HELP! my ZJ suddently stop - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > HELP! my ZJ suddently stop
NEW!! HMF 50"-52" light bar mounting brackets!! SPARTAN LOCKERS are on sale BIG TIME at ROCKRIDGE 4WD!Rubicon express discounts from oconee off-road
Unread 11-13-2013, 05:54 AM   #1
jeffjeep2
Hi Guys;
Need your input my ZJ 4.0 6 cyl suddently decided not to run or start
I wont crank either.
here is what I know so far
1. battery is good just bought it, because I taught the cause of not cranking is due to week battery.
2. starter is good I remove it from the car and have it tested and it crank and run ( spin)
3. when I switch the igniton to and pull the lever to reverse, no backlight at all.
4. I tried to wire the middle terminal of the starter switch on the ignition and connect it to positive. no avail no crank at all just a click click.
any suggestion to diagnose will be great help.
jeffjeep2 is offline   Reply With Quote Quick reply to this message
Unread 11-21-2013, 10:20 AM   #2
jeffjeep2
After 2 weeks of trying to figure it out. Myjeep is alive again.
Itcost me a new starter and solenoid, itcame to mind that when i start it i only hear a click
Even if supply direct 12v to S switch. I tryto hammer the solenoid or the starter and itstarts to move.
Referred it to a friend and he said he is convicedit ws a starter. Installed a new starter and it was good.
Now i have to clean and arrange the wire again and roll the jeep back on the road!
Thanks everyone for the support
