Had to ask this question - JeepForum.com
post #1 of 8 Old 04-11-2009, 01:01 AM Thread Starter
Pomorza
Hello all.
I've been a member here for about six months or so and have noticed a large majority of you like V8 engines in the ZJ. I would like to know why?
I've done my share of off road driving in my young life (I'm 21) and I've never really needed anymore power than the good old I6 puts out. Now take my jeep is stock and I usually stick to mostly moderate trails (I trail ride) so I've never really experienced a moment where I found 190hp not to be enough.
Is there something wrong with the I6? Mine has 253k on it and still starts up everyday like she was did the day we bought her. Sure she has a very faint knock on the bottom end at idle (very faint), and yes the remain seal is bad so oil leaks out (~1qrt a month) but I've never really had any major problems with it.
So I would really like to know. Why do you have a V8? Do you just not like the I6 engine or do you really need that extra power?
Jan
1996 Jeep Grand Cherokee. I6 2WD auto 250,000+ miles.
Pomorza is offline
post #2 of 8 Old 04-11-2009, 01:31 AM
Haleyrz
No one needs the extra power, we just want it. Think of it this way. Try to push a boulder up a steep hill, it might be a little difficult. Now if you were quite a bit stronger/fit/bigger, it would be easier. The I6 works wonders in the wrangler, and even in the XJ. In the ZJ it is perfectly acceptable, but when it comes to towing, hills, rock crawling, etc, its a little underpowered for the heavier vehicle.
1998 ZJ Laredo, 4.0L, 2WD, it's boring
Haleyrz is offline
post #3 of 8 Old 04-11-2009, 04:20 AM
newfieZJ
The fuel economy difference is very minimal
V8's have the better transmissions
and your almost guarenteed an LSD in the rear
Besides all that , my 0-60mph is less than 10 sec. with 32's and a 5" lift the exhaust rumble's a sound I love to hear
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #4 of 8 Old 04-11-2009, 06:33 AM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
If you know how to use it right, 6 is enough
'09 Rubicon
Kruzin is offline
post #5 of 8 Old 04-11-2009, 07:21 AM
newfieZJ
The 6 is enough , I like how you put it . It's enough to run run slightly bigger tires , it's enough to pull the family to the lake , and it's enough to get groceries with . For those who choose to build up , the V8 just makes more sense . No stroking required , no re-gearing required , no rear locker needed (until the dana breaks , lol) , the transmission are stronger , have less trouble and on average , take more abuse .
I liked the 4.0 in my stock 93 , it was a good engine with ample power to get along , but my lifted 95 V8 blew the doors off it . OK OK , it might have been the wife's driving
1995 Orvis build
1988 MJ build
newfieZJ is offline
post #6 of 8 Old 04-11-2009, 07:31 AM
97 ZJ Steve
I6 has enough for me and i find it easier to work on
to each their own
97 ZJ Steve is offline
post #7 of 8 Old 04-11-2009, 07:39 AM
newfieZJ
You solved your power issue with 4.56's . Heck , you probably have more get up and go even with your 33's over stock . Definately the way to go .
Nice build BTW
1995 Orvis build
1988 MJ build
newfieZJ is offline
post #8 of 8 Old 04-11-2009, 09:27 AM
UTChavok
Id love to have a V8 over the 6 just for the pure sound of a V8, I love that rumble. The I6 right now with my 33s and 3.73s is MISERABLE towing my boat. I only go 20 minutes max so its tolerable now. When I try and tow my four wheeler for a couple hours it sucks. Its peddle to the metal sometimes to get up some hills.
Granted im on not so stock tires with stock gearing. When I finally do axle swaps and regear I shouldnt be having these problems.
-Ronnie
UTChavok is offline
Newbiee Question?? - grand cherokee thumping question geoff6194 ZJ Grand Cherokee Forum 2 03-23-2011 01:59 PM
Radio code question - option question... GARover WK Grand Cherokee & XK Commander Forum 5 12-25-2009 10:39 PM
air condition face unit question n00b question Fatsooo ZJ Grand Cherokee Forum 4 09-21-2008 08:45 PM
couple minor questions. door question and mirror question Irish_Assassin ZJ Grand Cherokee Forum 2 07-04-2008 02:14 PM
Rear bumper question and shock question 01grander ZJ Grand Cherokee Forum 1 06-28-2005 10:26 PM
