How to reset Malfunction Indicator Light on a 2008 Grand Cherokee - JeepForum.com
post #1 of 6 Old 04-23-2010, 09:00 AM Thread Starter
JG_2008
Hello all,
I have searched around the forum but have been able to find a difinitive answer to how I can reset the malfunction indicator light on my cherokee.
I have come across the following so far and will test later today.
Solution #1 - Disconnect the positive and negative battery leads for 15+ minutes. This *should* cause a reset.
Solution #2 - Disconnect the positive and negative battery leads and touch them together. This *should* cause a reset.
Wondering if anyone has tried this already and if these are indeed the right solutions to the reset the malfunction indicator light.
Will post my results when I try them out.
Any help will be greatly appreciated.
Thanks.
JG_2008 is offline
post #2 of 6 Old 04-23-2010, 10:07 AM
xgerstandtx
Your vehicle has an OBD II system. To read the code (the reason you have a MIL) you need to obtain a code reader/diagnostic tool. After you read the code they give you an option to clear codes. It would be wise to figure out out what code you have set than go from there. disconnecting the battery may work but it makes sense to do it correctly.
Sometimes you can go down to autozone and those guys will let you borrow a code reader to scan it.
Or you can go to your local mechanic and let him do the job he is trained for.
xgerstandtx is offline
post #3 of 6 Old 04-23-2010, 10:31 AM Thread Starter
JG_2008
Thanks. Pulling the battery leads out did not work. Neither did tapping the leads together. I just brought it R&S Strauss so they can run a diagnostic and clear the codes. Will cost be $40 bucks. No biggie though, at least I will see if there are any new codes and then it can be cleared.
Thanks again.
JG_2008 is offline
post #4 of 6 Old 04-23-2010, 10:53 AM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Check out this link: Jeep Grand Cherokee WK - Diagnostic Trouble Codes
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #5 of 6 Old 04-23-2010, 02:39 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
Might want to try fixing whatever is causing the code to begin with. Just clearing it with an OBDII scan tool will just turn the light off, but will not fix the reason the light was on to begin with.
~James
ezflip is offline
post #6 of 6 Old 04-24-2010, 06:53 PM Thread Starter
JG_2008
Yes, I know. That is why I brought it to the shop. Paid $45 bucks. The intake temp sensor plug was not plugged in. That is what caused MIL to go on. Sensor plug was plugged in and the light was cleared. Jeep is all good now.
Thanks to all that responded. Found it helpful
JG_2008 is offline
2008 grand cherokee , mil
Malfunction Indicator Light on, '02 sarge74 Wrangler General Discussion 8 03-23-2009 03:55 AM
07 Grand 6cyl Malfunction Indicator Light tastic WK Grand Cherokee & XK Commander Forum 3 01-07-2009 03:03 PM
Malfunction indicator light on Tameer ZJ Grand Cherokee Forum 7 04-24-2007 07:07 PM
Help ~ Why my Malfunction Indicator Light is on? leoleo ZJ Grand Cherokee Forum 2 11-23-2006 07:52 PM
Question on Malfunction Light/OBD-II reset. KrisR ZJ Grand Cherokee Forum 3 11-22-2005 02:07 PM
