GCJEEPING's Build/Mod thread-It's a green thing- - Page 5 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > GCJEEPING's Build/Mod thread-It's a green thing-
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LinePoison Spyder JK Body Mounted Tire CarrierBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft Ki
Unread 04-15-2012, 09:42 PM   #61
gcjeeping
gcjeeping's Avatar
Yeah. But it was nice to have alot of crap out of the way in the spare well. Air tanks, compressors, straps and tools. Just gotta find a new home for the misc stuff.
__________________________________________________ _________
-GCJEEPING's build/mod thread-IT'S A GREEN THING...
gcjeeping is offline   Reply With Quote Quick reply to this message
Unread 04-20-2012, 04:47 AM   #62
tofuzeppelin
tofuzeppelin's Avatar
Hey Great Build Man, I ed at your intake set up in post #48, how do you like that set up so far? And cool find on the scoop, how's it holdin up with low branches?
01 TJ with some stuff
01 XJ with no rust
76 Ford with both
WTB TJ hard top, let me know what cha got
tofuzeppelin is offline   Reply With Quote Quick reply to this message
Unread 04-20-2012, 10:52 AM   #63
Spike300
Did you milage change at all with the snorkal?
[url]http://www.jeepforum.com/forum/f197/camo-beast-975063/[/url]
5.2-242 tcase-44a-30x9.50x15 MT/R-American Racing Burst Rims -[COLOR="Red"]Optima[/COLOR] -E3 plugs-[COLOR="DarkGreen"]Cu[/COLOR]st[COLOR="DarkGreen"]om[/COLOR] Pa[COLOR="DarkGreen"]in[/COLOR]t-Amsoil-Addco Front and Rear-polyurethane bushings
[B]To be installed[/B]: RE gen2 discos, military battery terminals
[B]To be rebuilt:[/B] HP30
[B]To be received:[/B]
[B]To be paid for:[/B]
[B]Next on the list:[/B] complete redo of brakes and
lines
[B]Needed:[/B] fittings, coil of brake tubing, Russel speed bleeders
Zombie Outbreak Response Unit #75
Spike300 is offline   Reply With Quote Quick reply to this message
Unread 04-20-2012, 11:23 AM   #64
gcjeeping
gcjeeping's Avatar
Thanks. So far I love it. I turn it around backwards when I wheel. That way any branches or brush just roll over it.
Dont know. Dont think so. Dont have any loss of power. Never really kept track of mpg. Dont wanna scare myself my calculating it. 6" lift,33's, half doors, lots of extra weight, roof rack, offroad lights and loss of aerodynamics. I'm sure its around 15. But the fun is worth it.
On another note. Finishing up a remodel of my kitchen so should be back to working on the jeep this weekend.
Unread 04-22-2012, 07:42 PM   #65
gcjeeping
gcjeeping's Avatar
Alright kitchen remodel done. Back to work on the jeep.
Got the supports cut and drilled. Spindle support welded on and 2x4 cut and welded onto supports.
Also started rust busting the gas tank skid. Drilled out he spot welds and separated the brackets from the skid. Lots of rust between them. Will weld them back together when I shorten the skid. The hold down straps were rusted pretty bad. Wire brushed them and metal etch primed them and put several layers of Rustoleum on them.
Pressure washed the tank to get the mud and dirt off.
Unread 04-23-2012, 07:30 PM   #66
gcjeeping
gcjeeping's Avatar
Got a little more done on the bumper before I had to go help a friend work on his car.
Unread 04-23-2012, 08:19 PM   #67
clgielin
2003 WJ
I need to get started on something resembling a rear bumper/tire carrier. Looks like a good start! What are you going to do with the hole in the floor?
Chris
2003 WJ 4.7L
Build Thread Here: 2003 WJ
Michigan Tech Jeepers #4
Utah JeepCrew #16
clgielin is offline   Reply With Quote Quick reply to this message
Unread 04-23-2012, 08:34 PM   #68
gcjeeping
gcjeeping's Avatar
Thanks. Should be able to work on the hoop and latch tomorrow. I have a piece of 12 steel to cover the hole. Gunna weld it in and cut an access hole for the fuel pump in case I need to get to it in the future.
Unread 04-24-2012, 07:46 PM   #69
gcjeeping
gcjeeping's Avatar
Made the stop for the carrier. Kinda like dcdriller used on his. I added piece to stop from pulling the pin too far up also.
Unread 04-26-2012, 04:20 PM   #70
gcjeeping
gcjeeping's Avatar
Got the hoop done for the spare tire carrier and supports for the gas cans. Gotta run to the scrap yard tomorrow and get a 1 1/2 x ? for the tire support. Also see if they have any round plate laying around. If not I'll cut a triangle from the 1/4 plate I have.
Unread 04-27-2012, 05:39 PM   #71
gcjeeping
gcjeeping's Avatar
Used my plasma cutter for the first time today. Made the plate for the tire holder. Cuts like butter, but you need a steady hand.
Unread 04-27-2012, 08:18 PM   #72
gcjeeping
gcjeeping's Avatar
Did a little more welding and test fitting. Will weld a few more braces/gussets tomorrow.
Unread 04-27-2012, 08:26 PM   #73
paulyboy
Sick wj nice mods i love custom d i y stuff.
ENTER WITTY COMMENT HERE ________________
paulyboy is offline   Reply With Quote Quick reply to this message
Unread 04-28-2012, 06:53 AM   #74
billyzj
1994 ZJ
nice tc, im trying to do a similar one on mrj jeep
billyzj is offline   Reply With Quote Quick reply to this message
Unread 04-29-2012, 10:40 AM   #75
gcjeeping
gcjeeping's Avatar
Thanks, it's fun building from scratch. Takes a while though figuring things out.
I've been watching his and thisguyhasadd2 spare tire carrier threads.
