Quantcast Help can't find sensor anywhere for ZJ - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Help can't find sensor anywhere for ZJ
Truck-Lite's New LED Headlamp Series4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE NeededRuffstuff Axle Simple Swap Kit!
Old 06-25-2009, 07:06 AM   #1
mimintheport
Hello all,
Please if you have parts of 98 Jeep Grand Cherokee 5.9 Limited, please help:
Parts needed-
Coolant temp sensor (well the book says lower hose)-I have pics
I can't find this sensor anywhere on the net or stores, they said it was D/C and now I'm desperate.
I also need the Computer for the jeep and front driver side Axle.
Or it can just be I need a really good mechanic that knows about these Jeeps
here is the link to see pics thanks http://raleigh.craigslist.org/cto/1236618455.html
Thanks!!!
mimintheport is offline   Reply With Quote
Old 06-25-2009, 06:38 PM   #2
81cjkid
1981 CJ7
Ok, I've got two part numbers for you for the coolant temp sensor, WT3026, and TS82261. They are both from Kragen/O'riely. Send me a message if you still can't get a hold of the parts. Oh, and as far as the computer, they can't get one, so it might be a dealer item only.
81cjkid is offline   Reply With Quote
Old 06-25-2009, 07:15 PM   #3
j.love
1994 ZJ
PM sent!
David.
94 ZJ laredo 5.2 V8 soon to be 5.9!!
In Delaware, the largest growth of population is Indian Americans, moving from India. You cannot go to a 7/11 or a Dunkin’ Donuts unless you have a slight Indian accent. I’m not joking. Joe Biden
j.love is offline   Reply With Quote
Old 06-25-2009, 07:25 PM   #4
jbreck
The coolant sensor is in the coolant reservoir, its not the engine coolant sensor. Mine was saying the same thing in the dash and I looked forever until the guy at the parts store told me that the computer in the dash doesn't throw engine codes.
jbreck is offline   Reply With Quote
Old 06-25-2009, 08:56 PM   #5
ratmonkey
Living dead mod
ratmonkey's Avatar
98 5.9 has an electric fan with coolant temp sensor in the rad hose that controls the fan only.
ratmonkey is offline   Reply With Quote
Old 06-25-2009, 09:06 PM   #6
ZJPunk98
Addicted to my jeep
ZJPunk98's Avatar
If your vic is giving you an error message "coolant temp sensor" this is almost always related to the one in the reservoir. replacing or ensuring a good connection with the sensor wires will fix the problem.
Erik
98 ZJ 5.2L JGC Limited
185K still running great
ZJPunk98 is offline   Reply With Quote
Old 06-25-2009, 09:27 PM   #7
vansskaterfreek
if you need dealer parts, PM me, ill hook you up
1998 ZJ 5.9L 122k miles - DD, 242 swap, 3.5" RE, 32" BFG M/T, safari rack, roof-mounted lights, custom steel front bumper with hitch reciever, 10k winch :)
2004 WJ 4.7L 107k miles - her daily driver, 2" daystar BB with scorpion shocks.. not too bad! stuffed 265/65/17 General Grabber AT2'S
vansskaterfreek is offline   Reply With Quote
Glock Forum
