fosterjd79's WJ Build Thread - Page 9 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > fosterjd79's WJ Build Thread
Bilstein Shock Upgrade Kits, Jeep JK TJ XJ Wranglers and CJeep Wrangler Complete Gear Upgrade Kits with Installs andStainless Steel Door Hinge Pins
Unread 07-03-2013, 01:48 PM   #121
oaklyjeep10
I like the BTF cover I have and would prefer them but that's just because they're local ish.
RCLAs | IRO 6.5" springs| Nitto Trail Grapplers 35s | Smitty built 8000 | Custom front Bumper | Complete sound system 2 12s | BTF cover and truss (rear) | Custom sliders | Flashpaq [URL="http://www.jeepforum.com/forum/f197/dhalls-build-1508292/"]http://www.jeepforum.com/forum/f197/dhalls-build-1508292/[/URL]
oaklyjeep10 is offline   Reply With Quote
Unread 07-03-2013, 02:10 PM   #122
fosterjd79
Are you using both front and rear? Did the front fit behind the trackbar?
[URL=http://www.jeepforum.com/forum/f197/fosterjd79s-wj-build-thread-1498923/][COLOR="white"]Fosterjd79 Build Thread[/COLOR][/url]
fosterjd79 is offline   Reply With Quote
Unread 07-03-2013, 11:22 PM   #123
CommanderWJ
The poison spider one looks nice, but the BTF looks more beefy! What is the price difference?
2001 WJ 4.7 V8 Ltd QD. 2" Rough Country BB, TF QD's, Rough Country shocks, BDS Adjustable front UCA's, RC 2.2 steering damper, 245-70R17 Firestone Destination muds/ 245-75R17 Wrangler A/T's on Moab's, Flat Land non-winch steel bumper, rear sway bar removed, Power Brake matched disc and pad set. More to come!
CommanderWJ is offline   Reply With Quote
Unread 07-04-2013, 07:10 AM   #124
fosterjd79
They are the same price right now. So, the BTF LOOKS more beefy but...it is made of a 3/8" steel ring and 1/4" steel plate for the rest of the cover. The Poison Spyder is actually beefier. It is up to 1" thick around the ring and 7/16" to 1/2" for the rest of the cover. I can see a definite difference in quality for the same price now that you had me put it in writing. I guess my other question is, do both covers fit on the front D30 without modification?
I know I need to add a spacer to the rear sway to get the BTF D44a to work, but I wonder if anyone has experience with the PS Bombshell or the BTF D30 and can tell me about whether or not it hits the trackbar.
Unread 07-04-2013, 01:07 PM   #125
CommanderWJ
1" wow thats thick, I have no experince with either, but if they are the same price and the poison spyder is actually beefier, poison spyder would be my choice...
Unread 07-06-2013, 01:50 AM   #126
XYZj
Would you mind taking a picture of the stance of your wheel/tire setup? You are running the exact combo that I would like to run- moabs, spacers and destination mts. It's looking pretty good, thanks.
XYZj is offline   Reply With Quote
Unread 07-06-2013, 07:29 AM   #127
fosterjd79
Here is a random I took yesterday. Not sure if this helps. I'm heading to the beach today so will try and post pics tomorrow. The tires are actually 245/75/17 Duratracs.
Unread 07-06-2013, 07:56 PM   #128
XYZj
That's perfect! Thank you, and I actually meant duratracs, I've had firestones on my last 2 jeeps.
Unread 07-06-2013, 08:02 PM   #129
fosterjd79
For me, the verdict is still out in the 245 size tires. Yesterday I ran some rocks and mud. It was interesting. The skinny tire cut right down into the mud until it found traction. Much different than the other guys with wide tires who floated over the surface. They obviously had to sling mud everywhere to get through. I just pushed through the mud slow and steady. This is exactly what I was looking for in the mud and snow. Great tires!
Now on the rocks, things were a little different. I actually worried about the steering components because it was hard to keep the skinny tires on the rocks without the weight of the jeep making it slide. When those skinny tires slid down in between the rocks it would send the steering wheel flying. I get worried that one wheel is going to right and the other left.
Unread 07-07-2013, 12:48 AM   #130
CommanderWJ
I have been running 245's for about 2 years now and have been very happy with them, I think a wider tire looks nicer in most cases (or maybe I just need some wheel spacers!) I have had good performance all round an I have driven places that guys with lifted JK's didn't want to follow!
I usually air down to about 1.8 bar, which isn't ery low at all, but still gives me maximum clearance.
Unread 07-07-2013, 05:57 AM   #131
fosterjd79
I didn't air down for the wheeling trip the other day but did for the trip before that. 245 is still wide enough to "float" when aired down to about 15 psi.
Unread 07-07-2013, 12:02 PM   #132
fosterjd79
Started priming the half doors today. If the weather holds out I might try and bedline the interior side of the rear doors. I am going to try and color match the exterior. I ordered some 5oz aerosol cans in my paint color from Quadratec.com.
Unread 07-07-2013, 12:23 PM   #133
CRJEeP_wj
Nice! I look forward to seeing those on.
02 grand cherokee, hp60 14b, 42s. Stazwork, triangulated 4-link, rear leafs, homemade bumpers and sliders. build thread [url]http://www.jeepforum.com/forum/f197/creep-wj-tons-build-1505917/[/url]
CRJEeP_wj is offline   Reply With Quote
Unread 07-07-2013, 12:26 PM   #134
fosterjd79
Me too, man. I am taking the family on vacation to Maine on Aug 12th and I plan to make the drive with the half doors. That's my goal anyway.
Unread 07-07-2013, 03:27 PM   #135
fosterjd79
Now I am being indecisive. The rear doors are primed in a real dark grey, almost black. The primer looks decent but of course, the doors aren't mounted. I might hit them with a round of flat black and put them on that way to see what it looks like. It has the potential to look pretty bad a$$. Anyone have any thoughts? Silver jeep with matte black rims, flat black grille, and flat black half doors?
