Frenchy's Build - Page 5 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Frenchy's Build
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 03-28-2010, 11:14 PM   #61
cloiselle
i run a d35 front / d44a rear ( vari locks ) and haven't had a problem in 1 1/2 of heavy offroading in my wj. your d35 should hold up just fine, especially locked. I'd love to go with a long arm hc kit, but i simply refuse to modify any part of the unibody. even with proper prep and sealing , rust = the devil.
cloiselle is offline   Reply With Quote Quick reply to this message
Unread 03-29-2010, 08:59 AM   #62
rugermack
Do you mean d30 front/44a rear.
95' Jeep Grand Cherokee Laredo, 148k, 5.2, NP242, 46RH, 4" RC lift, all new adjustable ca's(2 IRO front uppers and the rest RC adjustables), nitro shocks, JKS TB's, Jet Chip, Dynamax cat back, Magnaflow cat, GTP hood vents. 31" Pro Comps with Rock Krawler "D"s. Westin brush/grill guard with Hella 500s, 411's, Solid diff covers, detroit locker rear, power lock in front, SYE and Tom Wood's front/rear shafts, RE discos, BPE's, d-rings front and back, factory tc and rad skid, hitch, Sliders next.
03' Jeep Grand Cherokee Laredo, (wifes Jeep) 99k, 4.7 5 speed auto, K&N, KYB shocks, drilled-slotted rotors, All the toys.
2000' Ford Superduty, F250, 7.3, 198K, 37's, too much to list.
Built Not Bought #257
Parts for sale d30 and d35 parts http://www.jeepforum.com/forum/f126/...-parts-1004499
rugermack is offline   Reply With Quote Quick reply to this message
Unread 03-29-2010, 10:55 AM   #63
peicherokee
the front bumper build came to a hault when the rear bumper cover got ripped off trying to figure out what i am going to do with that.
THE MORE MUD THE BETTER
PEI JEEPERS MEMBER
peicherokee is offline   Reply With Quote Quick reply to this message
Unread 03-29-2010, 01:08 PM   #64
fireman33
2003 WJ
Ive never seen a d35 in the front ?? And for cutting the lca mount, im telling you its worth it if you want to go long arm. I live in eastern canada and the amount of salt they put on the roads in the winter is totally crazy, makes everything rust, but i spray all the undercarriage of the jeep with fluid film and i never had rust on my vehicles...i have just put some more fluid film where i cut the mount and its alll good...Rust is my enemy also and i know how to protect my jeep lol
98% of Canadian say '' oh **** '' before taking the ditch in winter time. The other 2% are from New-Brunswick and say '' hold my beer and watch this ''
2003 WJ 4.0, 4'' IRO Critical Path, 31x10.5x15 goodyear wrangler territory on soft 8's, Tom Wood front drive shaft, Rough country SS, 4.56 G2 gears, D30 front, D35 rear/detroit trutrac, IRO adj. trackbar, Doetch tech 8000 shocks, nv242 TC, midland cb, 3' firefly antenna, Mopar TC Skid
My build thread--> http://www.jeepforum.com/forum/f197/...-build-957216/
fireman33 is offline   Reply With Quote Quick reply to this message
Unread 04-09-2010, 09:51 PM   #65
MoonyJohn
Mallcrawler
MoonyJohn's Avatar
Love your WJ, pretty much exactly what I want mine to be like. How do you like the 4" kit? What shocks are you running, and how is the ride comfort compared to stock? I would most likely get bilsteins, but depending on how you like your shocks, I might change my mind. Also, do you like how the wheels with stock backspacing? Would you recommend getting wheel spacers?
I have a feeling I will be asking you a lot of questions lol.
MoonyJohn is offline   Reply With Quote Quick reply to this message
Unread 04-10-2010, 06:12 AM   #66
fireman33
2003 WJ
The 4'' is awesome, it rides really good on the road which is like 99% of my driving. And the flex you get out of it especially when disconnecting is really great...ive honestly never seen the limit yet, my tires are getting tucked right in the fender and i have to stop because of rubbing issue''only on the cladding, no need to trim off the metal part of the fender''...but all of them are still touching the ground.
I run the DT8000, personally i like them, a little bit stiff but they give a tight feeling on the road. And they will go up and down really good to allow lots of flex. Make sure you keep the metal sleeve out of the rear shocks you got right now to swap them in the DT because the one that comes with the shocks will give you an annoying clunk in the rear.
For the wheel...definitely get something offset or some wheel spacer, ill do that pretty soon also. When the rear wheel go up in the wheel well when flexing, the inside of the tire rubs against the shocks.
Unread 04-10-2010, 05:25 PM   #67
MoonyJohn
Mallcrawler
MoonyJohn's Avatar
Good to know, I was looking at your pictures and saw some marks on your shocks. I plan to get wheel spacers down the road, cause I love these stock rims.
One question though, was the vibe that you were getting in 4wd at high speeds? Also how short was your driveshaft?
Unread 04-10-2010, 07:24 PM   #68
fireman33
2003 WJ
No i didnt need to go at high speed to feel the vibe...4wd or 2wd as soon as the lift kit was installed doesnt matter the speed i could feel them.
Unread 04-10-2010, 08:18 PM   #69
fireman33
2003 WJ
but it was definitely worst in 4wd lol...i did not mesure the original drive shaft...didnt even took the time to compare was just to excited to put the new one in
Unread 04-10-2010, 09:24 PM   #70
MoonyJohn
Mallcrawler
MoonyJohn's Avatar
lol, dangit. Do you know if V8 247 shafts are longer/shorter than an I6 242?
Unread 04-11-2010, 09:37 AM   #71
fireman33
2003 WJ
No idea lol
Unread 04-11-2010, 09:44 AM   #72
GraKee99
Rapist Wit
GraKee99's Avatar
Pretty sure fronts are the same, not sure about the rear ones though.
Brian
WJ, WK, CJ5
GraKee99 is offline   Reply With Quote Quick reply to this message
Unread 04-11-2010, 09:57 AM   #73
Gigeroff
Lookin' great, keep up the good work. That rig would look awesome with some big*** tires on there.
Good to see another New Brunswicker, great sig BTW, so true.
Gigeroff is offline   Reply With Quote Quick reply to this message
Unread 04-11-2010, 10:00 AM   #74
fireman33
2003 WJ
Thanks, yes it would look awesome...but thats not gonna happen haha. Maybe if id have a v8 but no..:P
Unread 04-11-2010, 03:09 PM   #75
fireman33
2003 WJ
Just removed the transfer case drop spacers...glad i did...drives the same as before
