Gear ratio - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Gear ratio
Labor Day Sale at UCF!Gibson WK HEMI 3" Catback - 5 Day Special!Ruffstuff XJ Unirail Channel Reinforcement....
Unread 08-16-2015, 07:29 PM   #1
Jeeplife8
Gear ratio
I need help finding out what gear ratio my front end has I have a 01 grand Cherokee and need to replace front end
Jeeplife8 is offline   Reply With Quote Quick reply to this message
Unread 08-17-2015, 05:41 AM   #2
SnowLeopard
I was going to ask what your WJ's specs are; model - Overland, Limited, Laredo; etc. I think this will help more though.
http://www.jeepforum.com/forum/f12/b...specs-3020169/
Yes, it snows in Texas.
SnowLeopard is offline   Reply With Quote Quick reply to this message
Unread 08-17-2015, 08:25 AM   #3
99WJ539918
Unless you're the original owner the only 100% positive way to find out is to remove the diff cover. 99% of the time pulling a factory build sheet will be fine. You can also jack up the front or rear and rotate the driveshaft and see how many rotations compared to the tires on that axle. Stock gear ratios are 3.55's and 3.73's. Since those ratios are close it might be kind off difficult to see the difference between 3.55 and 3.73 rotations unless you're paying close attention.
99WJ539918 is online now   Reply With Quote Quick reply to this message
Unread 08-17-2015, 02:25 PM   #4
Jeeplife8
Thanks it don't have the tow PAC so I'm leaning more towards the3.55
Unread 08-17-2015, 02:26 PM   #5
Jeeplife8
Does any body on hear no were to find the cheapest front end for one
Unread 08-17-2015, 03:45 PM   #6
99WJ539918
Junkyard, craigslist, or someone parting one out.
Unread 08-17-2015, 05:20 PM   #7
Jeeples
Elbows Deep In WJ's
Jeeples's Avatar
What engine?
All V8's received 3.73 gears, regardless of being equipped with the factory tow package.
I6 motors will have 3.55's if they do not have the factory tow package.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Build Thread
Real men run the stock rear sway bar at any height
Jeeples is online now   Reply With Quote Quick reply to this message
Unread 08-17-2015, 08:33 PM   #8
SnowLeopard
Originally Posted by Jeeples View Post
What engine?
In the previous generation, the ZJ with an I6 and the tow-prep package came with 3.73 gearing. So you might check to see if that's listed on your build sheet. If it's got an I6 without either the tow-prep package or the tow package, then it will default to 3.55. This is if the rules for the ZJ apply to WJ's.
Unread 08-17-2015, 11:44 PM   #9
Kolak
Vendor
Kolak's Avatar
You can also look for the bill of materials number stamped onto the axle tube. It will start with the number 6. If you find that, I can look up what ratio you've got.
Kolak Performance and Offroad
Member: Specialty Equipment Market Association
Telephone: 480 998-3661
kolak@aol.com or kolak@kolakperformance.com
Kolak is offline   Reply With Quote Quick reply to this message
