Gray Goose Build Thread - Page 7 - JeepForum.com
post #91 of 752 Old 10-19-2010, 12:46 PM
volvite
Looks like you painted over the weights. Did you paint under them too?
His 99 WJ Limited 4.7
Hers 15 Overland EcoDiesel, ORAII
volvite is offline
post #92 of 752 Old 10-19-2010, 01:13 PM Thread Starter
smunns
No, I'm not going to remove the weights to paint under them. When I need to get them re-balanced down the road it's easy enough to just touch up where the old weights were.
smunns is offline
post #93 of 752 Old 10-24-2010, 02:15 PM Thread Starter
smunns
I finally had a chance to tackle my exhaust manifold leak.
The broken studs. They turned out by hand one I removed the exhaust manifold.
Old vs. new. The old gasket didn't have the metal layer that the new one does.
Also found this damage to one of my wheels from my offroad trip last week.
smunns is offline
post #94 of 752 Old 10-24-2010, 02:38 PM
volvite
That's s bad bend on the tire rim. Know if it's repairable?
volvite is offline
post #95 of 752 Old 10-24-2010, 02:51 PM Thread Starter
smunns
I'm going to make some calls, and see if it can be repaired. If not, I should be able to find another wheel pretty cheap.
smunns is offline
post #96 of 752 Old 10-24-2010, 03:11 PM
volvite
If it still holds air, you could always use it as the spare.
volvite is offline
post #97 of 752 Old 10-24-2010, 03:32 PM
85IrocZ-28
^x2.
*Project Yeti* 99 JGC Limited 4.7 w/6.5" Rockkrawler LA & IRO A-arm, Goodyear MTR 35's on MB TKO's, 4.56 Yukon's, Iceland Offroad Bumper/Flares/Sliders, Protofab Rear Carrier, SuperChips, Uniden/Firestick, Flowmaster, Smittybilt 8k Synthetic Line Winch.
My Jeep is Organic - Undercoated in 100% all natural Utah Dirt --- Utah Jeep Crew #49 ~Will
2012 JeepForum GCOTY ---
85IrocZ-28 is offline
post #98 of 752 Old 10-25-2010, 03:43 PM
801DubJay
Like the build thread! Your dub looks great... The graphite rims against the silver paint looks awesome and so does that tire carrier. Well done
'00 WJ Laredo V8 aka Katie
My Build Thread: http://www.jeepforum.com/forum/f197/801dubjay-build-thread-1114628/
801DubJay is offline
post #99 of 752 Old 10-25-2010, 04:00 PM
Apollo21
Be careful with that manifold many times it's warped and will need to be machined level. (cheaper than a new one) so it a bolt breaks again warping could be the culprit.
Midshipmen Patrick 1/C USMMA DD: 2004 Golf GLS TDI 43mpg and 2002 Overland: Zone 4in, 32in Treadwright MTRs, IRO upper CAs, lift gate light mod, Alpine/Polk speakers, and power inverter with USB in dash mod, CB, custom rear swing out tire carrier Build thread
SOLD
Apollo21 is offline
post #100 of 752 Old 10-25-2010, 04:07 PM Thread Starter
smunns
I checked it with a straight edge and it appeared to be fine. If it breaks again, I'll get it machined. I think it only took me about an hour to do.
smunns is offline
post #101 of 752 Old 10-25-2010, 04:09 PM
00JGC00
How hard was it to separate from the downpipe? I got too scared that mine wouldn't seal properly again so I left it connected. Kade's too.
"The" Matt | '00 Limited WJ | "The White Wolf" aka "Willow" aka "Cool Whip" aka "Sweet 'N Low" aka "AKA"
Utah JeepCrew #39 | Club Matt #1
December '11 GCOTM | Build: http://www.jeepforum.com/forum/f197/life-times-979511/
00JGC00 is offline
post #102 of 752 Old 10-25-2010, 04:14 PM Thread Starter
smunns
I was expecting a nightmare, the same as my '02 TJ, but this was seriously EASY. It loosened right up without too much effort, and went back together perfect too. The passenger side looks like it would suck though.
smunns is offline
post #103 of 752 Old 10-25-2010, 04:21 PM
85IrocZ-28
I did mine a while back. It wasn't that hard. It seems like everyone has problems with the driver's side. That is a good thing though as it is easier to get to than the passenger side. I pulled mine off of the downpipe. It took about 1.5 hours from start to finish when I did it.
Same thing with the loose bolt, I couldn't believe that they just came out by hand.
post #104 of 752 Old 10-25-2010, 04:25 PM Thread Starter
smunns
Nothing can be as bad as drilling out and tapping a broken exhaust manifold stud on my old 2.5L TJ back in high school. I think that was one of the first mechanical projects I ever tackled.
smunns is offline
post #105 of 752 Old 10-26-2010, 12:29 AM
5speed
Great job on the build very impressive results!!
5speed is offline
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 03:58 PM
Do I have dark gray or light gray laredo trim? guywithoutajeep ZJ Grand Cherokee Forum 11 08-16-2009 12:04 AM
