HeavyArm's Longshot zj built - Page 58 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > HeavyArm's Longshot zj built
Jeepforum Coupon for Iron Rock Off RoadRuffstuff Axle Simple Swap Kit!Our Panhard / Trackbar brackets, Variations......
Unread 05-13-2012, 11:31 PM   #856
PeriwinkleZJ
Is that with the front sway bar connected?
-1993 Grand Cherokee Laredo V8 5.2, Mopar CAI, Borla headers, Borla Y-pipe, Turn down exhaust, 4" RC SA, 33x12.50r15 BfGoodrich Km2, Crown extended brake lines, IRO Double Shear Track bar, IRO HD tie rod, Home made Quick discos, E-fan, Heavy duty harness/9007 bulb conversion, HP30 WJ knuckles lockrite solid cover.
BUILD THREAD:http://www.jeepforum.com/forum/f197/...-jeep-1133312/
PeriwinkleZJ is offline   Reply With Quote
Unread 05-14-2012, 08:59 AM   #857
HeavyArms
Yup fronts still connected. Im working on the front next weekend.
For the front il be adding pucks, swapping shocks, making disco's, the dropping it off for MM radius arms
Wiggle wiggle wiggle
HeavyArms is offline   Reply With Quote
Unread 05-18-2012, 01:18 PM   #858
HeavyArms
Got a call from MM. My radius arms are being re-scheduled for the end of next month. He had a dude drop off a s-10 wanting a sas and cage.
So today i pulled the pucks out of the rear. Is it bad that my axle rotates as much as it dose? I know theres a wicked swing radius on short arms but damn.
image-3086658380.jpg   image-764348026.jpg   image-2677676345.jpg   image-2792324861.jpg   image-3963468298.jpg
Unread 05-24-2012, 12:54 PM   #859
HeavyArms
Got a lil bit done before work
I thou all cladding clips were held on by lil pins? Mine were held on with self tapping screws?
Unread 05-24-2012, 01:11 PM   #860
squashman702
Mongo-fabbed
squashman702's Avatar
1994 ZJ
Someone probably pulled it and reattached it in the past. There shouldn't be any self tappers in there.
Think Twice Garage
"I guess I'd just run it?"
squashman702 is offline   Reply With Quote
Unread 05-24-2012, 07:38 PM   #861
PeriwinkleZJ
I second that. Never seen a zj with anything but pins.
Sent from your moms house, using JeepForum
Unread 05-24-2012, 08:45 PM   #862
HeavyArms
Thanks guys.
Now i gotta decide weather i want to leave it off or put it back on. I think i might leave i off and monstaline it.
Unread 05-25-2012, 10:22 AM   #863
HeavyArms
Finally got sum 96+ cladding!
Unread 05-25-2012, 09:01 PM   #864
Heepish
Looking good, man! I still haven't made that needed trip to Parts Galore...
1998 Grand Cherokee 5.9 Limited - Completely bone stock for now
1996 Grand Cherokee 4.0 2WD Laredo - Suprise for the grandfolks
1994 Chevy Silverado 1500 4X4 - Plow Truck
1993 Honda Del Sol Si - Parked good weather DD
Heepish is offline   Reply With Quote
Unread 05-27-2012, 09:26 AM   #865
HeavyArms
Thanks heep!
Picked up a set of tsl's and 3 boggers for $100 lmao. 3 tsls are 50% while ones bald. Boggers are about 25-30%.
Tsls on the front boggers on the back
Unread 05-29-2012, 05:25 PM   #866
HeavyArms
Flipped the swampers and doubled my monies
As for the zj, wheel'd it a bit this weekend. Painted the wj's new-to-it 16's. Not much else
Also i painted my buddys MM tube bumper. One of a kind fresh out the fab shop . Then we had to use it lol.
Also Alpha's getting big!
image-1069594951.jpg   image-3867744227.jpg   image-1450888802.jpg   image-1184736672.jpg   image-2226571610.jpg
Unread 05-30-2012, 12:15 AM   #867
HeavyArms
Also i really want to swap in an e-fan. Starting to research that!
I looked at my wj and it has a huge e-fan so that route is going to be a possibility
Unread 06-06-2012, 08:48 PM   #868
HeavyArms
Not much to write home about but zj's going to the MM shop tomorrow. It's getting new bumpstops, 44a lincon locked, and "steps" added to the rockers.
My GF is just over 5' and my mon has hip problems. I feel bad for them so basically the same steps that were on my sliders will be added to the tube but angled down a bit so there easier to reach.
As for bumpstops. Ive lost my rear coil 3 times now. Not happy about it atall. So were expending the factory post but capping the tube and weldin in a nut. That way a factory front bumpstop cup can be screwed in. it will need to be fine tuned but i like the idea.
Unread 06-10-2012, 10:36 AM   #869
HeavyArms
Picked it up today. Steps are done along with the lincoln lock. I end up making my own spring post extensions
image-62790546.jpg   image-1819280654.jpg   image-2949887635.jpg   image-3292127678.jpg   image-80126694.jpg
Unread 06-10-2012, 06:28 PM   #870
HeavyArms
My $500 investment! Already sold the doors for $400!!! Im pulling the drivetrain and keeping it for mine
