Going to be 5 degrees Tuesday morning, anything I can do to prep? - Page 2 - JeepForum.com
Closed Thread
post #16 of 118 Old 01-05-2014, 03:34 PM
wtroger
Good battery, good starter, right oil it should fire right up. Turn key on and off three times to pressurize fuel system and minimize crank time. Block heaters are the best insurance for good starts in cold weather. Plus they give you instant heat from the heater.
wtroger is offline
post #17 of 118 Old 01-05-2014, 03:40 PM
riot1987
It's silly how wind chill is interpreted by most people. Really, its fake. It doesnt exist. It feels colder but its not. At all. lol.
OP: I agree with the block heater.
Anyone ever used those heated dipsticks? Do they work? Ive just seen 'em in stores
Build thread^^
riot1987 is offline
post #18 of 118 Old 01-05-2014, 03:49 PM
somebody5788
1994 ZJ
It's supposed to be -20 tomorrow morning here (actual temp not wind chill). 5* is nothing.
2006 Honda 919 - Summer Daily
1994 Jeep ZJ - RC Long Arms | RE 4.5" springs | Bilstein 5100's | RE SS brake lines | Falken 31x10.5-15 tires | Flatland 4x4 bumpers | Summit Soft 8's 15x8 3.75 BS wheels
somebody5788 is offline
post #19 of 118 Old 01-05-2014, 04:24 PM Thread Starter
RoldGold
Wow I didn't realize how many people get insulted by the mention of wind chill. I know the wind chill affects only humans; I interpreted OverlandZJ's comment merely as trying to save face after we had complained about 5 degree weather and then the real men came in and talked about trying to start their Jeeps in absolute zero conditions (I kid!).
1996 Grand Cherokee Limited 4.0L
PSC Steering Gear; NP249 w/ new VC; Moog TRE's, Track Bar, Stabilizer bar bushings and endlinks, control arm bushings
Still no lift, and almost no paint on the hood
RoldGold is offline
post #20 of 118 Old 01-05-2014, 04:30 PM
zj97ltd
It's going to be in the 60's here tomorrow morning.......
zj97ltd is offline
post #21 of 118 Old 01-05-2014, 04:31 PM
Kingr98
2016 JK Wrangler
It is even going to get cold down here in Alabama. 14 degrees tonight and 4 degrees tomorrow night.
I do not worry about my Jeep starting, but moisture has frozen in my door locks before and I could not unlock it(no remote door locks). I would think that would be more of a problem down here because it often starts with rain in the evening and the temperature drops overnight. Right now, it is 53 degrees outside and raining...
I usually spray WD-40 into my lock in the evening, but I ran out this morning.
Kingr98 is offline
post #22 of 118 Old 01-05-2014, 04:50 PM
Technohead
I'd recommend buying vodka and whiskey.
-Eric
Technohead is offline
post #23 of 118 Old 01-05-2014, 05:12 PM
roughknight69
I like this idea
Build thread
roughknight69 is offline
post #24 of 118 Old 01-05-2014, 05:57 PM
jnowak
Originally Posted by RoldGold
So after checking the weather, I am starting to get a little bit worried. I've never had my Jeep in 5 degrees before, and haven't ever had to do a cold start at 5 degrees, after it sitting overnight. I park outside, so a space heater isn't really an option. Are my concerns about the temperature warranted?
Are you near Atlanta, I am a little north of it and that's are tempture predication
jnowak is offline
post #25 of 118 Old 01-05-2014, 06:05 PM
riot1987
Build thread^^
riot1987 is offline
post #26 of 118 Old 01-05-2014, 06:06 PM
riot1987
Originally Posted by technohead View Post
i'd recommend buying whiskey and more whiskey.
fify
Build thread^^
riot1987 is offline
post #27 of 118 Old 01-05-2014, 06:23 PM
roughknight69
I'd recommend buying Jim Beam and Jack Daniels .
Even better
Build thread
post #28 of 118 Old 01-05-2014, 07:55 PM Thread Starter
RoldGold
Nope, near Philadelphia. Is that a normal prediction for Atlanta? Seems a little low...
RoldGold is offline
post #29 of 118 Old 01-05-2014, 08:38 PM
wjkrostek
2012 KK Liberty
Originally Posted by roughknight69 View Post
Even better
An other tip from the far north. Don't drink the jack and beam when its subzero. If its out side with you it will be liquid but will be the same temp as outside. (-20 also). When you drink it it will freeze your mouth. Think when you are out there and its subzero. It is up to you.
wjkrostek is offline
post #30 of 118 Old 01-05-2014, 08:40 PM
Compgeek789
1994 ZJ
Battery maintainer, or a set of jumps and another vehicle nearby just in case.
RIP 1994 ZJ 5.2
Compgeek789 is offline
Closed Thread
