GCJEEPING's Build/Mod thread-It's a green thing- - Page 6 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > GCJEEPING's Build/Mod thread-It's a green thing-
KrawlOff-Road.com Sale EventFS: Jeep Fog Light LED Bulbs! Several Brightness Options! *STOP UNWANTED LIGHT BAR NOISE* with Pandemic LED Light Ba
Unread 04-29-2012, 11:15 AM   #76
Dasko
looks good man say goodbye to that rear view mirror haha
[CENTER]
2005 Grand Cherokee Limited - 5.7 [COLOR="Red"]HEMI[/COLOR] - QDII - 2" Rough Country BB - AFE Stage 2 CAI - Monkey Navigated - Rear Shackle
2001 WJ- SOLD
[QUOTE=mrJ]It's a Jeep, it's not supposed to work right all the time.[/QUOTE][/CENTER]
Dasko is offline   Reply With Quote Quick reply to this message
Unread 04-29-2012, 12:08 PM   #77
gcjeeping
gcjeeping's Avatar
Lol, no big loss. Usually have the back filled up anyway with gear and spare. This will just give me more room for gear. Maybe ill get one of those bu cameras.
__________________________________________________ _________
-GCJEEPING's build/mod thread-IT'S A GREEN THING...
gcjeeping is offline   Reply With Quote Quick reply to this message
Unread 04-29-2012, 04:48 PM   #78
Dasko
That'll be good for on the trail as well.
[CENTER]
2001 WJ- SOLD
Unread 05-17-2012, 09:20 PM   #79
gcjeeping
gcjeeping's Avatar
Well finally tire carried almost done and back on.
Primed and painted the parts. Used rubberized under coating on the parts where the gas cans sit as well as the bottoms of the plates that hold the cans down.
Made the hold downs for the cans. Welded a piece of pipe to the tops of the all thread to use as handles. The cut a piece of rod to go through handles with a washer welded at one end and a hole for a lock at the other.
Unread 05-17-2012, 09:31 PM   #80
gcjeeping
gcjeeping's Avatar
Made the latch spring loaded like the locked open one. Also made it auto locking by building an angled piece to push the pin up.
Incorporated the receiver into the bottom support. Did a root and two cover passes on all attaching points. Also added 6 gussets to another cross member for extra support. Then cut a 1/4 plate piece for safety chain connection.
Put the high lift on. Think I'll get a 48" one. The 60" sticks out some.
Finally all together.
Unread 05-18-2012, 08:54 AM   #81
gcjeeping
gcjeeping's Avatar
Onto finish the tank lift.
Got everything cut. Wire wheeled it and gave it a coat of primer, rubberized undercoating and satin black paint. Put the tank back into the skid.
Cut a couple holes in the uniframe for the hoses. Welded in a couple pieces of exhaust tube. Primed, rubberized coating and painted.
Tank in. Also replaced the fuel filter since it was right there.
Just gotta make the cover now.
Unread 05-19-2012, 06:14 PM   #82
gcjeeping
gcjeeping's Avatar
Tried to take somethings home from a cruise-in Friday night.
Unread 05-24-2012, 08:26 PM   #83
gcjeeping
gcjeeping's Avatar
Put a Wrangler gas filler panel on. Was a freebee.
Unread 05-28-2012, 07:30 PM   #84
gcjeeping
gcjeeping's Avatar
Found a guy on craigslist prating out a WJ. Went and looked at it. Was getting pretty picked over. But pulled all for doors, auto/fog light stuff, auto dim rear view and homelink/sunroof EVIC. $60 bucks well spent. Now time to fab another set of half doors.
Unread 06-14-2012, 10:36 PM   #85
Timbo24
When you movin to Idaho!
Timbo24 is offline   Reply With Quote Quick reply to this message
Unread 06-15-2012, 06:14 AM   #86
gcjeeping
gcjeeping's Avatar
Not sure yet. Wife put in for a job out there. It closes in 3 weeks then she will know if she got it.
Unread 06-28-2012, 05:16 PM   #87
gcjeeping
gcjeeping's Avatar
Played her a little rough last weekend. Finally took out the front axle shafts on the last day of wheeling. After over 11 years they lasted well. Already putting the new parts in. Also decided to replace the hubs since I was at.
Unread 07-06-2012, 10:00 AM   #88
wj4play
Just FYI I had read on another thread on this site that the JK hubs(32 spline) will fit in the WJ knuckles, with that said you would need custom shafts (RCV) but throw a 30spline OX locker in it and you would ALMOST be as strong as a stock 44. Except the R&P
Nice build and BTW, I heard you were running a 46rh tranny??? I didnt read every post but looked at all the pretty pictures
wj4play is offline   Reply With Quote Quick reply to this message
Unread 07-19-2012, 04:52 PM   #89
gcjeeping
gcjeeping's Avatar
Well after a good wheeling trip a couple weeks ago I felt that my old battery was on its last leg. So I decided go dual like theksmith but keep mine up front. He liked my spare tire well mod so I figure I'd copy his dual battery mod.
Started with 2 group 34/78 Diehard Platinum. 850 CCA, 135 Minutes of reserve capacity, AGM (Absorbed Glass Mat) construction, 4 year free replacement and 10 year prorated.
Blue Sea ACR as my isolator/combiner. LINK
Old battery and fuse block moved out of the way.
Battery tray in work. Staggered the batteries to clear the hood. It will bolt to all the original battery tray locations.
Batteries test fitted in tray. I built a lip for each of the batteries that the bottoms will slip into. Will build a top hold down later.
Tray and batteries test fitted in the jeep. Will need to notch the braces in the hood in two places slightly to clear one of the posts and front pass side of front battery.
New location for fuse block. Will build bracket for it later.
Tray painted and installed.
Isolator mounted to the top of the fuse box.
Batteries and isolator installed. Hold down installed. Used 1/0 wire for the winch and from the batteries to the isolator. Kept the 4 gauge from the original wiring for the rest. Also upgraded to 2 gauge wire for from the Mean Green alt to the battery.
Finished product. Only thing left is running the switch for the isolator into the cab. Fired it up and everything worked as advertised. Not much room left in the engine bay for many more mods.
Unread 07-19-2012, 07:04 PM   #90
teckman02
that came out good dave
teckman02 is offline   Reply With Quote Quick reply to this message
