fosterjd79's WJ Build Thread - Page 6 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > fosterjd79's WJ Build Thread
GEARSHADE Pocket Tops in stock and available at ROCKRIDGE Artec JK Under Armor BellypanEngo winches available at www.rockridge4wd.com! Free shipp
Unread 06-09-2013, 12:11 PM   #76
fosterjd79
4 coats and drying. I might do 1 or 2 more coats then let them cure.
[URL=http://www.jeepforum.com/forum/f197/fosterjd79s-wj-build-thread-1498923/][COLOR="white"]Fosterjd79 Build Thread[/COLOR][/url]
fosterjd79 is offline   Reply With Quote
Unread 06-14-2013, 05:08 PM   #77
fosterjd79
Added horse power...
Unread 06-17-2013, 08:31 AM   #78
4x4Jeep
that will get you about 20hp (5hp/sticker) plus with the Hybrid sticker you are now qualified to park in "Hybrid Spaces"
01 WJ, D30, D44a, 3.73 - 4" RC-X * 32" MT's * IRO adj. trackbar * Uniden CB w/ 4' Firestik * KC/Rigid lights * "Kolak" Flowmaster 70 exhaust *
Build-http://www.jeepforum.com/forum/f197/4x4jeeps-build-thread-1341031
Florida4x4.org
4x4Jeep is offline   Reply With Quote
Unread 06-17-2013, 11:42 AM   #79
fosterjd79
How funny would that be, lol, you're driving through a lot and see a row of prius with a WJ on 32's jammed into a parking space in between them all.
Unread 06-17-2013, 11:44 AM   #80
fosterjd79
Here is a pic of the bday yesterday. I was somewhere on I-84 in CT on the way home from the Bantam Jeep Fest. My brother was on the passenger seat and took the pic while I was driving.
Unread 06-17-2013, 02:59 PM   #81
fosterjd79
Painting rims is a real PITA! I think I am too much of a perfectionist for this. Anyway, I need to sand and cover a couple mistakes. I guess that's the good thing about rattle can paint; easy to fix. The VHT paint is tough to use. If you spray from too far away the paint dries as it hits the wheel and looks splotchy. If you hold the can too close the paint runs. I ended covering the paint with Duplicolor Matte clear coat. That stuff is great and covered a lot of the mistakes. I think I need to let it go since the whole idea behind rattle canning them was that they were going to get scratched off road. If you scratch powder coat you need to sandblast and recoat the whole wheel, if you scratch spray paint you just need to hit it with sand paper and touch up.
Unread 06-18-2013, 10:50 PM   #82
CommanderWJ
Nice build so far! I'm also busy with wheel painting and yes it is a major PITA, but well worth it in the end!
2001 WJ 4.7 V8 Ltd QD. 2" Rough Country BB, TF QD's, Rough Country shocks, BDS Adjustable front UCA's, RC 2.2 steering damper, 245-70R17 Firestone Destination muds/ 245-75R17 Wrangler A/T's on Moab's, Flat Land non-winch steel bumper, rear sway bar removed, Power Brake matched disc and pad set. More to come!
CommanderWJ is offline   Reply With Quote
Unread 06-19-2013, 09:33 AM   #83
fosterjd79
Thanks, it's a slow moving build but it's moving. The rims are curing now and are as good as they are going to get. I will post pics when I get them mounted.
Unread 06-19-2013, 07:13 PM   #84
fosterjd79
Saw these at Bantam...they are definitely on my wish list.
Unread 06-20-2013, 08:58 AM   #85
fosterjd79
Started wiring lights. I added the switches to the dash above the steering wheel and below the instrument cluster (See pic). One of the switches is for lights and the other will be for a quick emergency power cutoff for the winch. I am jumping the power for the switches from the lighter outlet. I have a solenoid under the hood for the lights and another large one for the winch cutoff, not sure where I'm going to put it yet.
Unread 06-20-2013, 04:12 PM   #86
fosterjd79
Work was getting in the way today. Everything is wired up except the lights themselves. Just 4 more plugs and they're ready to go. Nothing is easy though. I had to reconnect the wire crimps on the switch a couple times for some reason it kept coming loose when I would snap the dash back in place.
Unread 06-20-2013, 05:10 PM   #87
fosterjd79
I'll be adding a cutoff switch for the winch too. Here is a link to the 500amp continuous relay that I'm using. http://www.sonicelectronix.com/item_...Bay-IB500.html
Unread 06-20-2013, 05:46 PM   #88
fosterjd79
Here is a daytime pic of the lights mounted. I will take a pic in the dark with the lights on once the sun goes down.
Unread 06-20-2013, 06:55 PM   #89
fosterjd79
Lights...
Unread 06-21-2013, 12:46 AM   #90
CommanderWJ
Coming along nicely!
