Going to be 5 degrees Tuesday morning, anything I can do to prep? - Page 3 - JeepForum.com
Closed Thread
post #31 of 118 Old 01-05-2014, 09:47 PM
Jeffro06
Jeffro06's Avatar
5 degrees? You guys having a heat wave? I went and filled the wife's Explorer with gas earlier, and it was already zero, and it's supposed to be -20 at 8am. If nothing starts I guess we'll go back to bed and try again the next day.
Jeffro06 is offline
post #32 of 118 Old 01-06-2014, 01:07 AM
970001zj
its - 18 now and what i do to prep it is very complicated and demanding but i will share it with you
start it in neutral and leave it there for 10 minutes to warm
97 zj orvis/04 wj ltd/02 lancer oz rally/85 rx7 gs
970001zj is offline
post #33 of 118 Old 01-06-2014, 03:10 AM
Timo_90xj
Timo_90xj's Avatar
Don't.. it's better to leave it idle for a only a little while and then start driving. Keep it on low revs though, don't exceed around 2.5-3k until the engine is at operating temps. I'd take it easy in very cold anyways, shocks etc. tend to go do funky things when it's -20* outside The coldest I've started my XJs or the ZJ has been around -25*F, without a block heater. With good battery/ starter cables and a good battery, it's not a problem. Use full synthetic oil, and check to see 50/50 coolant mixture.
Other than that? Wake up, drink your cup of coffee, go to Jeep, start it and drive, enjoy trouble-free, warm miles. At least these things warm up and stay warm, unlike newer vehicles especially on this side of the ocean.. try keeping a 1.4 litre VW Golf that gets 40+MPG warm in sub-zero temps. It won't Diesels are even worse..
If you're doing a lot of city driving, and not long stretches where the engine compartment warms up, your battery will be very cold and not happy to recharge. In that case, you may end up with a dead battery surprisingly quickly.
***Under construction***
Timo_90xj is online now
post #34 of 118 Old 01-06-2014, 05:58 AM
jeepjeepster
Its funny when people start talking about wind chill, no one really has a clue.
All its doing is removing the heat quicker. So yes, it affects anything thats warmer than the air temp.
jeepjeepster is offline
post #35 of 118 Old 01-06-2014, 06:21 AM
dmak04
1994 ZJ
I'm here in utah and have had some pretty cold mornings (not quite - 35, coldest has been -10) and my zj has had a few rough starts. One exceptionally cold, icy morning it took a set of jumper cables and a heat gun and about an hour to convince her to fire up. I replaced the battery and starting coil and haven't had nearly as many issues. Pumping/burying the gas pedal also helps in the cold mornings
dmak04 is offline
post #36 of 118 Old 01-06-2014, 07:09 AM
OverlandZJ
LOL...
Wind Chill is absolutely a valid concern.. my fuzzy slippers aren't Goretex lined. My Gramp's told me so..
OverlandZJ is offline
post #37 of 118 Old 01-06-2014, 07:23 AM
Jeffro06
Jeffro06's Avatar
For inanimate objects (like Jeeps), the effect of wind chill is to reduce any warmer objects to the ambient temperature more quickly. It cannot, however, reduce the temperature of these objects below the ambient temperature, no matter how great the wind velocity.
Jeffro06 is offline
post #38 of 118 Old 01-06-2014, 07:32 AM
Timo_90xj
Timo_90xj's Avatar
^- This exactly.
However, even though windchill doesn't reduce temps any lower than ambient temp. is, it can cause issues at times due to the fact increased windspeed causes quicker heat dissipation, which in turn causes machinery not to stay within operating temp range. We've had this happen many times at my workplace with equipment having long, exposed hydraulic lines, when equally cold temps under calm weather don't cause any issues.
post #39 of 118 Old 01-06-2014, 08:08 AM
Uniblurb
Uniblurb's Avatar
Guess it's common sense to have your defroster on after running for a few minutes so the air will heat up slowly on a frozen windshield. I learned the hard way years ago on our 93 XJ where a small chip in the windshield turned into a crack across the whole windshield when pouring hot air to it after warm up with almost an inch of ice on the outside.
If you have summer blend windshield washer in your reservoir/lines you best drain it out since it will freeze in these cold temps. A typical winter blend washer fluid has 30-40% methanol in it which keeps it from freezing.
Just curious how others unfreeze doors iced shut? I'll typically just use a half-warm water to pour around the door/outside latch button while being careful to not let it hit glass. Of course it's just going to freeze over again in using water. May try my new heat gun today to thaw them out. I do apply silicone to all the door/hatch rubber seals which helps a lot.
Here in Ohio we don't get the cold temps others up North do but it's supposed to be -12 by midnight tonight.
96 4.0 ZJ Laredo, 2004 4.7L WJ Limited, 93 4.0 XJ (spare), 96 4.0 XJ (son's)
Uniblurb is offline
post #40 of 118 Old 01-06-2014, 08:23 AM
bjorn17
I have seen a professional AA guy use a regular heat gun in the area of the lock/latch on the door. A few minutes and everything was ice free inside and outside. Just place your hand next to the metal where you give heat to avoid paint damage.
B.
bjorn17 is offline
post #41 of 118 Old 01-06-2014, 08:23 AM
riot1987
Explain. I like to warm mine up in neutral. This is bad??
Build thread^^
riot1987 is offline
post #42 of 118 Old 01-06-2014, 09:35 AM
PolkaPower
Most of the wear happens to a motor on start up when the oil has settled to the bottom. Idling the motor doesn't circulate the oil very well. Driving it slowly gets the oil gets the oil warm faster and circulated which means less wear and tear at start up.
PolkaPower is offline
post #43 of 118 Old 01-06-2014, 11:20 AM
jnowak
Originally Posted by RoldGold
Nope, near Philadelphia. Is that a normal prediction for Atlanta? Seems a little low...
Gonna be a record if it hits it. Gonna be 0 where I am at it the mountains.
jnowak is offline
post #44 of 118 Old 01-06-2014, 12:39 PM
Timo_90xj
Timo_90xj's Avatar
^- That.
post #45 of 118 Old 01-06-2014, 12:45 PM
steiny93
with a decent battery you will be fine at +5
this weekend we were -25F (air temp) windchill was into the -60's F; the 1991 xj with 209k on the ticker was starting just fine without being plugged in or anything
if you are hyper worried i'd get a block heater in it and plug that in
steiny93 is offline
Closed Thread
