High Pitched Noise Driving Me Crazy - JeepForum.com
post #1 of 10 Old 03-24-2011, 02:42 PM Thread Starter
RedDragon1
I have a 2002 Jeep Grand Cherokee (4x4). There is a high pitched noise that is coming from someplace in the engine in front of the driver area. It almost sounds like a high pitched sound like when you have an ungrounded radio...but its not it. It does not happen all the time, but when it happens, it is when I start to drive above 40 mph. If I press on the accelerator, it will lower pitch. If I let off it, the pitch increases. It does not happen if I put the vehicle in neutral. Of course I can never reproduce it for my mechanic and he has no idea. Please help, it drives my sensitive ears crazy!
Thanks.
RedDragon1 is offline
post #2 of 10 Old 03-24-2011, 04:28 PM
94yj03wj
2003 WJ
I'm not sure if I have the same issue but with my grand cherokee if I'm in 3rd gear doing about 40mph and the torque converter locks up I get the same noise you are describing and it changes with my throttle position. Same thing in 4th gear around 55-60 mph when the converter is locked up. I know this doesn't answer your question but if it is the same problem I have then it most likely has to do with your torque converter. Hope this gives you somewhere to start looking.
2003 WJ Laredo 4.0 I6 with Selec-Trac, 4” BDS lift with 32” Goodyear wrangler Duratracs, KC Slimlites mounted on Kevin’s Offroad Light Bar, Rusty’s Recovery Hooks and T-Case Skid, Midland CB,(Daily Driver)
1994 YJ With 30” Interco TSLs (Project Jeep)
94yj03wj is offline
post #3 of 10 Old 03-24-2011, 05:28 PM
AGDubyaJ
theres been a few threads ill find a link for you. however, ive driven my WJ for 2 years and its made this noise. nothing has broken? why fix it?
does it sound like a stuck pig/ dying goat squealing noise? lol, ill find the thread, one guy said it was a wheel bearing/hub assembly. ive heard it was a pinion bearing issue. i just say, drive on it till it breaks and youll know whats wrong with it!
98 XJ- 4.0L, NP231, AW4, chryco 8.25, 4.5" mid arm 3-link, 285/75 Herc terra tracs on moabs, V8 ZJ tie rod, fabbed bumpers...
AGDubyaJ is offline
post #4 of 10 Old 03-24-2011, 05:35 PM
AGDubyaJ
http://www.jeepforum.com/forum/f310/...t-end-1177341/
http://www.jeepforum.com/forum/f310/...-help-1125491/
its a wheel bearing if this sounds like what your getting.
AGDubyaJ is offline
post #5 of 10 Old 03-24-2011, 05:42 PM
AGDubyaJ
heres a video of the noise i think your talking about.
http://s81.photobucket.com/albums/j2...t=MVI_0977.mp4
AGDubyaJ is offline
post #6 of 10 Old 03-27-2011, 12:28 PM Thread Starter
RedDragon1
No, the sound is even higher pitched. Upper frequency. It almost sounds like it is coming from behind the dash but if you roll down the window, you can hear it louder. It must be coming from the engine compartment on the driver's side.
post #7 of 10 Old 03-27-2011, 12:51 PM
AGDubyaJ
take a video of it.
AGDubyaJ is offline
post #8 of 10 Old 10-04-2011, 06:54 PM
katch26
Thats exactly what mines doing. Is that the wheel bearing?
katch26 is offline
post #9 of 10 Old 10-06-2011, 01:24 AM
AGDubyaJ
pinion bearing
AGDubyaJ is offline
post #10 of 10 Old 04-02-2014, 02:04 PM
03GcJeEpGiRL
2003 WJ
pinion bearing
Around how much should that cost to fix?
03GcJeEpGiRL is offline
High Pitched whining noise when i lift off gas 4.0 WJ Perfectbackstag ZJ Grand Cherokee Forum 12 10-29-2013 10:50 AM
High pitched noise from intake jstang289 ZJ Grand Cherokee Forum 17 03-23-2011 03:41 PM
Loud, high pitched noise coming from right front tire Jakey9547 ZJ Grand Cherokee Forum 3 07-13-2009 03:34 PM
High Pitched Squealing Noise MN_ripper ZJ Grand Cherokee Forum 0 06-10-2009 07:23 PM
Squeaking noise driving me crazy!! miker ZJ Grand Cherokee Forum 1 02-15-2004 08:31 PM
