09-26-2011, 05:34 AM
#46
The clocks ticking, pops.
Bumper looks great. What kind of paint and clear did you use? I know what problem you're having - I had the same issue with the hood of my Subaru. I was just curious if you used the same paint.
Chelsea
WANTED:
-Jeep Comanche OEM drip rails
09-26-2011, 11:59 AM
#47
The rustolum hammard black and i forgot what clear. For me the problem was i got impatient and didnt wait long enough. Same thing happen on the gfs rims.
Weird part is i also painted my rocker covers and sliders with the same paint and didnt have any problems.
Wiggle wiggle wiggle
09-26-2011, 01:16 PM
#48
started the jeep up to head to work and it idled loke crap. Acted like it was going to stall but then itd idle way up for a couple seconds then idle normal for a couple seconds.
Just kept lobing. Gonna pick up a tps before work tomorrow and try that
09-26-2011, 01:50 PM
#49
i'd try a IAC
1996 ZJ- 4.0, [COLOR="Purple"]AX-15 5SPD/NP242[/COLOR], RE 4.5" lift, 36x12.50x16.5 Goodyear military surplus tires, Longarms/Tri-4 link/one ton axle build/swap in progress, arb bumper, a bunch of other goodies
1995 XJ- 4.0 HO, ax-15(stolen for swap), stock
2001 GMC Sonoma-RIP...
2002 GMC Sierra 1500 ECSB-roadtrip/long haul vehicle
[CENTER][COLOR="Blue"]RIP Troy (bigbluezj94) you wont be forgotten[/COLOR]
[COLOR="Purple"]December 2010 GCOTM[/COLOR]
5spd ZJ Club Member 001
[/CENTER]
[QUOTE=bddisi;6376248]Glad you are ok. If you were a cat, you would be down to 8.:D[/QUOTE]
[QUOTE=Greengc4x4;10782815]Everything looks great, Hellen Keller! :D[/QUOTE]
[QUOTE=rritch;10960201]plastic + Fuel + Ignition = "Bubba wake up this is gonna be good" :rofl:[/QUOTE]
[CENTER][COLOR="Purple"]RIP William Anthony Kolich(DAD)
you were the best father i could have wished for. I'll always miss you
04/28/58-2/13/11[/COLOR][/CENTER]
#50
Originally Posted by PurpleZJ
i'd try a IAC
Huh?
09-26-2011, 02:03 PM
#51
idle air control valve. with the engine idling does it respond properly when you rev it? and just idles like crap without you revving it i'd look into the IAC instead. that was causing my poor idle. engine would respond to my foot normally but as soon as i let off the gas it'd either die or idle extremely low
[/CENTER]
09-26-2011, 02:31 PM
#52
Thanks purp! Thats exactly what i have going on.
09-26-2011, 02:37 PM
#53
X2 on the IAC. I had the same problems purp is describing. Looks like you're off to a great start. You basically stole it from that guy. I might have to have you give me your friends contact info for future reference. Not sure if you're still interested or not but I still have that FM 50 if you want it. Im going to be posting it up on GL4x4 and craigslist later today.
98 5.9 ZJ: 4.5" IRO + 1" spacers w/IRO front adjustable long arms and rear adjustable CAs, IRO OTK steering, KOR steering brace, JKS quick disconnects, IRO belly skid, Bilsteins, 33x12.5x15 Duratracs on MT sidebiters, ARB bumper w/ WARN M8000 and 2 55W Hella Black Magic, JCR stage 2 sliders, Bushwackers, AEM CAI, KOR lightbar w/4 130W slimlites, Kolak Ignition Upgrade, 3" Kolak exhaust w/Flowmaster 44
In the garage: 8.8 w/4.10s and LSD, Artec 8.8 swap kit and truss
My 5.9 BUILD THREAD: http://www.jeepforum.com/forum/f197/...hread-1095938/
R.I.P. TROY
09-26-2011, 02:42 PM
#54
Good ta hear from you! Nah the fm isnt really needed on a 4.0
In a few months my zj sliders will be up for grabs thou
09-26-2011, 03:09 PM
#55
how much you want for the sliders?
just curious.
[URL="http://i1206.photobucket.com/albums/bb441/black97ZJ/September%20Nineteenth%202011/IMG_1210.jpg?t="]Blacked out 97 ZJ 4.0, 4" IRO + Junkyard lift kit[/URL], [URL="http://i1206.photobucket.com/albums/bb441/black97ZJ/Flex/IMG_1075.jpg?t="]32" Maxxis ATs, 15x8 d-windows[/URL], [URL="[IMG]http://i1206.photobucket.com/albums/bb441/black97ZJ/April%20Thirtyth%202011/IMG_0567.jpg[/IMG]"]cherrybomb turbo[/URL], [URL="http://i1206.photobucket.com/albums/bb441/black97ZJ/April%20Thirteenth%202011/IMG_0545.jpg"]gas tank skid[/URL] and [URL="http://i1206.photobucket.com/albums/bb441/black97ZJ/April%20Thirteenth%202011/IMG_0539.jpg"]t-case skid[/URL], [URL="http://i1206.photobucket.com/albums/bb441/black97ZJ/December%20Twenty-fifth%202010/IMG_0183.jpg"]spectre cone air filter[/URL], [URL="http://i1206.photobucket.com/albums/bb441/black97ZJ/May%20First%202011/IMG_0575.jpg"]Baja off road lights[/URL]
[CENTER][URL="http://www.jeepforum.com/forum/f197/1stblack97zjs-build-thread-frankinjeep-1121844/"][COLOR="Blue"][SIZE="4"]MY BUILD THREAD[/SIZE][/COLOR][/URL][/center]
09-26-2011, 03:31 PM
#56
I figured as much but thought I would ask since I knew you wanted it before.
I picked up a set of JCR stage 2 sliders from toomuchtalk on great lakes for $120. I had to buy the bolt kit and have them sand blasted though. Pics are on my build thread.
R.I.P. TROY
09-26-2011, 03:47 PM
#57
Darn cuz i was gonna give you a good deak because i love ur 9'er lol
Blk- im thinkin about $150ish. Really depends on who it is lol
09-26-2011, 05:25 PM
#58
At work, just went to go get dinner and the f'er wouldnt start again!
For sum reason the old owner pulled all the domelight bulbs. I havent botherd with it because it hasnt caused a problem till now. The key ring stays lite all the time and my key fob wont lock the doors or arm the security system.
I just pulled the fuse. Hopefully it dosnt die again.
09-26-2011, 08:04 PM
#59
I'd check all the fuses in the main box, yeah. And I think you might have a fuel pump issue. It's all one module in the tank, and I had that issue with starting/idling. The check valve that keeps fuel to the rail when the Jeep is shut off was bad. So the fuel would all drain back to the tank, and it'd have to pump and pump to get fuel to the rail to start. If I didn't keep on the ignition for long enough, it'd stumble and idle roughly and die. So often I was flooding the engine with fuel because it couldn't get it right off. What a PITA. I ended up replacing so much before I finally figured out it was that. Jeep should be sued for such a moronic setup. The entire assembly in the tank, one unit, is quite pricey. I'd get one from Kolak if that's your problem. Just turn the key to the aux setting, wait to hear the hum of the fuel pump, turn back off, repeat twice, and then turn to full ignition. If it starts without issue or less issue that's probably the problem. Anyway, it seems most auto builders do this all-in-one pump/filter/checkvalve assembly these days. So we're stuck with this idiotic mess.
09-26-2011, 08:45 PM
#60
Thanks for the input snow. It was very informational but im pretty dure its either the tps or what purp said.
I tried just starting it and it fired right up no problem.
Drove home for dinner just fine. Never started idleing funny till i got home.
