Going to be 5 degrees Tuesday morning, anything I can do to prep? - JeepForum.com
Closed Thread
post #1 of 118 Old 01-05-2014, 01:12 PM Thread Starter
RoldGold
So after checking the weather, I am starting to get a little bit worried. I've never had my Jeep in 5 degrees before, and haven't ever had to do a cold start at 5 degrees, after it sitting overnight. I park outside, so a space heater isn't really an option. Are my concerns about the temperature warranted?
1996 Grand Cherokee Limited 4.0L
PSC Steering Gear; NP249 w/ new VC; Moog TRE's, Track Bar, Stabilizer bar bushings and endlinks, control arm bushings
Still no lift, and almost no paint on the hood
RoldGold is offline
post #2 of 118 Old 01-05-2014, 01:21 PM
PolkaPower
Move?
PolkaPower is offline
post #3 of 118 Old 01-05-2014, 01:27 PM
xcaliber81
My jeep gets cold starts every winter. Lowest has been like -35 celsius. Get a block beater if your worried.
xcaliber81 is offline
post #4 of 118 Old 01-05-2014, 01:27 PM
OverlandZJ
Make sure your coolant is fresh, 50/50 mix.
Battery on a trickle charge might not be a bad idea.
Gonna be cold here..
OverlandZJ is offline
post #5 of 118 Old 01-05-2014, 01:52 PM
nodoze
5 above? You should be fine I think, assuming your battery isn't bad. It's -5 here right now, and Monday our HIGH is -15, so I'm a little nervous about mine too but I'm sure the Jeep will be ok.
First Jeep, still a newb :)
1996 ZJ Laredo 4.0 w/ 242 SelecTrac
nodoze is offline
post #6 of 118 Old 01-05-2014, 02:35 PM
riot1987
5*!? ha!
Wake up, get coffee, start jeep, drive to work.
Shouldnt be an issue unless you have a weak battery or bunk coolant in your system
Build thread^^
riot1987 is offline
post #7 of 118 Old 01-05-2014, 02:38 PM
mckellyb
Make sure you roll keep the windows rolled up...
I'm considering firing up the still new-to-me 5.9L tomorrow AM, supposed to be 15F here in Fort Worth.
It's been sitting for two complete days, and before I replaced the distributor cap, rotor, wires, and plugs, they were originals...with 163K miles on 'em, and even when 70F, it'd cough and hack on cold start.
White '98 5.9L as a dedicated towed car, 175K miles, bone stock
2008 LS 460L, my DD
mckellyb is offline
post #8 of 118 Old 01-05-2014, 02:39 PM
LilyBayXJ
Agreed, my LJ gets cold-started in sub-zero temperatures multiple times a day throughout January. You definitely have no reason to worry.
2006 LJ - 4.0L, NSG370, 31's
2001 XJ - 4.0L, AW4, 3.5" lift, 31's
1997 TJ - 2.5L, AX5, 2.5" lift, 32's - Sold
1983 CJ-5 - Stock - Sold
LilyBayXJ is offline
post #9 of 118 Old 01-05-2014, 02:45 PM
streetzj
I want to represent the Minnesotans on here and say that 5 degrees is t-shirt weather. Unless your battery is old, you'll be just fine, maybe tap the throttle just a bit when you're starting it if you have a weak fuel pump.
I was actually just gonna post if I should run mine occasionally during this spell of -23 nights and -13 days, but I'm sure some Alaskan or Canadian will respond that I'm a wimp.
streetzj is offline
post #10 of 118 Old 01-05-2014, 02:49 PM Thread Starter
RoldGold
Haha, I'm eating my words.
Thanks everyone, I won't worry and try to grow a pair while I'm at it
RoldGold is offline
post #11 of 118 Old 01-05-2014, 02:51 PM
OverlandZJ
LOL..
You forgot to mention the overnight low of -20 with wind chill.
post #12 of 118 Old 01-05-2014, 02:55 PM Thread Starter
RoldGold
Originally Posted by OverlandZJ View Post
LOL..
I figured it best not to dig myself into an even deeper hole, especially since xcaliber81 has experienced negative 31 fahrenheit, without wind chill.
RoldGold is offline
post #13 of 118 Old 01-05-2014, 03:15 PM
wjkrostek
2012 KK Liberty
wind chill only effects live things not machines. -20 is -20 no matter how much the wind is blowing. It will cool faster but not more. I run 0-30 oil summer and winter up here in Alaska in tractors that I use in the winter so there is less drag on the starter. Of course up here if it get in the 70's in summer that is hot day. Lite oil and good battery is all you need unless it's -40. If it's that cold stay home if you can. Bad things can happen to machines and people in the cold. Start moving slow for the first few miles so she can warm up before you hit it.
wjkrostek is offline
post #14 of 118 Old 01-05-2014, 03:24 PM
mckellyb
THANK YOU!!!!
It is disturbing how this is lost on people.
Regardless, I find the while 'wind chill' thing dubious, at best.
When we were up in Fairbanks, it was mid-80's. State fair time of year, so August.
2008 LS 460L, my DD
mckellyb is offline
post #15 of 118 Old 01-05-2014, 03:30 PM
mudder53
I keep the block heater plugged in over night and reaches around -50F windshield around here. Starts up just fine
mudder53 is offline
Closed Thread
