Gas or diesel for towing a 5k GVWR trailer? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Gas or diesel for towing a 5k GVWR trailer?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineBilstein Shock Upgrade Kits, Jeep JK TJ XJ Wranglers and CJeep Wrangler Complete Gear Upgrade Kits with Installs and
Unread 02-17-2015, 11:35 AM   #1
LORIENOAKS
Was wondering if anyone might provide some insight on this. I am buying a new JGC Limited w/ tow package so the gas version rated at 6200 lbs towing capacity should be adequate to pull a trailer up to 5000 lbs. I will be towing through the Rockies; would the turbo-diesel be worth the extra expense??
Any help is appreciated!
LORIENOAKS is offline   Reply With Quote Quick reply to this message
Unread 02-19-2015, 03:27 PM   #2
madmax
Turbo diesel engine is better for pulling heavy trailers. I didn't know that there is a Jeep with turbo-diesel engine? I know Fords have them.
2000 WJ 4.0L, drop-in K&N filter, Addco rear antisway bar, Bridgestone Revos, Overhead DVD monitor w/ wireless headsets.
2007 BMW 335i, Montego Blue with Lemon seats, premium & sport package.
2004 TJ Sport 4.0L - SOLD :(
madmax is offline   Reply With Quote Quick reply to this message
Unread 02-19-2015, 03:41 PM   #3
87thhunter
Diesels are always better for pulling period.
Things to think about though
How often will you NOT be pulling the trailer vs pulling it
Oil changes will even cost more
The cost to fix any engine/transmission problems, gas engines can cost a fortune, diesels cost ALOT more
Fixing it will cost more period at the dealer it says diesel, most dealers will charge more to do ANY work just because it says diesel on it....'
Then again what are you going to save in fuel vs. the expense of the diesel. I don't recommend getting a little v6 gas, IF you chose the gas route get the biggest engine they offer if your going to tow ALOT, if they offer a v6 middle size v8 and a huge v8 just weigh your options.
Basically if all your buying it for is to tow, buy a pick up truck, if you need to tow the trailer once or twice a year get the v8 gas. Again this is how i would look at it.
Also not all diesels are good research ANY motor and see how there holding up, you may tow better but don't mean it will last.
87thhunter is offline   Reply With Quote Quick reply to this message
