kit (includes shocks)
post #6 of 20 Old 07-21-2010, 09:49 PM
WillMcD
Im 18 and I put on my 4in lift by myself so im sure you could do a budget boost. Its best to have someone give you a hand though.
04 WJ Limited Black, 5.5" LA hybrid (IRO Trackbar, Teraflex Springs, Bilstein 5100/5125 Shocks, IRO Critical Path High Clearance LA's + KOR 3/4" spacers, JKS Disconnects) 32" Firestone Destination M/T's, JCR Stage 3 Sliders, Black Moabs, Muffler Delete, Hella 700ff's, Yakima Load Warrior
Phil:4:13: I can do all things through Christ which strengtheneth me.
Originally Posted by billzcat View Post
a lot of people waste their life playing FB games all day like Farmville, Cityville, Gangsterville, Hookersnblowville, Idonteffingcareville
August 2011 GCOTM Winner
Build Thread:
WillMcD is offline
post #7 of 20 Old 07-21-2010, 09:58 PM
GraKee99
Rapist Wit
GraKee99's Avatar
Just take your time, read the instructions and spray pb blaster on every bolt you have to remove. That will make them come off a lot easier.
When I did my BB, I read the instructions at least 15 times and ended up doing the install in my apartment parking lot. It isn't difficult, don't get frustrated and post up any problems.
Brian
WJ, WK, CJ5
GraKee99 is offline
post #8 of 20 Old 07-21-2010, 10:38 PM
Apollo21
if you're worried about removing the front shocks you're on the right track ratcheting wrenches, vise grips, and a helper make them a lot easier to deal with.
Midshipmen Patrick 1/C USMMA DD: 2004 Golf GLS TDI 43mpg and 2002 Overland: Zone 4in, 32in Treadwright MTRs, IRO upper CAs, lift gate light mod, Alpine/Polk speakers, and power inverter with USB in dash mod, CB, custom rear swing out tire carrier Build thread
SOLD
Apollo21 is offline
post #9 of 20 Old 07-21-2010, 11:11 PM
marcua56
I did mine myself in about 4 hours. Get spring compressor first and if you dont need it then great but its alot better than walking to rent one because your jeeps in peices haha.
marcua56 is offline
post #10 of 20 Old 07-22-2010, 10:46 AM Thread Starter
GatorJeep15
so do I need any other special tools other than a spring compressor?
post #11 of 20 Old 07-22-2010, 10:50 AM
Apollo21
i didn't use a spring compressor. i just let the axle drop. Be careful with the spring compressor mess that up and getting hit with a coil sucks.
SOLD
Apollo21 is offline
post #12 of 20 Old 07-22-2010, 10:53 AM
marcua56
The only time I needed it was passenger side up front. the axel just wouldnt droop enough. Otherwise if you jack up the oppisite side your working on it will lower the side your trying to work on.
marcua56 is offline
post #13 of 20 Old 07-22-2010, 11:02 AM
WillMcD
Socket set, pb blaster, jack stands, and floor jack are the only things necessary (If im missing something correct me). Spring compressors are a good idea to have though even though you may not use them.
Build Thread:
WillMcD is offline
post #14 of 20 Old 07-22-2010, 11:08 AM Thread Starter
GatorJeep15
thanks guys, lets hope this isn't a disaster....
post #15 of 20 Old 07-22-2010, 11:13 AM
WillMcD
Take pics when youre done!
Build Thread:
WillMcD is offline
2" , budget boost , diy , lift , newbie , wj
Best Budget Boost? KHoff90 Grand Cherokee General Discussion 29 07-26-2009 02:01 PM
Budget Boost??? coloradojeeper ZJ Grand Cherokee Forum 1 06-04-2009 03:37 PM
2" budget boost on a budget lambar ZJ Grand Cherokee Forum 17 05-07-2008 09:38 PM
installing a budget boost in my WK void my warranty? coyote runner WK Grand Cherokee & XK Commander Forum 2 09-23-2007 02:46 AM
Not another budget boost ? mitchj01 ZJ Grand Cherokee Forum 1 01-05-2005 02:10 PM
