Free laptop software for Grand Cherokee?? - Page 2 - JeepForum.com
post #16 of 29 Old 03-29-2013, 07:35 AM
4Tom
I've the ELM327 Bluetooth and have used torque free and paid but I get very little live data for 3.1TD
I've tried a few of the free programs again limited live data. But the all read fault codes as far as I can tell.
WJ 2001 3.1TD
Tom
4Tom is offline
post #17 of 29 Old 03-29-2013, 07:36 AM Thread Starter
alfaitalia
Originally Posted by car5car View Post
Advance auto has a scanner for customers, which shows live data. I used it a few times. It has ABS and engine codes, but not air bag.
Just ask them, they'll let you use it.
It also shows graphs (diagram??)
I doubt they would let me use it!.........long way to deliver/collect it!
If you can't fix it with a hammer, you've got yourself an electrical problem!
alfaitalia is offline
post #18 of 29 Old 03-30-2013, 09:08 AM
MWF
MWF is offline
post #19 of 29 Old 03-31-2013, 06:16 PM
sandfreestyle
what's the best free one for iPhone?
04 WJ V8 HO, 545rfe w/ shift kit, NP231HD w/ SS SYE, TW drive shafts, 4" RCX, 255/75/17 moabs, 55w HID projectors, Cherry Bomb Vortex muffler, Superchips, bored TB, HD Tie rod and Drag Link, IRO Steering Equalizer, Dual steering stabalizers, Homemade Sliders, 4 Hella FF75 55w HID Light bar...
“The corpse’s crimson bitter tears flow and mingle through the endless sand feeding the chaos in me and making me stronger”
sandfreestyle is offline
post #20 of 29 Old 04-01-2013, 09:20 PM
Jeepgcl9947
Bumpity bump
Jeepgcl9947 is offline
post #21 of 29 Old 04-01-2013, 09:31 PM
ancientspear
free - turn key from off to on 3 times and odometer will display codes then finish with done. if it just says done, there's no codes. i'm pretty i read in this forum that you can reset codes by unplugging the battery for 10 minutes or something then plugging it back in.
ancientspear is offline
post #22 of 29 Old 04-01-2013, 10:38 PM
sandfreestyle
i want to know more real time stuff.
post #23 of 29 Old 04-01-2013, 11:41 PM
pinky2252s
Ever hear of these...?
http://www.ultra-gauge.com/ultragauge/index.htm
I have one, its pretty awesome.
Is it broken?
Colorado Jeep Club Member #2252
2001 Laredo, 2004 Special Edition
pinky2252s is offline
post #24 of 29 Old 04-01-2013, 11:48 PM Thread Starter
alfaitalia
Can't reset codes on a 04 CRD by disconnecting battery. They are in a permanent type of memory until you either delete them with the drbIII or similar or have 40 cold starts after the fault is fixed when it will delete itself.
Sent from my HTC Wildfire using JeepForum
post #25 of 29 Old 04-02-2013, 07:02 AM
sandfreestyle
Never heard of it but it does't have trans temp info. That's one thing at the top of the list of wants.
post #26 of 29 Old 04-02-2013, 08:21 AM
wvracer821
i use torque with my galaxy S 2 and cant get trans temp data either. its also something i would like to have. my plan is to weld a bung in the pan for a temp sensor and run a manual gauge.
DD: 2014 RAM 3500 Megacab Larmie 6.7L Cummins
Junk: 2000 WJ, 4.0L
Build Thread:
wvracer821 is offline
post #27 of 29 Old 04-02-2013, 02:42 PM
itsmeonjeep
Originally Posted by MWF
What's this we are seeing on your laptop?
Grand Cherokee 1999 WJ. 4.0L I6 with nothing upgraded as yet! Just trying to keep the car on the road...
itsmeonjeep is offline
post #28 of 29 Old 04-03-2013, 08:29 PM
narnwv
narnwv's Avatar
looks like dash command.
http://www.palmerperformance.com/products/dashcommand/
~Aaron
narnwv is offline
post #29 of 29 Old 04-04-2013, 02:37 AM
MWF
Originally Posted by narnwv View Post
It's PCMSCAN
http://www.palmerperformance.com/pro...scan/index.php
Perfect for seeing how my engine apparently revs too low and how my K&N kit only draws in red hot air.
Should work on the 'best engine' too I imagine.
Only $169.95
MWF is offline
