GCJEEPING's Build/Mod thread-It's a green thing- - Page 12 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > GCJEEPING's Build/Mod thread-It's a green thing-
Steering and more from Ruffstuff!Ruffstuff Axle Simple Swap Kit!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 12-06-2012, 07:47 PM   #166
Thomahawk
Just orderd one right now, ha ha
Look at this on eBay:
HYBRID Sticker Green Decal Environmental
http://bit.ly/TFYDkz
Green Machine - Hybrid Car - Window Bumper Sticker
http://bit.ly/TIotbj
Buildthread [url]http://www.jeepforum.com/forum/f197/jeep-norway-2th-buildt-overland-upgrade-1813490/[/url]
Thomahawk is offline   Reply With Quote Quick reply to this message
Unread 12-06-2012, 07:50 PM   #167
gcjeeping
gcjeeping's Avatar
LOL, every time I go to the junk yard I try to find one.
I like this but in black...
Or this...
__________________________________________________ _________
-GCJEEPING's build/mod thread-IT'S A GREEN THING...
gcjeeping is offline   Reply With Quote Quick reply to this message
Unread 12-07-2012, 10:43 AM   #168
grand2000
Or this...
I've got a Prius hybrid one. I was gonna use it to make a selec-drive hybrid badge. Never used it.
grand2000 is offline   Reply With Quote Quick reply to this message
Unread 12-09-2012, 12:12 PM   #169
dahlonegawj
Now if you're backing out of a parking spot and someone hits you, they can't use the excuse "I couldn't see you"
2002 WJ Limited 4.7 V8
245/65/17 Falken Rocky Mountians
Quadradrive and a CB
dahlonegawj is offline   Reply With Quote Quick reply to this message
Unread 12-09-2012, 03:09 PM   #170
gcjeeping
gcjeeping's Avatar
Either that or something from Close Encounters of the Third Kind.
Unread 12-16-2012, 07:16 PM   #171
gcjeeping
gcjeeping's Avatar
My WJ Dash Mod
Got tired of my CB bolted to the top of the dash. So I cut it up and fitted the radio, CB, and Whelen controller into it and made a cover. The Whelen controller is wired up to control all the lights, OBA back up lights, rock lights and future accessories.
First, cut up the dash to make room.
Took some sheet metal and made a faceplate. Also cut a hole for the switch that controls my dual battery isolator. Was going to paint it black but found some carbon fiber stick on vinyl at Pep Boys on clearance.
So since I had the carbon fiber I decided to copy Thomahawk and do the other trim pieces also in the center console. The bottom of piece of the console I had contained the ashtray. But since I had another one with a cubby I decided to use that and put a speaker I had laying around for the external CB speaker. Fit perfect. I had to cut the top off the vent panel for this mod.
Next I made the cover. Used wood for this. Put a curve on the back and rounded the sides. Then I put a layer of bondo and formed it to the shape I wanted. Finally I covered it with black vinyl. I tried to match the gray but couldn't. If I fine some later I will recover it.
Unread 12-16-2012, 07:17 PM   #172
gcjeeping
gcjeeping's Avatar
I picked up a fuse box from a local liquidation place for 3 bucks so I can try and keep everything tidy under the hood since I'm usually not doing that.
I fabbed a bracket for the fuse box from some scrap I had and mounted it to the batt hold down. Also some of the relays are from an early XJ engine bay. They are nice since the have the receptacle and are modular.
I made a cover for it from some scrap plastic I had. I heated it up with a heat gun and formed it to cover the fuse box.
I made a bracket for all the relays I was going to use for the Whelen controller.
Used wire loom under the hood to cover all the wiring I added.
The Whelen didn't have covers for the selectors for the switches so I went on line and found picks of switch labels and made some for mine. Used Power Point to make the symbols. Printed them and then used laminating paper to cover them. Cut them out and inserted them into the Whelen.
Unread 12-16-2012, 07:17 PM   #173
gcjeeping
gcjeeping's Avatar
When the Whelen is on the switch labels show green, but when you select one it changes to red. I have the slider switch set up to Pos 1= KC lights, Pos 2= Both LED light bars and Pos 3= KC's and light bars together. I also have them set up that they will only come on when the high beams are on. Also Its nice now to have the Blue Sea batt isolator switch installed so now I can switch the batt's from 1 to 2 to off from the cab.
Finally all assembled and working. And yes I do have an external PA speaker on top and the sirens work. I have a kill switch hidden to disable the PA just in case PO-Po has a problem with the Whelen in the Jeep. I also have the CB hooked into the Whelen so it can rebroadcast the CB ext speaker through the PA. All in all I like it.
Unread 12-16-2012, 08:14 PM   #174
Spike300
That is awesome totally gave me more ideas for what i want to do
[url]http://www.jeepforum.com/forum/f197/camo-beast-975063/[/url]
5.2-242 tcase-44a-30x9.50x15 MT/R-American Racing Burst Rims -[COLOR="Red"]Optima[/COLOR] -E3 plugs-[COLOR="DarkGreen"]Cu[/COLOR]st[COLOR="DarkGreen"]om[/COLOR] Pa[COLOR="DarkGreen"]in[/COLOR]t-Amsoil-Addco Front and Rear-polyurethane bushings
[B]To be installed[/B]: RE gen2 discos, military battery terminals
[B]To be rebuilt:[/B] HP30
[B]To be received:[/B]
[B]To be paid for:[/B]
[B]Next on the list:[/B] complete redo of brakes and
lines
[B]Needed:[/B] fittings, coil of brake tubing, Russel speed bleeders
Zombie Outbreak Response Unit #75
Spike300 is offline   Reply With Quote Quick reply to this message
Unread 12-16-2012, 08:25 PM   #175
gcjeeping
gcjeeping's Avatar
Cool, Cant wait to see your creation.
I guess its technically a triple din. LOL
Unread 12-17-2012, 08:33 AM   #176
teckman02
dave that came out good at some point we may have to do something like this to my dash
teckman02 is offline   Reply With Quote Quick reply to this message
Unread 12-17-2012, 08:58 AM   #177
gcjeeping
gcjeeping's Avatar
Get to designing.
Unread 12-17-2012, 12:06 PM   #178
redbeard144
1994 ZJ
that is a nice wj. like the cut doors and the new roof rack.did you ever try the harbor freight bender before you return it.what made you cut your fenders with the smaller tires on it .did they rub?
redbeard144 is offline   Reply With Quote Quick reply to this message
Unread 12-17-2012, 12:44 PM   #179
gcjeeping
gcjeeping's Avatar
Thanks. The doors are great. I never used the HF tube bender. I went with a JD3 tube bender. Thats what I have used for all my tube so far.
Yeah the 33's look small now. I did have rub at full flex in the back. Figured I cut now and then go to 35's.
Unread 12-17-2012, 02:52 PM   #180
RedZJ
That is killer dude. I so wanna do this.
RedZJ is offline   Reply With Quote Quick reply to this message
