**Froggo27's Build Thread** - Page 3 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > **Froggo27's Build Thread**
Unread 04-05-2008, 12:42 AM   #31
SpeedyCat3
Survivor
SpeedyCat3's Avatar
Originally Posted by DixiesCJ3B View Post
Looks great Keep us updated with lots of pics
Time to get those hubs painted or covered, and i noticed that you took off your front head light covers, any reason ??
I do not think you ever met Rrubio.......
_o o o o_
|_Jeep_|
(OlllllllO)
[] ---o-[]
My 97 ZJ Build
SpeedyCat3 is offline   Reply With Quote Quick reply to this message
Unread 04-05-2008, 08:40 AM   #32
_Kyle_
_Kyle_'s Avatar
Originally Posted by a70eliminator View Post
Just curious as to your MX6 adjuster knobs, how easy it to reach the adjuster on your rear shocks? I see skinny end down on the fronts putting the knob at the bottom and skinny side up on your rears putting adjuster knob on the top. On mine I put the adjuster down on the rears.
The adjuster nobs are supposed to be mounted down for best performance. There is a big "NOTE" on the instruction page attached to them stating that. I do think the nob is kinda hard to turn, I want to order my speed key from them but have yet to do so.
-Kyle
1996 Grand Cherokee
2005 Wrangler Rocky Mountain Edition
RIP Troy (bigbluezj94)
Kyle's TJ Build
_Kyle_ is offline   Reply With Quote Quick reply to this message
Unread 04-05-2008, 09:27 AM   #33
nierace
nierace's Avatar
2003 WJ
Nickerdoodle
03 WJ 4.7 242HD Kolak/IRO 5" Clayton LA's
35" BFGoodrich KM2
sira4x4.net North East Offroad Club
www.carolinadriveline.com
www.ironrockoffroad.com
kolak@aol.com
nierace is offline   Reply With Quote Quick reply to this message
Unread 04-05-2008, 04:33 PM   #34
froggo27
Originally Posted by 87Xota View Post
First time I've seen your build thread, rig looks awesome!!, glad I get to contribute to the build this weekend
Oh i am glad too!!!!
Its VERY easy access for the rear knobs but the fronts are a pain to get to.
Kamil
04 WJ Limited
My Trail Pics!!
froggo27 is offline   Reply With Quote Quick reply to this message
Unread 04-05-2008, 04:35 PM   #35
froggo27
Well the Jeep is under the knife this weekend.
Adding 4.56 gears, rear Aussie locker, front diff cover....
thanks to 87xota.
Kamil
04 WJ Limited
My Trail Pics!!
Unread 04-05-2008, 04:37 PM   #36
froggo27
here is the cover, i painted it red because i thought it look good.
Kamil
04 WJ Limited
My Trail Pics!!
Unread 04-05-2008, 04:37 PM   #37
TX-WJ
TX-WJ's Avatar
Looking sweet Froggo
IIRC, the MX6s should be mounted adjuster knob down both F&R; that's how I did mine anyways
Edit: I just noted Kyle posted the same thing
David.
2004 WJ Ltd. (steel blue pearlcoat)
4.7, 242 HD swap, 6" Clayton's, 35" BFG KM2s, F/R chromo'd JK Rubi D44s
TX-WJ is offline   Reply With Quote Quick reply to this message
Unread 04-05-2008, 04:46 PM   #38
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
that is the RSS cover right??
hard working private first class in the United States Marine Corps.
Originally Posted by shift_grind View Post
It's threads like this that make me wonder why people lift there jeeps
its comments like this that make me wonder why some people are jerks.
build thread:http://www.jeepforum.com/forum/f197/...ndard-1056365/
5.9 ANDY is offline   Reply With Quote Quick reply to this message
Unread 04-05-2008, 04:47 PM   #39
froggo27
Not to burst anyones bubble or self cofidence but they can be mounted "upside down" in the back, wont hurt anything. I've already had plenty discussions about this and its ok.
Kamil
04 WJ Limited
My Trail Pics!!
Unread 04-05-2008, 04:47 PM   #40
froggo27
Yes it is.
Kamil
04 WJ Limited
My Trail Pics!!
Unread 04-05-2008, 04:52 PM   #41
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
Originally Posted by froggo27 View Post
Yes it is.
can you do me a favor and take a pic of it next to the stock cover, i need to know if it stick out farther foward than the stock cover.. thanks.
Unread 04-05-2008, 04:52 PM   #42
TX-WJ
TX-WJ's Avatar
OK, be like that, but when your rear end bounces off a big rock and you flip over your nicely built WJ (no exo-cage on) out in the trail, let us know so I can remind you that we told you so.... j/k
Unread 04-05-2008, 05:30 PM   #43
froggo27
Been off plenty of rocks and no problems yet, but i'll keep you in mind and let you know when that happens
Kamil
04 WJ Limited
My Trail Pics!!
Unread 04-05-2008, 05:49 PM   #44
mendelmax
Froggo27 is right, monotubes work the same way in every position, because as the name says, they have only one tube, so no gas to escape from one chamber to the other like in twin-tubes. They advise to use them "upside down" for two reasons- to limit unsprung weight (with the weight of axle and wheels, shock body won't make much difference ) and to protect the body from damage. The second one is a bit more serious, but still I can't see many situations when you can bend it.
Froggo27, great rig, congratulations!
But this red color on the cover... hmmm... might be useful only if you loose your axle on the trail at dark night
POLISH JEEP OWNERS CLUB #11
Anyway, nothing will beat Suzuki :D
mendelmax is offline   Reply With Quote Quick reply to this message
Unread 04-05-2008, 05:59 PM   #45
wojtizzlator
1987 XJ Cherokee
its really not as bright as it seems. its a neutral red color not bright *** red. hehehe
Wojtek
"who needs paved roads when u have a jeep"
87 xj 6" long arm lift, 35's, 4.88 yukon gears, front detroit true trac
colorado jeep club member # 74
wojtizzlator is offline   Reply With Quote Quick reply to this message
