Help easy question on 2000 grand cherokee laredo -
Go Back > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Help easy question on 2000 grand cherokee laredo
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! 1999-2004 Jeep Grand Cherokee Limited Headlight Pair1999-2004 Jeep Grand Cherokee Laredo Headlight Pair for Mo
Unread 10-06-2015, 08:14 PM   #1
I have a 2000 grand cherokee that the heat only works the first few minutes I turn it on then it no longer comes out hott I checked all the vacum lines and I noticed this vacuum line with no hose attached and air comes out of it when I turn on my heat, if u see that taped up hose I did That to fix the air from only blowing out my vents and it seemed to work, but now my issue is the heat does not work to good, I'm hoping it's not the blend door everyone keeps telling me about, does someone know if there is supposed to be a hose attached to that vacum line I circled
Youshady2 is offline   Reply With Quote Quick reply to this message
In order to be able to post messages on the forums, you must first register.
Jeep, Wrangler, Cherokee, Grand Cherokee, and other models are copyrighted and trademarked to Jeep/Chrysler Corporation. is not in any way associated with Jeep or the Chrysler Corp.
