Help me pick my lift - JeepForum.com
post #1 of 3 Old 08-17-2017, 06:40 PM Thread Starter
04awpro
I have a 2004 grand cherokee limited with the 4.7l and 4x4. I have a budget of 800-1200 dollars to lift it. Have scowered through the wj lift threads but can't decide. Need inspiration and guidance so pictures are appreciated and links to products would be great. Thanks!
04awpro is offline
post #2 of 3 Old 08-18-2017, 01:43 PM
tymaoaretae
tymaoaretae's Avatar
2003 WJ
Is that budget for lift/tires/repairs/etc or just for the lift itself?
What is your goal for the use of the vehicle?
2003 WJ LTD 4.7, 242HD, PR44+ARB+RCV & D44HD+varilok+BTF 4.56, 7" RC LA (Clayton coils + pucks), Bilstein 5165, OBA, Lizardskined & Monstalined inside.
tymaoaretae is offline
post #3 of 3 Old 08-18-2017, 02:27 PM
Jeeples
Jeeples's Avatar
Zone 4" lift can be had at the bottom end or under the lowest number in your budget range. Add in some front sway bar disconnects from the company of your choice to gain a little more functionality and you're done.
That will leave you plenty of cash to refurb the rest of your suspension, such as tie rod ends, ball joints, bushings and rear upper ball joint.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
