How to change dash light on 93-98 ZJ!! - Page 6 - JeepForum.com
 1Likes
post #76 of 219 Old 03-12-2010, 08:46 PM
JeepZjLrd
Thank you sooooo much for posting this it has helped me alot and I turned my interior to white LED's
1993 Jeep Grand Cherokee Laredo - Rubicon Express 3.5 Superflex lift, 5.9L bumpers,cladding,hood,vents,grille, Hids, Tail light covers, Intake, PIAA fogs, and much more goodies
JeepZjLrd is offline
post #77 of 219 Old 03-12-2010, 09:08 PM
soul_Less
1994 ZJ
looks awesome
saved this thread for future reference.
soul_Less is offline
post #78 of 219 Old 03-16-2010, 11:26 PM
studmichael
hey
hey so i need 8 to do the hole guage cluster. 1 74 hp for key and 2 for the shifter. ?
studmichael is offline
post #79 of 219 Old 03-17-2010, 09:22 PM
JeepZjLrd
Thats correct but 1 for the shifter and 1 for the TC shifter
post #80 of 219 Old 03-25-2010, 09:17 PM
EMTFFNJ
Hey thanks alot for this whole writeup, It was easy enough to follow that I did the same as yours in under an hour, Looks great. Used the blue LED Bulbs also.
EMTFFNJ is offline
post #81 of 219 Old 03-26-2010, 07:40 AM
jlipka98zj
Originally Posted by VastoLorde View Post
rear doors window switch bulb, front one's I can't get into, case won't fully open
Damn it, that's a solder bulb, too. I wonder how to get the front one open (if possible). There's gotta be a way.
I have all my LED's, just need the time to do it now. I got every bulb for the entire interior except for the door switches.
I also changed all the dome/courtesy/etc lights to super white LED's and man does it look cool. I did it to my SRT8 months ago and decided to try it on this Jeep. Looks great. Particularly the footwell lights!
jlipka98zj is offline
post #82 of 219 Old 03-26-2010, 07:52 AM Thread Starter
-cAcHe-
-cAcHe-'s Avatar
If you have the part #'s for all the interior lights post them up here and i will update the thread. it will help out alot of people.
What are the #'s for the dome and courtesy bulbs? i would like to do mine white also.
Originally Posted by CarolinaWK View Post
I like happy endings :2thumbsup:
RIP Troy Edwards (bigbluezj94)
-cAcHe- is offline
post #83 of 219 Old 03-26-2010, 08:00 AM
jlipka98zj
Map Lights (Front) - #212 x 2 (1 for each side)
Dome Light (Center, Rear Seat) - #561 x 1 (rigid loop bulb, tough to find good LED replacement)
Map Lights (Rear) - #921 x 2 (1 for each side) 921 LED - White LED
Rear Dome (Above Hatch) - #212 x 1 SUPER 6K WHITE 36 LED DOME LIGHT BULB 212 211 212-2 214-2 578
Footwell - #89 x 2 (Can use 1156 bulb or anything else with BA15S base) 2 HID WHITE MSMT 27 LED LIGHT BULBS 89 1156 1073
Doors - #194 x 2 (1 for each FRONT door)
I also got carried away and did the vanity lights in the sun visors (got idea from my SRT8 Jeep)
Visors - #3022(???) x 4 (2 for each visor) HI POWER SMT 3 LED HID WHITE VANITY LIGHT BULB
post #84 of 219 Old 04-21-2010, 11:10 PM
Triumphil
Outsyanding post very timely.
Triumphil is offline
post #85 of 219 Old 04-21-2010, 11:28 PM
BLACKzj52
Dome Light (Center, Rear Seat) - #561 x 1 (rigid loop bulb, tough to find good LED replacement) EDIT: http://www.superbrightleds.com/cgi-b...L4410-xHP9.htm - what I bought
good work, you just saved me a few minutes! lol
keep in mind, that ^^ is assuming you have a sunroof.
If you dont have a sunroof, I believe you need 4x 212-2 bulbs and no 921 bulbs or the 516
i also edited your post with a link to the 561 bulb I use
good work. Looks like the neo wedge bulbs I need to have soldered in to some of the dash panels
didn't see this one posted before, so this one is for the ''check gauges/low fuel'' and what not (#37 on sylvania chart)
IIRC, the little idiot lights are 74's. I remember because I originally bought a 74 for them, then realized the ignition light by the key is a 74 bulb as well. Decided the ignition lit up looked better, so I went with that. Put a blue 74 behind the "gages" light and it turned purple, lol.
Originally Posted by 2GRND4U View Post
I think because the OP used "white" leds and BlackZJ as well as myself used "blue" leds.... My heated seat control module is brighter than the others but thats because the led's sit closer to the front of the module than the rest.
Right, I used blue led's.
looks exactly like mine! awesome!
BLACKzj52 is offline
post #86 of 219 Old 04-21-2010, 11:32 PM
Triumphil
I really like the blue
post #87 of 219 Old 04-22-2010, 07:29 AM
jlipka98zj
Correct, that is WITH a sunroof. I have only owned two ZJ's and both of them are/were '98's with sunroofs. Since the non-sunroof jeeps have map lights similar to the front, I would agree that you probably need (4) ea 212-2 bulbs and neither the 561 nor 921 bulbs, as you said. Can anyone confirm?
That 561 bulb you linked to is pretty nice. Cheap, too. Since my post, I have found some more 561 bulbs. Try about halfway down this link:
Festoon Dome Lights
You can get some larger arrays to fill out your lens better. Note, the some 561 bulbs may be a little loose on the "posts" that the bulb secures to in the light. Loose enough that the light would flicker when opening/closing doors. I just bent the rigid loops of the bulb to hold it in there tighter.
Every indicator light on the gauge cluster (with the exception of the turn signals) is a 74 bulb. I got all the correct color ones for all the different idiot lights that could come on (amber for ABS, green for cruise, etc). The color gets slightly more "brilliant" but you won't notice a difference on any of them except for the turn signals. You get a much "crisper" flash with LED turn signals. Oh, and I went with low-power frosted lens LED's for the turn signals so I'm not blinded everytime my blinker is on, LOL.
post #88 of 219 Old 04-22-2010, 03:56 PM
Mudzilla6661
2010 JK Wrangler
does anyone have any other colors installed? A while ago I installed the white ones, I didn't care for the color especially mixed with the orange on the gauges. and my jeep is a green and black theme, so I bought the green ones tonight. I will get pics once they are installed. Also, I will have the white ones for sale once I pull them out if anyone is interested. I hope the green looks good.
2010 jk islander aka Mudzilla 2.5 AEV lift 35" kevlars, PSC front and rear bumpers Q10000 winch. More to come!
Mudzilla6661 is offline
post #89 of 219 Old 04-22-2010, 08:06 PM
Triumphil
I would be interested in seeing the outcome I have a green Jeep as well.
post #90 of 219 Old 04-22-2010, 09:58 PM
Spike300
im lookin to do the green also
5.2-242 tcase-44a-30x9.50x15 MT/R-American Racing Burst Rims -Optima -E3 plugs-Custom Paint-Amsoil-Addco Front and Rear-polyurethane bushings
To be installed: RE gen2 discos, military battery terminals
To be rebuilt: HP30
To be received:
To be paid for:
Next on the list: complete redo of brakes and
lines
Needed: fittings, coil of brake tubing, Russel speed bleeders
Zombie Outbreak Response Unit #75
Spike300 is offline
How to change a light bulb......... keya Wrangler General Discussion 7 02-10-2009 07:33 PM
Air Bag Dash Light bobged ZJ Grand Cherokee Forum 1 09-30-2008 12:03 AM
How to change dash light bulbs? 318jeepcherokee ZJ Grand Cherokee Forum 3 09-01-2008 11:40 AM
what is this dash light? dustindu4 ZJ Grand Cherokee Forum 4 02-06-2008 01:50 PM
94 4WD Dash Light Info Herb Jenssen ZJ Grand Cherokee Forum 6 11-27-2002 02:29 PM
