Grand Cherokee CRD - Transmission Fluid Change - JeepForum.com
post #1 of 10 Old 07-17-2012, 10:32 PM Thread Starter
Diesel25
2008 WK
Has anyone seen any "how-to" tutorials on changing the transmission fluid in an '08 CRD? I'm planning to do this on my recently purchased CRD (just in case the previous owner wasn't as nice to it as I plan to be). I just want to make sure I'm not missing something since I've never done a fluid change on a transmission with the auto/shift feature.
Thanks!
Dsl
Diesel25 is offline
post #2 of 10 Old 07-18-2012, 07:47 AM
timbotrog
2014 JK Wrangler
I have done plenty of repairs and servicing myself, but never serviced an auto box. Watched a few vids on youtube and read up on it a little. I have a 2003 V8 Grand and I'm looking at doing the same thing.
I'll see what I can find out from some aussies with oil burners.
Cheers
Tim
timbotrog is offline
post #3 of 10 Old 07-19-2012, 07:18 AM
JeepCares
FCA Customer Care
JeepCares's Avatar
I think the biggest problem is checking the fluid level.
From the service manual:
TRANSMISSION FILL
To avoid overfilling transmission after a fluid change or overhaul, perform the following procedure:
1. Verify that the vehicle is parked on a level surface.
2. Remove the dipstick tube cap.
3. Add following initial quantity of MoparŪ ATF +4, Automatic Transmission Fluid, to the transmission:a. If only fluid and filter were changed, add 5.0 L (10.6pts.) of transmission fluid to transmission.
b. If the transmission was completely overhauled or the torque converter was replaced or drained, add 7.7 L (16.3 pts.) of transmission fluid to transmission.
4. Check the transmission fluid (Refer to 21 - Transmission and Transfer Case/Automatic - NAG1/FLUID and FILTER - Standard Procedure) and adjust as required.
21 - Transmission and Transfer Case / Automatic - NAG1 / FLUID and FILTER/Standard Procedure
CHECK OIL LEVEL
Special Tools:
9336A - Dipstick
WARNING: Risk of accident from vehicle starting off by itself when engine running. Risk of injury from contusions and burns if you insert your hands into the engine when it is started or when it is running. Secure vehicle to prevent it from moving off by itself. Wear properly fastened and close-fitting work clothes. Do not touch hot or rotating parts.
3. Actuate the service brake. Start engine and let it run at idle speed in selector lever position "P".
4. Shift through the transmission modes several times with the vehicle stationary and the engine idling
5. Warm up the transmission, wait at least two minutes and check the oil level with the engine running. Push Oil Dipstick 9336A into the transmission fill tube until the dipstick tip contacts the oil pan and pull out again, read off oil level, repeat if necessary.
NOTE: The dipstick protrudes from the fill tube when installed.
6. Check the transmission oil temperature using the appropriate scan tool.
NOTE: The true transmission oil temperature can only be read by a scan tool in Reverse or any forward gear position.
7. With the transmission in “P”, determine the height of the oil level on the dipstick and using the height, the transmission temperature, and the Transmission Fluid Graph, determine if the transmission oil level is correct.
8. Add or remove oil as necessary and recheck the oil level.
9. Once the oil level is correct, install the dipstick tube cap.
JeepCares is online now
post #4 of 10 Old 04-23-2013, 12:36 PM
NameLikeNoOther
I found this thread pretty helpful for this too ...
http://www.jeepforum.com/forum/f67/p...check-1135591/
especially getting the temperature reading on a budget
In my quest for NAG1 information I also found this link on the forums here.
http://www.benzworld.org/forums/w210...ssion-faq.html
and within it this which is extremely helpful with pics:
http://www.benzworld.org/forums/w210...ion-fluid.html
NameLikeNoOther is offline
post #5 of 10 Old 09-04-2013, 10:21 AM
johnniebravo
2008 WK
I am sure it's me, but the two charts linked above are a bit confusing. For a 2008 CRD which should I be using?
2008 CRD GC
johnniebravo is offline
post #6 of 10 Old 06-24-2014, 08:21 AM
brewcider
can we use Sprinter parts? I compared the prices and the Sprinter parts are way cheaper than Jeep. I've ordered from Europarts before for my fuel filter and glow plugs and see they have a tranny change kit....
http://europarts-sd.com/2002-2009aut...ekit-fuchs.asp
sold - 2005 Liberty Limited CRD, 22G Package, Atlantic Blue, fully loaded.
2007 Grand Cherokee Limited Diesel 4x4
brewcider is offline
post #7 of 10 Old 10-06-2016, 06:43 AM
jgc2006
2006 WK
I read the temperatures by my Android phone using the following device & application combination:
Mini ELM327 Bluetooth OBD2 scanner
http://www.ebay.com/itm/NEW-Mini-ELM...076058&vxp=mtr
Torq Android App
https://play.google.com/store/apps/d...l.torque&hl=fi
Costs < $10
jgc2006 is offline
post #8 of 10 Old 03-06-2017, 09:20 AM
underscore
2007 WK
After reading this thread I ordered the dipstick and an ELM327, at first it wasn't showing the trans temp on my phone (Android) until I found out you need to change a setting to show Jeep trans temps. Open Torque, hit the "Settings" button on your phone, then go "Settings" -> "Manage extra PIDs/Sensors" -> your settings button again -> "Add predefined set" -> "Chrysler/Dodge/Jeep/Mercedes". This will add three more options to the list, you want the post-2012 one even though our Jeeps are pre-2012 (the pre-2012 calculation read way too low).
2007 WK CRD QDII
underscore is offline
post #9 of 10 Old 03-17-2017, 10:59 AM
Raffish
2005 WK
I have trans filters ordered and will be doing a filter/fluid change shortly..
Raffish is offline
post #10 of 10 Old 06-05-2017, 01:19 AM
yabadaba
The charts in post 3 indicate that the 3.0 diesel (CRD) has a different (higher) fill level than the gasoline powered Grand Cherokees. Can anyone confirm that this is correct please?
yabadaba is offline
Transmission Fluid Change Mediokrates ZJ Grand Cherokee Forum 15 08-09-2012 04:29 PM
Transmission Fluid Change? Grey/brown Fluid JeepinJordan ZJ Grand Cherokee Forum 17 02-28-2012 05:40 PM
2007 grand cherokee transmission change ltningjace WK Grand Cherokee & XK Commander Forum 3 03-03-2010 07:08 PM
Transmission Fluid Change TonyVideo WK Grand Cherokee & XK Commander Forum 5 09-15-2009 01:29 PM
Transmission fluid change matt21484 ZJ Grand Cherokee Forum 21 07-27-2009 02:47 PM
