Genright Hood louvers<< mini write up>> - JeepForum.com
post #1 of 13 Old 06-17-2010, 09:19 PM Thread Starter
xgerstandtx
Hey guys, Thought I would do a little write up for the guys that are interested in these but a little skeptical about cutting into the hood on your zj. Maybe this will give you a little confidence.
Ordered in my genright hood louvers. Really like the quality of them and the packaging was top notch. I called them and had them in three days which is pretty impressive.
Tool list
1'' painters tape
tape measure
metal rule
1/8 drill bit
Drill
4 1/2 grinder w/ cutoff wheel
sharpie for marking holes
Pop rivit gun
PATIENCE!!!
On to the cutting:
This is how I measured and got an idea of where my 14'' louvers will go. Marked the underside of the hood.
A picture of the under hood. You can get an idea of where the best to locate them is.
Using the 1'' tape to line up everything. You should get the idea from just checking the pics.
I had a pretty large box that i used under the hood to shield of sparks and drill filings.
First Cut is always the hardest. cut it with a 4 1/2 cut off wheel on the angle grinder. The lines turned out very straight and was happy with the result.
Both holes cut. YOu get the idea of what cooling benefits it will have.
Mounted. Used a pop rivit gun and an 1/8 drill bit. Pretty standard. I am happy with the look.
Initial impressions are about 7-8 degrees cooler on the thermostat. The heat billowing out of them is pretty good. I would imagine the vacuum that they create is pretty significant. The real test will be the next few weeks when luggin around on the trails.
xgerstandtx is offline
post #2 of 13 Old 06-17-2010, 09:34 PM
Meaninglessphot
Looks great man. Ive been tinkering with the idea of adding hood louvers. Doesnt sound too hard to do neither.
Meaninglessphot is offline
post #3 of 13 Old 06-19-2010, 08:58 PM
Spike300
any pics of the underside of the final product?
5.2-242 tcase-44a-30x9.50x15 MT/R-American Racing Burst Rims -Optima -E3 plugs-Custom Paint-Amsoil-Addco Front and Rear-polyurethane bushings
To be installed: RE gen2 discos, military battery terminals
To be rebuilt: HP30
To be received:
To be paid for:
Next on the list: complete redo of brakes and
lines
Needed: fittings, coil of brake tubing, Russel speed bleeders
Zombie Outbreak Response Unit #75
Spike300 is offline
post #4 of 13 Old 06-20-2010, 01:06 PM Thread Starter
xgerstandtx
post #5 of 13 Old 06-20-2010, 09:12 PM
Spike300
thanks, should paint the underside of your hood
To be rebuilt: HP30
To be received:
To be paid for:
lines
Spike300 is offline
post #6 of 13 Old 06-20-2010, 09:28 PM
AEagle326
looks good, what about drip trays?
Andrew
1995 Grand Cherokee Orvis Edition
You can never go wrong with an Orvis.
AEagle326 is offline
post #7 of 13 Old 06-20-2010, 11:52 PM Thread Starter
xgerstandtx
Not sure what I am gonna do for Tray's. I will need something espeicially being in the PNW. What do you guys think?
As for paint the underside of the hood.... na really it doesn't matter under there.
post #8 of 13 Old 07-24-2010, 10:05 AM
MoparBoy01
Just looked at you build with your ZJ and then saw this mini build about the hood vents. Totally going to do the same thing on my ZJ now. Thanks for making a build write up about this and ZJ looks awesome.
1998 ZJ 4.0L-Trail Rig
1998 ZJ Black 5.9L-Prerunner/Daily Driver
1999 XJ 4.0L-Daily Driver/sometimes a weekend warrior
Down and Dirty Offroad Club Member
ddoffroad.com
MoparBoy01 is offline
post #9 of 13 Old 07-24-2010, 11:21 PM Thread Starter
xgerstandtx
I appreciate it. Sometimes is discouraging always posting and updating with minimal feedback. But I am glad it helps. The best way to build is take your time and choose parts wisely and hunt for good deals. Make your own build thread and keep us up to date. It's fun to see how your truck evolves.
post #10 of 13 Old 03-18-2011, 06:12 PM
zte87
GIVE IT THE ONION
zte87's Avatar
I just ordered these hood louvers I can't wait to get them on!
zte87 is offline
post #11 of 13 Old 11-27-2011, 04:41 AM
Degra101
where did you order them from ?
Degra101 is offline
post #12 of 13 Old 11-27-2011, 12:04 PM
StrokedWJ
StrokedWJ's Avatar
I've got the same vents but put them in a different location on the hood. I don't have drip trays and didn't want the trays directly over the fuse box and the air intake. I hope you were smarter than me and either covered up the windshield or directed the sparks away from it...I learned the hard way!
2000 WJ 4.5L - Stroked, Locked, & Long-Armed
Looking for 6" WJ springs!
StrokedWJ is offline
post #13 of 13 Old 12-01-2011, 01:12 AM Thread Starter
xgerstandtx
ha, yeah i ended up cutting them with the sparks shooting away from the windshield. They just wouldn't fit in the center of the hood where i really wanted. them.
Genright hood louvers done w/pics HighLonesome ZJ Grand Cherokee Forum 28 01-30-2013 06:30 AM
Hood Louvers StrokedWJ ZJ Grand Cherokee Forum 16 07-01-2009 03:30 PM
New mod, 5.9L hood louvers WhiteOut Grand Cherokee General Discussion 3 06-11-2009 01:25 AM
Hood Louvers Good For Zj???? -cAcHe- ZJ Grand Cherokee Forum 11 04-21-2009 12:22 PM
5.9 Hood Louvers kennedymr ZJ Grand Cherokee Forum 7 04-20-2009 12:46 PM
