I want to change the mechanical cooling fan on the electric fan?! - JeepForum.com
post #1 of 15 Old 08-21-2013, 01:07 AM Thread Starter
madelk_RUS
wanted to ask you!
From what car would suit the cooling fan (electric)?
I want to lead off button on the dashboard (to overcome water obstacles)
found only on 5.9, but it is very expensive
in Russia there is only the original (Mopar), and here it is $ 800
madelk_RUS is offline
post #2 of 15 Old 08-21-2013, 01:31 AM
970001zj
ford thunder bird v8/ lincoln mark 8 v8, perfect fit
97 zj orvis/04 wj ltd/02 lancer oz rally/85 rx7 gs
970001zj is offline
post #3 of 15 Old 08-21-2013, 02:29 AM Thread Starter
madelk_RUS
and what model year?
I'll look)))
in Russia there is almost no such machines
post #4 of 15 Old 08-21-2013, 02:36 AM Thread Starter
madelk_RUS
post #5 of 15 Old 08-21-2013, 02:41 AM
970001zj
Originally Posted by madelk_RUS View Post
yes , that is exactly like the one i installed make sure you get the wire harness as well
it flows about 4,000 cfm low and 5,000 to 6,000 high
you should get a 136 alternator if you dont already have one or something better too
970001zj is offline
post #6 of 15 Old 08-21-2013, 02:46 AM Thread Starter
madelk_RUS
He gets up without any alterations?
what is the volume of air needed motor 5.2?
I have is the original generator)
its energy is not to be missed?
post #7 of 15 Old 08-21-2013, 03:02 AM
970001zj
i believe the stock mechanical fan flows 5,000 cfm maximum
the t-bird fan fits the stock radiator perfectly with only a few mm of space left over
today it was 90*f and i had the a/c on idling for 15 minutes with the fan on low and my coolant temperature never got over 195-200*f
while beating it in hot weather with the a/c on the temperature never gets over 210*f
i suggest the t-bird e fan over any other even nice aftermarket stuff that is $200-$300 because it fits so well and flows so much air
970001zj is offline
post #8 of 15 Old 08-21-2013, 03:06 AM Thread Starter
madelk_RUS
Thank you! will be ordering
3 weeks to wait on you)))
post #9 of 15 Old 08-21-2013, 03:09 AM
970001zj
no problem
dont forget the wire harness that goes with it !
970001zj is offline
post #10 of 15 Old 08-21-2013, 04:10 AM Thread Starter
madelk_RUS
And you can throw a link?
or the number of the parts?
thank you
post #11 of 15 Old 08-21-2013, 04:22 AM
970001zj
thank you
you should be able to find one at a junkyard maybe
970001zj is offline
post #12 of 15 Old 08-21-2013, 04:27 AM
970001zj
car-part.com
970001zj is offline
post #13 of 15 Old 08-21-2013, 05:14 AM Thread Starter
madelk_RUS
'll book until just a fan.
I do not know the year of production of the Ford T-Brad
electrician do it myself
thank you
post #14 of 15 Old 08-21-2013, 10:22 AM
970001zj
cool , it shouldnt be too hard to solder in some wires or use connectors with one side open and one side crimped to a wire
970001zj is offline
post #15 of 15 Old 08-21-2013, 11:59 PM Thread Starter
madelk_RUS
thank you
