Front Wheel Vibration during high speeds - JeepForum.com
post #1 of 3 Old 05-15-2013, 04:43 PM Thread Starter
Frugal
2000 FSJ Cherokee
Hello All.... was just wondering if anyone knew about the cause the and the necessary repair for a horrible front-wheel vibration a 2000 Jeep Grand Cherokee at speeds of 45-70 mph. It's very noticeable now with the warm weather on the roads, but less during cold, winter months. I've had the tires balanced and the the entire set of shock absorbers changed out. Could the control arms be worn out? My Jeep is 2000, Grand Cherokee Laredo with 148k miles on it so far. I would luv to keep this awesome Jeep vehicle ! Please advise ! Thank you so very much !!
Frugal is offline
post #2 of 3 Old 05-15-2013, 04:45 PM
squashman702
1994 ZJ
Check cv shafts, wheel bearings, and diff fluid for metal.
Think Twice Garage
"I guess I'd just run it?"
squashman702 is offline
post #3 of 3 Old 05-27-2015, 08:39 PM Thread Starter
Frugal
2000 FSJ Cherokee
Thanks squashman702.. the cv shafts are shot... the wheel bearings are not bad, but they're worn... and the diff fluid has no metal... just dirty. Guess it's time for replacing all items. Any suggestions where to start to remove and replace the CV shafts ??
Thank you in advance !
Frugal is offline
