How to change dash light on 93-98 ZJ!! - Page 4 - JeepForum.com
 1Likes
post #46 of 219 Old 01-20-2010, 09:19 AM
BLACKzj52
new bulbs come with new bases. but yes, replaced all of them.
BLACKzj52 is offline
post #47 of 219 Old 01-20-2010, 10:06 AM
wsar10
2003 WJ
THANK U THANK U THANK U THIS HAS BEEN MY DAMN QUESTION FOR A MONTH
and does the new base hav a "wedge base" bulb, i mean can you pull the new LED out of its base unlike the old bulbs that hav wires or leads coming out of the bottom and are kinda permanitley fixed into there base.
wsar10 is offline
post #48 of 219 Old 01-20-2010, 10:12 AM
wsar10
2003 WJ
i'm trying to figure out if i can swap these lights out with wedge base LED's and different bases that accept wedge base bulbs, rather than getting the ones that are no removable from the base.
wsar10 is offline
post #49 of 219 Old 01-20-2010, 10:58 AM
2GRND4U
summary?
Blackzj52, just to beat it like a dead horse..... you used:
HVAC
4x 4mm (blue? or white?) neowedge
Heated Seats/Rear Wiper
3x 3mm(red) solder bulbs
1x 3mm(blue) solder bulbs
3x 3mm(blue) neowedge
Headlight Unit
2x 3mm(blue) neowedge
1x 4mm(blue) neowedge
Dash
6?x 4?mm(did you use blue or white) neowedge
2GRND4U is offline
post #50 of 219 Old 01-20-2010, 11:30 AM
BLACKzj52
do you mean like remove the bulb and throw in a bulb such as the 194? if so no that wont fly. the bases are way too small. And I dont know if you can remove the bulb from the base. But then again I didnt really try.
HVAC
blue
Headlight Unit
Dash
I used 5x 4mm bulbs. All blue
post #51 of 219 Old 01-20-2010, 11:47 AM
2GRND4U
thank you sir, looks great!
2GRND4U is offline
post #52 of 219 Old 01-20-2010, 12:04 PM
wsar10
2003 WJ
Kinda but i mean to use a 194 like bulb but alot smaller the number is i think 74 or a 37, but yes its the same type of base and bulb but alot smaller, the HVAC light base is 10mm round and the 194 is probably 15mm.
I hav store credit with an ebay store and he sells 74 and 37 style LED's but they are wedge base only, this is y i'm trying to figure this out cuz they would be free, except for the plastic base.
wsar10 is offline
post #53 of 219 Old 01-20-2010, 12:11 PM
BLACKzj52
i think the bases would be too small and narrow to accept the bulbs
post #54 of 219 Old 01-20-2010, 01:26 PM Thread Starter
-cAcHe-
-cAcHe-'s Avatar
Updated! thanks john..i will be doing this soon
Originally Posted by CarolinaWK View Post
I like happy endings :2thumbsup:
RIP Troy Edwards (bigbluezj94)
-cAcHe- is offline
post #55 of 219 Old 01-20-2010, 02:31 PM
BLACKzj52
awesome. just had brian add this to the FAQs
post #56 of 219 Old 01-20-2010, 03:35 PM
2GRND4U
just finished ordering
2GRND4U is offline
post #57 of 219 Old 01-20-2010, 04:02 PM
SnowLeopard
I know the link is probably here somewhere, but I just want regular bulbs. My climate control bulbs are burnt out and I need some replacements, but no one local has them. There's nothing at the local junkyard I can get them from either. Those I found are burnt out. So I need to order some new ones. I think they've the gray base. Anyone know a good place to find them?
SnowLeopard is offline
post #58 of 219 Old 01-22-2010, 04:10 PM
SnowLeopard
- Bump - I still just want stock bulbs to replace the burnt out ones in my climate control, but I can't for the life of me find out what they are(the bulb model/#) and where to get them.
post #59 of 219 Old 01-22-2010, 04:28 PM Thread Starter
-cAcHe-
-cAcHe-'s Avatar
come on its on the 3rd page.. i think you should get them yellow since john said they have a blue filter.
SUPER BRIGHT LEDS - LED Lights & Accessories
Climate Control:
x4 4mm neowedge bulbs
**NOTE** Climate control unit has blue filters everywhere. The stock bulbs light up yellow. So yellow + blue filter = green light output.
Heated Seat/Rear Wiper Switch
x4 3mm Solder component neowedge bulbs ("Left" "Right" heated seat indicators, Overdrive off indicator, rear defroster activated indicator)
x3 3mm neowedge bulbs
Headlight Switch
x1 3mm solder component neowedge bulb (fog light activated indicator)
x2 3mm neowedge bulbs
x1 4mm neowedge bulb
Links:
3mm and 4mm neowedge bulbs
Super Bright LEDs - Instrument Cluster and Gauge Backlights
-cAcHe- is offline
post #60 of 219 Old 01-22-2010, 04:31 PM
SnowLeopard
Well howdy do, I'm a blind bat with a sheet over my head. I read all through that and completely overlooked what I need. Thanks.
How to change a light bulb......... keya Wrangler General Discussion 7 02-10-2009 07:33 PM
Air Bag Dash Light bobged ZJ Grand Cherokee Forum 1 09-30-2008 12:03 AM
How to change dash light bulbs? 318jeepcherokee ZJ Grand Cherokee Forum 3 09-01-2008 11:40 AM
what is this dash light? dustindu4 ZJ Grand Cherokee Forum 4 02-06-2008 01:50 PM
94 4WD Dash Light Info Herb Jenssen ZJ Grand Cherokee Forum 6 11-27-2002 02:29 PM
