How to change dash light on 93-98 ZJ!! - Page 13 - JeepForum.com
 1Likes
post #181 of 218 Old 03-28-2013, 12:39 AM
Myusername1674
Originally Posted by Earlk View Post
Question !!! Are there lights on the window and door lock switches on the doors. ??????
1994 ZJ Larado 5.2
Don't think so. Not on my 95
95 FiveTwo ZJ, DD, Lifted, Locked on 35s,
(in progress)
Myusername1674 is offline
post #182 of 218 Old 03-29-2013, 07:51 PM
Travisf90
On my 98 there's lights on the window and lock switches
Travisf90 is offline
post #183 of 218 Old 04-13-2013, 12:28 AM
ROFLwaffles
So, on the 3 and 4mm bulbs, onlt the climate control has blue filters, needing white LEDs? For the ones for headlights and wipers, I need blue bulbs, correct?
Also, what about the 4wd shifter? Can that bulb be changed?
ROFLwaffles is offline
post #184 of 218 Old 04-13-2013, 10:01 AM
jlipka98zj
If you're going for the blue look, use blue everywhere. Don't worry about white.
And yes, the 4WD can be changed. I believe it is a simple 194 LED bulb.
'98 5.9 Limited - Got some stuff done to it...
jlipka98zj is offline
post #185 of 218 Old 04-13-2013, 12:20 PM
rdavisct
Correct bulb sizes for limited zj 95
Thanks for this guide,i went ahead and re did my whole car with blue leds, for the footwells not listed here i went with these http://www.ebay.com/itm/400457012249...84.m1497.l2649 they work great. btw same bulb type as turn signals in rear of car.
the only hiccup was the headlight and rear wipers,i have a 1995 zj limited so no heated seat switch that i see but the bulbs i ordered are
Heated Seat/Rear Wiper Switch
x3 3mm neowedge bulbs
Headlight Switch
x2 3mm neowedge bulbs
x1 4mm neowedge bulb
when i took whole steering apart (which is a pia btw lol) i noticed the bulbs base of the leds were too small to turn and click in. only one fit, there are 2 bigger same size ones,1 reallly small one(which is the only one i fit- for turning interior lights on/dim) and anothr one of a different size. hard to explain exactly but basically 3 different size bulbs it appears.
has anyone done a zj limited 1995?. i need to know the bulbs sizes for the wiper switches and headlight switches. thanks.. also since a bulb does not light the ac display or above console display what i did was ordered some blue headlight tint and applied it, so its no so green,its more like an aqua now.
if anyone knows the correct led bulb sizes,please let me know.
rdavisct is offline
post #186 of 218 Old 04-13-2013, 01:54 PM
ROFLwaffles
Wouldn't white through the blue filters be brighter though? I tried red LEDs in the dash first, they were dim as hell. I'm worried that blue might not be as bright as white.
post #187 of 218 Old 04-13-2013, 02:04 PM
ROFLwaffles
I'm thinking white for the dash and shifters, but blue for everything else. That will give me that hyper blue look.
post #188 of 218 Old 04-13-2013, 10:59 PM
jlipka98zj
h
Go for it. All I will say is that I have my dash dimmer all the way down because everything is so bright. If brightness is your concern, go for it. U will be buying standard power led's
post #189 of 218 Old 04-14-2013, 03:20 AM
ROFLwaffles
h
So go with the 4 bulb LEDs, not the 6 bulb ones then?
post #190 of 218 Old 04-21-2013, 10:54 AM
Lakoswolf
I saw a while back that someone used green LEDs in their conversion which ended up matching the climate controls, VIC etc. Does anyone recall what LED they used or where I might find that post? I've been looking everywhere...
"Those who say it cannot be done should not interrupt the one doing it." -Chinese Proverb
93' Grand Cherokee 5.2 Ltd. - Mine
93' Grand Wagoneer 5.2- Dad's
93' Grand Cherokee 4.0 Ltd. (Deceased)
Lakoswolf is offline
post #191 of 218 Old 04-24-2013, 04:09 PM
ROFLwaffles
h
What bulbs did you use? And did you do the climate control/rear wipers/headlight blubs as well?
post #192 of 218 Old 05-11-2013, 12:24 PM
rdavisct
CORRECT BULBS for 1995 limited v8
x4 3mm Solder component neowedge bulbs ("Left" "Right" heated seat indicators, Overdrive off indicator, rear defroster activated indicator)
Headlight Switch
x1 3mm solder component neowedge bulb (fog light activated indicator)
AS A HEADS UP FOR ALL - on a 1995 grand cherokee limited this is false, you actually need 2 5mm neowedge bulbs,2 4mm neowedge bulbs,and 1 3mm neowedge bulbs. i just had to re order some bulbs since these listed in original post werent the right ones.
so its like this for 1995 GRAND CHEROKEE LIMITED V8 ...
Heated Seat/Rear Wiper Switch/OD on-off
x2 3mm Solder component neowedge bulbs , Overdrive off indicator, rear defroster activated indicator)
x1 5mm neowedge bulbs (rear wiper switch)
x2 4mm neowedge bulbs (overdrive on,rear defrost)
Headlight Switch
x1 5mm neowedge bulbs (headlight turn on ROTATION area)
x1 3mm neowedge bulb (interior lights turn on switch)
rdavisct is offline
post #193 of 218 Old 05-14-2013, 01:50 AM
sunpialia
reply
I used to buy my LED lights from the site http://www.ledlightshub.com. Have you ever heard of it?
sunpialia is offline
post #194 of 218 Old 05-15-2013, 12:28 PM
ROFLwaffles
BIG ISSUE: If you have a Laredo model, the climate control does NOT take a 3 or 4 mm bulb. It uses 3 PC74 twist lock bulbs. Found that out the hard way. Now I have to send the extyra neowedge bulbs back and get those.
For Laredo, the list for the lower dash is this.
2x 3mm neowedge
1x 4mm neowedge
3x PC74 LED
post #195 of 218 Old 07-24-2013, 01:07 AM
petruna
Last Minute Lifesaver
2x 3mm neowedge
1x 4mm neowedge
3x PC74 LED
i have been searching through my service manual for specifics with cluster lights to no avail and was about to order others, thank you for the info!!
petruna is offline
How to change a light bulb......... keya Wrangler General Discussion 7 02-10-2009 08:33 PM
Air Bag Dash Light bobged ZJ Grand Cherokee Forum 1 09-30-2008 01:03 AM
How to change dash light bulbs? 318jeepcherokee ZJ Grand Cherokee Forum 3 09-01-2008 12:40 PM
what is this dash light? dustindu4 ZJ Grand Cherokee Forum 4 02-06-2008 02:50 PM
94 4WD Dash Light Info Herb Jenssen ZJ Grand Cherokee Forum 6 11-27-2002 03:29 PM
