Improving MPG on my Jeep Grand Cherokee - Page 4 - JeepForum.com
post #46 of 55 Old 05-22-2012, 06:50 PM
Spiritsuit7
2003 WK
Okay then do drive through floods...thats why we have Jeeps! haha
QUIDQUID RECIPITUR AD MODUM RECIPIENTIS RECIPITUR- Thomas Aquinas
Translation: Whatever is received is received according to the manner of the receiver.
Spiritsuit7 is offline
post #47 of 55 Old 11-24-2013, 10:02 PM
Duly_Noted
Worst Jeep Mileage Ever?
Great site! I just bought a 1999 Jeep Grand Cherokee Laredo V8 with 145K miles on it. Had a tune-up last week. According to the console, I'm getting a measly 6.7 mpg in the city. I was expecting to get at least 12 to 14 mpg. Any ideas why it's so much lower than its e.p.a, and what I can do about it? I'm going to try Sea Foam next week, but I'm not very optimistic about it getting my mileage up to the rated levels. It's driving me nuts!
Duly_Noted is offline
post #48 of 55 Old 11-27-2013, 01:08 PM
sdowney717
Reduce rolling friction using skinny tires.
Reduce the wheel rotating mass by using light weight rims.
Put in a 4 cylinder engine.
sdowney717 is offline
post #49 of 55 Old 11-27-2013, 01:19 PM
sdowney717
56 to 60 mpg improvement by putting on donuts just on the rear of car.
post #50 of 55 Old 11-28-2013, 10:46 AM
Zombieslammed
I feel really bad for you guys I look at double digits all day on highway around 27-32. But not so much in the city I go through gas really fast I have one hell of a lead foot.. spectra air filter autolite plugs. Oil change with treatment. And then once a year I do a seafoam cleaning in the brake booster vacuum hose... that's all I did. And mine is an inline 6 jeep wj so it may be a bit different in weight
Zombiekid
Zombieslammed is offline
post #51 of 55 Old 02-26-2014, 05:22 PM
nurpelflup
As with any motor it's just a big air pump the more air you can get in and out the better of you'll be.
nurpelflup is offline
post #52 of 55 Old 04-01-2014, 03:52 AM
sdowney717
Motor is a big air pump, BUT more air in and out = more gasoline used.
That is due to the engine computer maintains the proper gas fuel to air ratio at 14 air to 1 gas.
Heavy foot open up the throttle means your pumping more air, more air in, more power, more gas used.
A restricted air filter means less air flow = less gasoline flow since computer controls fuel injection = better gas mileage but less power.
The oxygen sensor tells computer how to maintain proper stoichiometric ratio, and then it does.
post #53 of 55 Old 11-24-2015, 07:43 AM
callmebignate
Switch to manual seats, chuck the spare tire, remove the back seats, slide the roof racks all the way to the back and then pull the front driveshaft during the summer. Add a wash and wax and you'll get low/mid 20s.
callmebignate is offline
post #54 of 55 Old 11-24-2015, 07:59 AM
callmebignate
You can also take plastic and streamline the undercarriage. Door trim strips on every edge to reduce drag, too.
post #55 of 55 Old 12-07-2015, 08:30 AM
OsteKuste
Zombie thread! Just won't die!
2000 TJ Sahara 4.0
1961 Willys CJ5
2004 WJ Grand Cherokee Laredo, Freedom Edition
OsteKuste is offline
Will A 242 Transfer Case From A 90 Cherokee Fit In My 99 Jeep Grand Cherokee.?? squirrly ZJ Grand Cherokee Forum 8 03-05-2009 05:55 PM
Jeep Liberty 8.25 Axle into a Jeep Grand cherokee??? blackjeeprubi ZJ Grand Cherokee Forum 23 10-13-2008 07:10 AM
jeep grand cherokee 00 peepmyjeep00 ZJ Grand Cherokee Forum 2 01-14-2008 04:54 AM
Need Help with my 05 Jeep Grand Cherokee dallag WK Grand Cherokee & XK Commander Forum 2 07-25-2007 04:36 AM
Jeep Grand Cherokee HelpMeFindaGC ZJ Grand Cherokee Forum 15 02-09-2006 06:03 PM
