**Froggo27's Build Thread** - Page 5 - JeepForum.com
post #61 of 138 Old 04-15-2008, 06:03 AM
Diehard
Diehard's Avatar
Hello Froggo. Nice Jeep. Did you install extenders on the bumpstops? Previous pic it doesn't look like it. Hows the ride on the taller springs? I've got the UC spring and 2.5" spacer set-up, but when I get my winch & bumper, (one of these days from Kevin's), I'm thinking I'll need to go to a taller spring to compensate for the extra weight.
My Jeep is in the shop, laid it on its side, but it looks like they're going to fix it. It will be my off-road Jeep from now on, so I have more plans for it. Loved that write-up on the regearing. Must be nice to have all those tools. Thanks for any replies/opinions.
2004 GC Spec. Edit. V8 4x4 Quadra-Trac II. Bright Silver Metallic Clear Coat, 4" lift, RE shocks, adj. JKS CAs all around, 265/75/16, ProtoFab winch bumper, Vortex 10,000 lb. winch, dual OME steering stabilizer, Rockyroad rockrails, skids, JKS Discos. Addco front & rear sway bar, & Aussie locker.
Diehard is offline
post #62 of 138 Old 04-15-2008, 06:15 AM Thread Starter
froggo27
froggo27's Avatar
Originally Posted by Diehard View Post
Hello Froggo. Nice Jeep. Did you install extenders on the bumpstops? Previous pic it doesn't look like it. Hows the ride on the taller springs? I've got the UC spring and 2.25" spacer set-up, but when I get my winch & bumper, (one of these days from Kevin's), I'm thinking I'll need to go to a taller spring to compensate for the extra weight.
My Jeep is in the shop, laid it on its side, but it looks like they're going to fix it. It will be my off-road Jeep from now on, so I have more plans for it. Thanks for any replies/opinions.
Reason i got the gears was because i know i'm gonna go bigger.
No extended bumpstops. The ride is great i like it, no complaints, just get good shocks.
Kamil
04 WJ Limited
froggo27 is offline
post #63 of 138 Old 04-15-2008, 06:41 AM
Diehard
Diehard's Avatar
What setting do you use on your MX-6 shocks? I went with the middle/halfway setting. Thanks.
Diehard is offline
post #64 of 138 Old 04-15-2008, 08:43 AM Thread Starter
froggo27
froggo27's Avatar
I use about 2 in the front and 3 in the back..going from the softer side.
Kamil
04 WJ Limited
froggo27 is offline
post #65 of 138 Old 04-15-2008, 11:42 AM
mendelmax
Froggo, why did you set it softer up front than in the rear?
POLISH JEEP OWNERS CLUB #11
Anyway, nothing will beat Suzuki :D
mendelmax is offline
post #66 of 138 Old 04-15-2008, 12:58 PM
phant0omx
2012 WK
Originally Posted by mendelmax View Post
Froggo27 is right, monotubes work the same way in every position, because as the name says, they have only one tube, so no gas to escape from one chamber to the other like in twin-tubes. They advise to use them "upside down" for two reasons- to limit unsprung weight (with the weight of axle and wheels, shock body won't make much difference ) and to protect the body from damage. The second one is a bit more serious, but still I can't see many situations when you can bend it.
that makes sense, i was wondering how they are supposed to be orientated. i have my bilstein 5125s mounted with the boot down.
phant0omx is offline
post #67 of 138 Old 04-15-2008, 06:11 PM Thread Starter
froggo27
froggo27's Avatar
So when i hit the bumps in the crappy Colorado roads the shocks can take the initial impact...
Kamil
04 WJ Limited
froggo27 is offline
post #68 of 138 Old 04-15-2008, 08:40 PM
painted600rr
how wide are your soft 8s?
painted600rr is offline
post #69 of 138 Old 04-15-2008, 08:42 PM
Sporer65
Sporer65's Avatar
Location: Powder Springs, Georgia/University of Tennessee
If you look at his Jeep information under his avatar you will see they are 7" wide.
Ben
1993 Jeep Grand Wagoneer ZJ V8: Rear Aussie, 3.5" Lift, 31" M/Ts
Sporer65 is offline
post #70 of 138 Old 04-15-2008, 10:43 PM
GraKee99
Rapist Wit
GraKee99's Avatar
I will be up there in a month so I will know whether or not they are really that crappy cause Arkansas rodes are some of the worst.
Brian
WJ, WK, CJ5
GraKee99 is offline
post #71 of 138 Old 04-16-2008, 02:20 AM
mendelmax
Yeah, but front is heavier, so to make the ride optimal fronts should usually (I don't know if that works in your case, since suspension is far from stock ) be a little harder than the rears. Try 3/3 or 3/2 F/R, I bet you'll like this setup more.
post #72 of 138 Old 04-16-2008, 07:05 AM
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
there was a study done, it revieled that the the city that has the worst roads in the country is san fransisco.
hard working private first class in the United States Marine Corps.
Originally Posted by shift_grind View Post
It's threads like this that make me wonder why people lift there jeeps
its comments like this that make me wonder why some people are jerks.
build thread:
5.9 ANDY is offline
post #73 of 138 Old 04-16-2008, 08:23 AM
RyanZJ
RyanZJ's Avatar
Arkansas roads are NIIIICE compared to the roads up here. The constant melting/freezing of snow during the winter and spring here results in some tremendous potholes and frost heaves.
Ryan
'98 ZJ V8 Limited
'06 WK V8 Laredo
'51 CJ-3A
RyanZJ is offline
post #74 of 138 Old 04-16-2008, 11:14 AM
CLNinja
CLNinja's Avatar
yeah colorado roads suck
now imagine driving in my ZJ on them... 4.5" lift stock CA lol... i want LAs so bad
Matt
**September 2009 Grand Cherokee Of The Month**
CLNinja is offline
post #75 of 138 Old 04-16-2008, 12:01 PM
GraKee99
Rapist Wit
GraKee99's Avatar
They never work on our roads and all the 18 wheelers driving through at 75 over the years really beats them up but I know the freezing and melting is bad.
Brian
WJ, WK, CJ5
GraKee99 is offline
? about starting a build thread zjzach Grand Cherokee General Discussion 5 04-17-2009 06:00 PM
