fosterjd79's WJ Build Thread - Page 8 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > fosterjd79's WJ Build Thread
Attention to the TJ owners 1996-2006 NEW LED LIGHT OPTIONSBds fox ipf 2.0 racing series shocks now available at rockFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye Kit
Unread 06-25-2013, 10:59 PM   #106
CommanderWJ
+1
2001 WJ 4.7 V8 Ltd QD. 2" Rough Country BB, TF QD's, Rough Country shocks, BDS Adjustable front UCA's, RC 2.2 steering damper, 245-70R17 Firestone Destination muds/ 245-75R17 Wrangler A/T's on Moab's, Flat Land non-winch steel bumper, rear sway bar removed, Power Brake matched disc and pad set. More to come!
CommanderWJ is offline   Reply With Quote
Unread 06-26-2013, 08:01 PM   #107
fosterjd79
I still can't upload pics direct or from URL. WTF?
Fosterjd79 Build Thread
fosterjd79 is offline   Reply With Quote
Unread 06-27-2013, 07:26 AM   #108
fosterjd79
Can post pics! Finally!
Unread 06-27-2013, 07:38 AM   #109
CommanderWJ
Looks great!
Unread 06-27-2013, 08:07 AM   #110
fosterjd79
Thanks.
So, I used Duracoat Matte clearcoat on the rims after I coated them several times with VHT wheel paint. Anyway, the clearcoat cannot stand up to brake cleaner. When the tire guy sprayed the back of the rim some dripped onto the front and the runs ate through the clearcoat before the cleaner could dry. But...just a quick sand with a highgrit sandpaper, cleaning with soap and water, tack cloth, and quick whack with a layer of clearcoat made them look good as new. Took about 5 minutes.
Unread 06-29-2013, 04:19 PM   #111
fosterjd79
The hitch mounted tire carrier serves 2 purposes. 1. It carriers my tire, 2. It protects my gas tank!
But...there is a down fall. I lost my rear recovery because I can't use the hitch. Maybe in a pinch I could pull from the base of the carrier but it sounds like a bad idea so...I am mounting rear shackle tabs. Pics coming...
Unread 06-30-2013, 02:56 PM   #112
fosterjd79
Finished the rear shackle tabs today...
Unread 06-30-2013, 06:01 PM   #113
4x4Jeep
nice^
01 WJ, D30, D44a, 3.73 - 4" RC-X * 32" MT's * IRO adj. trackbar * Uniden CB w/ 4' Firestik * KC/Rigid lights * "Kolak" Flowmaster 70 exhaust *
Build-http://www.jeepforum.com/forum/f197/4x4jeeps-build-thread-1341031
Florida4x4.org
4x4Jeep is offline   Reply With Quote
Unread 07-01-2013, 12:53 PM   #114
CommanderWJ
+1, I like those shackle mounts, I don't think I have seen any one doing it like that before. Some details please!
Unread 07-01-2013, 03:03 PM   #115
Merc1973
Sweet C3R shackles! I have the same Knucklebone carrier and wanted to get those but I wasnt sure where to mount them. Looks Like I will have to give Mark a call. Any extra pics of how much plastic to trim?
2002 WJ Ltd. 4.7 V8, QuadraDrive
1973 Mercury Cougar Xr7 convertible 351CJ, C6, 9" rear
1970 Kaiser-Jeep M35A2 W/OW 6x6 Multifuel D-Turbo.
ΜΟΛΩΝ ΛΑΒΕ!
Merc1973 is offline   Reply With Quote
Unread 07-01-2013, 04:17 PM   #116
fosterjd79
Yeah, these are a set of the C3R shackle tabs for the WJ. Mark at Detours meant for them to be mounted pointing down towards the ground. I didn't like that idea because if you think about it, when you hook up to the shackles and pull a stuck WJ, the force on the shackles would create a twisting motion on the hitch. We originally decided to build them that way because we thought they would have to be much longer tabs if they point straight out of the bumper like I put them. Also, Mark was thinking that if he is going to mass market these, not many people would be willing to slice into their bumper.
Anyway, I mounted them pointed out from the bumper obviously. Minimal cutting was required but the tabs are not as secure as they could be. The tab is welded to a bracket that slides over the hitch. It is meant to sit in a U-shape which in my case would point the shackle down toward the ground and require zero cutting or at least only cutting that can't be seen. The U-shape bolts to the hitch with grade 8, 1/2" bolts supplied by Mark. I had to drill into the hitch using the C3R's as a guide. With his design the force would be put on the U-shape of the tab. When I pivoted mine to have them protrude from the bumper I turned that U-shape to a C-shape and now all the force from pulling will be on the bolts. This can be corrected if I weld the tabs onto the hitch. It's on the list to do someday so hopefully if I need them they hold up. I'm pretty confident in the grade 8 bolts.
This could also be corrected by having Mark weld the tab to the U-shape in a position to have them protrude from the bumper rather than point to the ground. I emailed him about what I did (I'm sure he's not thrilled) but I haven't heard back.
Unread 07-01-2013, 08:30 PM   #117
fosterjd79
I decided to read a little to make sure I completely understand the capability of the bolts that are holding a lot of items together on the Jeep (Trailer hitch, hitch shackles, Fawkes system, tow hooks, winch plates, etc). Came across this and thought I would post it here for future reference of formulas in the article. From what I can see, it looks like the 1/2" grade 8's that are holding the shackle tabs have a shear strength of over 14K lbs. I think I'm safe.
http://www.rockcrawler.com/techrepor...ners/index.asp
Unread 07-02-2013, 09:11 AM   #118
Fawkes
WJ recovery gear
Fawkes's Avatar
1/2 Grade 8 bolts, properly torqued, have a shear strength of ~9K# each.
Click to order:
WJ Stand-Alone Shackle Tabs.
WJ Modular Recovery & Bull Bar Relocation Kits.
Kris Fox
kfox@fawkesmfg.com
www.fawkesfab.com
Fawkes is offline   Reply With Quote
Unread 07-02-2013, 09:12 AM   #119
fosterjd79
So is the article wrong or am I misunderstanding it?
Unread 07-02-2013, 06:12 PM   #120
fosterjd79
I'm debating on buying the poison spyder D30 cover (http://shop.poisonspyder.com/Dana-30.../42-10-030.htm) and a BTF D44a or getting both from BTF. Anyone have any thoughts?
